ATMega32U2 Tx/Rx LEDs
3 posts / 0 new
Hi to all,
I'm working with an ATMega32U2,
Powered and programmed via USB,
I wish to know if it's possible to add Tx/Rx LEDs in some way.
I've tried to look in atmega datasheet, but i found nothing.
Hope that someone can help me, and sorry for my bad english.
Kind regards,
Yomega96
Rx and tx leds for what? Are you doing usb to serial? If so, connect the leds to the rxd and txd pins. Be sure to use current limiting resistors.
Thanks for the reply,
you get the point.
It works, thank you for the help.
