Split from: Using c++
3 posts / 0 new
Hi all,
I've got ARM Cortex M4 based kit SAM4E Xplaied Pro and wanto to do a C++ development on it using Atmel Studio 7. But even a sample C++ project fails to build, when I add ASF packagaes to it, like Standard Serial I/O (stdio) and try to compile Hello World program using printf.
I got these errors:
Severity Code Description Project File Line
Error recipe for target 'src/ASF/sam/drivers/pmc/sleep.o' failed GccApplication2 D:\Projects\AtmelStudio\GccApplication2\GccApplication2\Debug\Makefile 337
Error recipe for target 'src/ASF/sam/drivers/pmc/pmc.o' failed GccApplication2 D:\Projects\AtmelStudio\GccApplication2\GccApplication2\Debug\Makefile 337
Error recipe for target 'src/ASF/sam/utils/cmsis/sam4e/source/templates/system_sam4e.o' failed GccApplication2 D:\Projects\AtmelStudio\GccApplication2\GccApplication2\Debug\Makefile 344
Error 'PMC_FSMR_FLPM_FLASH_DEEP_POWERDOWN' undeclared here (not in a function) GccApplication2 D:\Projects\AtmelStudio\GccApplication2\GccApplication2\src\ASF\sam\drivers\pmc\pmc.h 117
Error 'PMC_FSMR_FLPM_FLASH_IDLE' undeclared (first use in this function) GccApplication2 D:\Projects\AtmelStudio\GccApplication2\GccApplication2\src\ASF\sam\drivers\pmc\pmc.h 118
Error 'PMC_FSMR_FLPM_FLASH_STANDBY' undeclared (first use in this function) GccApplication2 D:\Projects\AtmelStudio\GccApplication2\GccApplication2\src\ASF\sam\drivers\pmc\sleep.c 316
So, could you please tell me how to create just a plain "Hello world" C++ example and to build a nd run , printing message on the serial terminal ?
thanks
Frantisek
Forget the "Error List" - it is utterly hopeless. Look at the "Ouptut" tab and see what the actual errors reported actually were.
So why are you hijacking a Mega/Tiny AVR thread, then?
And a 6-year-old one, at that!
