(atmega 16 )turning off mains when no one is inside after a delay
4 posts / 0 new
what my code should do is, whenever someone enters and he is the first one to be inside that time mains should turn on so tat he can use the  fan, light ,etc. I am using 2 ir sensors to detect if someone is entering or leaving the room.Once everyone leaves the room the microcontroller should wait for a certain delay so tat it wud b better to not keep turning off mains if ppl keep coming in and going out so tats d reason y i want to turn off mains wen all leave the room and wen no one enter even after tat specific delay. I am using 555 timer for timing and parallelly keep checking if someone entered. Wen i run the code n i keep hand to just giv a sign about a person entering and leaving and make count zero it directly turns off the mains without d delay. I am unable to understand how the timer function is getting skipped. Pls help me
#include <util/delay.h>
#define F_CPU 1000000UL
int count=0,start_timer=0,ir_check,timer_op,OutOfTime=0;
int timer(void);
		DDRC=0x00;  //port A input for ir sensor values
		DDRD=0xff;	//for a relay which is used to switch from vcc to ground and vice versa
		PORTD |= (1<<PD5);  //trig pin is made high
			ir_check = PINC & (0x03); //to read which ir is read and count is manipulated based on tat
			if((ir_check==1))
				_delay_ms(50);
				if(ir_check==2)
					count+=1;  //1 person entered
			if((ir_check==2))
				_delay_ms(50);
				if(ir_check==1){
				count-=1;	//1 person left
			if((count==0)&&(start_timer==0)){
				timer();  //none inside so start timer
				PORTD |= (1<<PD6);//relay on
			if(count!=0)
				start_timer=0; //if someone entered then it should not turn off relay
			OutOfTime=(PINC & (0x04)); // to read if 555 delay of X sec is over and output of is low
			if(OutOfTime==4){
				OutOfTime=0;
			}else
				OutOfTime=1;  //timer crossed the designed T(ON)
			if((OutOfTime==1)&&(count==0)&&(start_timer==1))
				PORTD &= ~(1<<PD6);   //relay off
				start_timer=0;
			_delay_ms(100);
		return 0;
int timer(void)
	PORTD |= (1<<PD5);	//send 1 to 555 timer trig
	PORTD &= ~(1<<PD5);	//send 0 to trig
	_delay_ms(10);		//delay ms for hold time for 555 to detect trigger
	PORTD |= (1<<PD5);	//send 1 to trig
	start_timer = 1;
	return 0;
You already have a thread on this: http://www.avrfreaks.net/forum/avr-automatic-turn-power-mains-using-timer
prostriker wrote:
Pls help me and i am in a hurry to complete this
http://www.catb.org/~esr/faqs/sm...
tats my thread but this is a different code than the previous one so i just made a new post
it's the same topic - stick with one thread, and pay attention to the advice that has already been given there - in particular, #10
Topic locked
