Lightweight mesh on ATSAMR21B18-MZ210PA
3 posts / 0 new
I use Lightweight mesh application on SAM R21 Xplained Pro Evaluation Kit without any problems. Now I want to use it on ATSAMR21B18-MZ210PA. R21 Xplained Pro has ATSAMR21G18A MCU, while ATSAMR21B18-MZ210PA has ATSAMR21E18A MCU. I find it is very difficult to transfer my code used on R21 Xplained Pro to ATSAMR21B18-MZ210PA or create a new lightweight mesh application for ATSAMR21B18-MZ210PA.
I know ATSAMR21G18A and ATSAMR21E18A have different I/O PIN.  It looks like Atmel Studio only supports ATSAMR21G18A in Example Project and in ASF for Lightweight mesh application. If I try to use them for ATSAMR21B18/ATSAMR21E18A, it seems that I need change a lot. Is there a good way to do that?
Actually I tried modify the code and configuration. I have many problems. For example, PHY_Init() is stuck at void trx_reg_write(uint8_t addr, uint8_t data). After I check it, I find AT86RFX_SPI for SERCOM4 register is the problem. Can anyone help?.
Hi kz312
I am starting at this very moment to play around with teh same combination.
did you find by now a solution how to get the examples compiled for the ATSAMR21B18-MZ210PA.?
If not, maybe we can find it together?
All the Best
Frank
Hi Kz312,
Did u get solution on your problem? I have same problem occurred.its very difficult to transfer a data.
