Attiny44 I2C interface
4 posts / 0 new
I m new to I2C, I was trying to implement it using attiny44 as master. I have following doubt:
When start condition is produced making the SCL pin high and SDA pin low, after that SCL should continue its operation as a clock pin, so how to switch from start condition to its clock operation?
-- That AVR model does not have a native TWI/I2C peripheral
-- It does have the USI; there are app note(s) on using that
-- If you want to bit-bang I2C, many will recommend starting with a known-good implementation.  In this case, "Fleury"...
http://homepage.hispeed.ch/peter...
That rather raises the question of "why tiny44?" in the first place. If one of your chief design goals is using I2C then why did you pick a chip that does not have it? What else attracted you to tiny44? Perhaps other AVRS have its "must have" features" too but also have I2C?
Absolutely!!
