UART new line issue
16 posts / 0 new
HI,
I have a simple code that receives and transmits string through UART. I use ATMEGA 168.
So according to my code I transmit a string using cool term and the controller receives it.The controller the compares the string .If the strings match then the controller sends back  "K" , which will be displayed in the cool term.
If the strings don't match the controller sends back"AT" followed by  carriage return and new line.
But when I execute the code and if the strings don't match it returns back "AT";but I do not get a new line.It prints "AT" continuously.
#include <string.h>
#include <util/delay.h>
#define F_CPU 8000000UL
#define BAUD 9600
#define MYUBBR F_CPU/16/BAUD-1
void uart_init(unsigned int ubrr)
	// Setting the baud rate to ubrr
	UCSR0A = 0<<U2X0;
	UBRR0H = (unsigned char)(ubrr >> 8);
	UBRR0L = (unsigned char)ubrr;
	//Setting the frame format to 8 data bit, no parity bit, 1 stop bit
	UCSR0C = 3<<UCSZ00;
	UCSR0B = (1<<TXEN0)|(1<<RXEN0);
void USART_Transmit( unsigned char data )
	while (!(UCSR0A & (1<<UDRE0)));
	UDR0 = data;
unsigned char USART_Receive()
	while (!(UCSR0A & (1<<RXC0)));
	return UDR0;
void transmit_string(char* data)
	int i;
	for (i=0;data[i] != '\0';i++)
		USART_Transmit(data[i]);
void receive_string(char* dat)
	char command[4];
	command[0] = '\0';
	command[1] = '\0';
	command[2] = '\0';
	command[3] = '\0';
	int index = 0;
	while ((command[2] != 0x0D) && (command[3] != 0x0A))
		dat
= USART_Receive(); index += 1; if (index > 3) { command[0] = dat[index - 4]; command[1] = dat[index - 3]; command[2] = dat[index - 2]; command[3] = dat[index - 1]; } } dat[index-2] = '\0'; } int main(void) { // Setting system clock to 8MHz CLKPR = (1 << CLKPCE); CLKPR = 0; uart_init(MYUBBR); while(1==1) { char dat[10]; receive_string(dat); if(strcmp(dat,"OK")==0) { UDR0='k'; } else { char data[]="AT"; transmit_string(data); UDR0='\r'; UDR0='\n'; _delay_ms(1000); } } }
Kindly point out the mistake .
When transmitting the '\r' and '\n' you are not waiting for UDRE0 to clear. Fix by calling USART_Transmit() rather than explicitly assigning UDR0 in main().
Have you checked what your terminal actually transmits for "newline" ?
Most terminals are configurable as to what they send when you press the "enter" or "return" key - CR, LF, CRLF, etc ...
Also, some implementations of stdio will do similar translations.
Also, most terminals are configurable as to how they will handle incoming CR and LF ...
The ATMEGA 168 has on-chip debug - use it to step through the code and see what's actually happening
@awneil: I believe this is a case of overrunning UDR0, ie a timing problem. If I'm right then debugging and single-stepping will alter/diguise the faulty behaviour. Agree?
Agree!
Geeth wrote:
			char data[]="AT";
			UDR0='\r';
			UDR0='\n';
Apart from the error that Johan's already pointed out,  why would you not simply do
			char data[]="AT\r\n";
(someone will be along soon to explain about putting constant strings in Flash...)
Thank you that worked.It was overrunning  problem .
A note on style.
You have:
The key to good programming style - whatever style you choose - is to Be Consistent!
You have four USART-related functions:
  • two of them are prefixed "USART_"
  • one of them is prefixed "uart_"
  • one of them has no prefix at all!
EDIT
typo
Thank you for sharing this knowledge :-)
You're welcome.
Did you get the point about including the "\r\n" in your string - rather that sending them as separate individual characters?
yes it would optimize my code
In the above mentioned code if I make a slight change that is add transmit(commented it below) before receive , the program does not transmit when I connect it to cool term.It waits until it receives a message and then transmits.Why doesn't it transmit first and receive next as it is the flow in my program?Kindly point out the mistake
	CLKPR = 0;
	uart_init(MYUBBR);
	while(1==1)
		char dat[10];
		transmit_string("AVR");//transmit AVR
			UDR0='k';
			char data[]="AT";
			UDR0='\r';
			UDR0='\n';
			_delay_ms(1000);
New question = new thread.
Oh OK , I will create a new topic:-)
Give a link once you've created it.
If you need to reference this thread in the new one, you can also include a link there.
link  for the new thread:   http://www.avrfreaks.net/forum/u...
