ATmega328 UART won't transmit
11 posts / 0 new
I've been trying to get the UART on my Arduino to transmit but with no success.  Here is my initialization code:
// initialize UART
UCSR0C &= ~(1<<UMSEL01 | 1<<UMSEL00); // async UART mode
UCSR0C &= ~(1<<UPM01 | 1<<UPM00 | 1<<USBS0 | 1<<UCPOL0); // no parity, 1 stop bit (tx only), clock polarity set to "0" for async mode
UCSR0C |= 1<<UCSZ01 | 1<<UCSZ00; // character size = 8 bits
UCSR0B |= 1<<UCSZ02; //
UCSR0B |= 1<<RXEN0 | 1<<TXEN0; // enable tx, rx pins (overrides normal port pin function)
UCSR0B |= 1<<RXCIE0 | 1<<TXCIE0; // enable rx, tx interrupts
UCSR0A |= 1<<RXC0 | 1<<TXC0; // these bits are also used to enable interrupts on the rx, tx
UBRR0 = BAUD_4800; // set baud rate, 12-bit baud rate register (see Table 20-4, p187 of ATmega328 datasheet)
And here is the UART transmit interrupt routine:
ISR(USART_TX_vect)
uart_tx_flag = true; // set this flag to indicate that character in tx shift register is done
And here's the code in my main program:
else if (uart_tx_flag==true) // if UART tx'd character is done
uart_tx_flag=false; // clear semaphore
UDR0 = 0x55; // transmit another byte
I also have a line at the start of my program that loads a byte into the UART transmit buffer to get things kicked off.
Thanks for your help!
Dan
cleaned up the code - Jim
Why all those RWM?  Needlessly complex, hard to debug/understand, and if the registers contain anything other than the post-reset default values, you may not be setting what you think you're setting.
Did you realise you were setting 9-bit mode?:
Probably not, given the comment.
You've also enabled both the receive and send interrupts:
... but you've only provided a TX ISR.  If any bytes do come in, the AVR will run the 'catch-all' default ISR and restart your app.  Don't enable the RX interrupt unless you provide an ISR.
This:
... is incorrect.  Those are flags, not enable bits.  Writing them as '1' will simply clear any pending interrupt flags.  Not relevant to your situation.
What exactly are you trying to accomplish?  The use of the transmit complete interrupt is not common.  Most people poll UDREn (or use the associated interrupt) and feed the USART a new byte as soon as the buffer has room.  The TX has effectively a two-byte buffer (1-byte plus shift register).
Anyway, avoid RWM when configuring a peripheral:
UCSR0C = (1<<UCSZ01) | (1<<UCSZ00);
UCSR0B = (1<<RXEN0) | (1<<TXEN0);
UBRR0 = BAUD_4800;
... and unless you're actually using the receiver, there's no point in enabling it.
"Read a lot.  Write a lot."
Hi Joey,
Yes - I realized I was in 9-bit mode after I posted.  I made all the corrections that you suggested and I am still not seeing any bytes transmitted.
Also, I do have an RX interrupt - I'm just not showing it right now because I can't even get the TX to work.
I have the clock configured for 8MHz internal RC and divide by 8, so I have a system clock of 1MHz.  I know this is working because I have a timer interrupt setup to run at 50ms and it works perfectly.
Is there anything else that I need to do to configure UART clocks, etc. that I may have overlooked?
Dan
	//	initialize UART
//	UCSR0C	&=	~(1<<UMSEL01 | 1<<UMSEL00);									// async UART mode
//	UCSR0C	&=	~(1<<UPM01 | 1<<UPM00 | 1<<USBS0 | 1<<UCPOL0);				// no parity, 1 stop bit (tx only), clock polarity set to "0" for async mode
//	UCSR0C	|=	1<<UCSZ01 | 1<<UCSZ00;										// character size = 8 bits
//	UCSR0B	&=	~(1<<UCSZ02);												// 8-bit data
//	UCSR0B	|=	1<<RXCIE0 | 1<<TXCIE0;										// enable rx, tx interrupts
	UCSR0B	|=	1<<RXCIE0 | 1<<UDRIE0;										// enable rx, tx interrupts
//	UART transmitter interrupt
ISR(USART_UDRE_vect)
Then it would seem as though you should start there.  Get TX working.  Forget RX altogether.  One thing at a time, otherwise you're not sure what the source of the problem is.
Write a complete, short test program which configures the USART and continuously transmits 'U'.
Do you have an oscilloscope?
Hi Joey,
That's essentially what I'm doing.  I have a short program that is attempting to transmit.  I am monitoring the TX pin on the Arduino with my o-scope and I get nothing.  I even tried disabling the interrupts so I could poll the transmitter and send a character when the shift register is empty.  That doesn't work either.
Dan
		else if( UCSR0A & (1<<UDRE0) )
			UDR0 = 'U';
By complete and short, I mean:
int main(void) {
    UCSR0B = (1<<TXEN0);
    UBRR0 = 12;
    while (1) {
        while (!(UCSR0A & (1<<UDRE0)));
        UDR0 = 'U';
I don't know what BAUD_4800 is defined as, so I just did the math for 1 MHz, single-speed, 4800 baud.
This should give you a 2.4 kHz square wave on TXD.
I tried that and it worked!  So, I started commenting code out until I found what was causing the problem.  For some reason, timer 2 is keeping the UART TX from running.  I wonder if it has something to do with the Baud Rate generator?
void rc_board_init(void)
	// initialize timer 2
	PRR	|= 1<<PRTIM2 | 1<<PRTIM0 | 1<<PRTIM1;								// turn off timers
	PRR	|= 1<<PRSPI | 1<<PRUSART0 | 1<<PRADC;								// turn off SPI, USART, ADC
	PRR  &= ~(1<<PRTIM2);													// enable Timer/Counter 2 module
	OCR2A = 0x30;															// set output compare register (A) for timer/counter 2 (approx 20Hz, 50ms)
	ASSR &=~(1<<AS2);														// select internal clk(io) as clock source for timer/counter 2
	TCCR2B |= (1<<CS22 | 1<<CS21 | 1<<CS20);								// select prescaler to divide by 1024 for timer/counter 2
	TCCR2A |= 1<<WGM21;														// set timer mode to CTC
	TIMSK2 |= 1<<OCIE2A;													// enable interrupt for Compare match A
	TCCR2A |= 1<<COM2A0;													// toggle OC2A on PORTB, bit3 (waveform will appear as 10Hz, 100ms)
	DDRB   |= 1<<DDB3;														// set PORTB, bit3 to output for OC2A
	//	initialize UART
//	UBRR0	=	BAUD_4800;													// set baud rate, 12-bit baud rate register (see Table 20-4, p187 of ATmega328 datasheet)
//	UCSR0B	|=	1<<TXEN0;													// enable tx, rx pins (overrides normal port pin function)
//	UCSR0B	|=	1<<RXEN0 | 1<<TXEN0;										// enable tx, rx pins (overrides normal port pin function)
//	UCSR0B	|=	1<<RXCIE0 | 1<<UDRIE0;										// enable rx, tx interrupts
	UBRR0 = 12;
	//	initialize ports
	DDRB |= 1<<ARDUINO_LED;													// bit 5 on port B is output (LED on Arduino)
	DDRB &= ~(1<<WARM_RST_N | 1<<COLD_RST_N | 1<<PMIC_SYS_RST_N);			// bits 0,1,7 on port B are inputs
	PORTB |= 1<<WARM_RST_N | 1<<COLD_RST_N | 1<<PMIC_SYS_RST_N;				// turn on internal pullups for input pins on port B
	DDRC |= 1<<nRESETREQ | 1<<QSPI_RST_N | 1<<PS_SRST_N | 1<<PS_POR_B;		// bits 0,1,2,3 on port C are outputs
	DDRD |= 1<<RC_LED;														// bit 7 on port D is output
	//DDRD |= 0x02;															// UART Tx set to output
	PORTC = 1<<nRESETREQ | 1<<QSPI_RST_N | 1<<PS_SRST_N | 1<<PS_POR_B;		// set ALL reset lines HIGH
Okay, I feel really dumb right now.  I just saw what I did.  I was disabling the UART in the timer initialization routine (PRR register)
I really appreciate your help.
Dan
Glad you got it sorted.
Which is a fine illustration of what Joey said:
EDIT
See also: http://www.avrfreaks.net/comment...
Glad you got it working, but the internal RC makes for a poor serial clock source, as a change in temperature or VCC will cause clock drift and loss of async comms.
When using serial i/o its best to use a xtal clock source.
