Attiny85 8Mhz+PLL for both CPU clk and peripheral clk at the same time?
3 posts / 0 new
I know it's possible to get 16 MHz CPU clock from the 8 MHz internal RC + PLL. It's also possible to get 64/32 MHz peripheral clock the same way. But what about having both at the same time? I didn't find anything in the datasheet that says it's impossible, but it doesn't mention it as a possibility either.
Yes you can have both.  IIRC, with the 16 MHz system clock via the PLL, you cannot use the slower 32 MHz FPC, only the 64 MHz is available.
"Read a lot.  Write a lot."
Perfect! Thanks.
