AtmelStudio 7 error list RUNCOMPILERTASK line 0
4 posts / 0 new
Where can I get more log/ info for RUNCOMPILERTASK in the error list after a build? I have 2 identical error lines in the whole error list both where it is written RUNCOMPILERTASK  in the file with line 0.
In the description, I see some code. I am able to find the file with this code, but I don't see anything special.
I got this project from a person that is on vacation, so I don't know more deeply about the problem. I am compiling for SAM E70 on Atmel Studio 7.
Frank
Use the output window to get the fill output of the command.
:: Morten
+1
And if you still can't understand it, then copy the full message from the output window and paste it into a reply here.
Do not try to manually re-type the message.
I found in the output window messages about printf. The codes is third party with macro expansions using printf. I don't need printf and the serial output is used differently elsewhere in our in-house code. I took it out and it compiles fine.
warning: incompatible implicit declaration of built-in function 'printf'
include '<stdio.h>' or provide a declaration of 'printf'
Frank
