Serial runs at 642 instead of 115200
5 posts / 0 new
I'm trying to get send data on a UART line on a custom board with a AT32UC3C2512C microcontroller. I've never used Atmel before (except Arduino) so I don't know what I'm doing.
So far, I have the UART sending data, but the data rate is slow. I put 115200 as the baudrate, but the actual signal is 642.
The board has a 20MHz crystal as XTAL0. I've tested a blinky code and it seams to run at the correct speed.
Is there something I'm missing?
#define BOARD_OSC0_HZ          20000000
#define BOARD_OSC0_STARTUP_US    142000
#define BOARD_OSC0_IS_XTAL		   true
#include <asf.h>
#include <gpio.h>
#include <delay.h>
#include <usart.h>
#  define USART                 (&AVR32_USART0)
#  define USART_RX_PIN          AVR32_USART0_RXD_2_PIN
#  define USART_RX_FUNCTION     AVR32_USART0_RXD_2_FUNCTION
#  define USART_TX_PIN          AVR32_USART0_TXD_2_PIN
#  define USART_TX_FUNCTION     AVR32_USART0_TXD_2_FUNCTION
#  define TARGET_PBACLK_FREQ_HZ   BOARD_OSC0_HZ// PBA clock target frequency, in Hz
int main (void)
	sysclk_init();
	board_init();
	static const gpio_map_t USART_GPIO_MAP =
		{USART_RX_PIN, USART_RX_FUNCTION},
		{USART_TX_PIN, USART_TX_FUNCTION}
	// USART options.
	static const usart_options_t USART_OPTIONS =
		.baudrate     = 115200,
		.charlength   = 8,
		.paritytype   = USART_NO_PARITY,
		.stopbits     = USART_1_STOPBIT,
		.channelmode  = USART_NORMAL_CHMODE
	// Assign GPIO to USART.
	gpio_enable_module(USART_GPIO_MAP,
	sizeof(USART_GPIO_MAP) / sizeof(USART_GPIO_MAP[0]));
	// Initialize USART in RS232 mode.
	usart_init_rs232(USART, &USART_OPTIONS, TARGET_PBACLK_FREQ_HZ);
	while (true) {
		usart_write_line(USART, "Hello world!");
		delay_ms(200);
Not sure if this will make a difference, but...
#define BOARD_OSC0_HZ          20000000UL
I always specify my defines (greater than 64K) as unsigned long.
Edit: Strike through due to post #3.
I knew I shouldn't respond to a post on a processor I have never used!
David (aka frog_jr)
Except that this is a 32 bit micro ;-)
Your system clock is still the default 115 kHz.
115200 baud desired * ( 115 kHZ actual / 20 MHz desired ) = 662 baud actual.
Something is wrong (or missing) with the #defines that sysclk_init() uses to configure the clock(s).
Fixed it!
The problem was in conf_clock.h. CONFIG_SYSCLK_SOURCE was defined as SYSCLK_SRC_RCSYS. I changed it to SYSCLK_SRC_OSC0 and its working now
