USART with Timers Atmega32
62 posts / 0 new
I was trying to use USART to communicate between 2 Atmega32 Microcontrollers, But i'm facing some problems like whenever i use 16 mhz crystal it shows excessive CPU usage, and when i use lower internal clock it slow down the transmitting speed . Apart from this i was sending data to another microcontroller and receiving it using timers like every some millisecond but it creates some problem like "UDR read without transmitting" and My main loop function of 2nd microcontroller aint working it stucks at some point. I am so confused whats happening. I just want to know if there is any way possible like whenever i press button data transmits and received without delay and without disturbing main loop cycle.
Manish verma
for start show your code
Usart receive interrupt could solve that proplem.
whenever i use 16 mhz crystal it (sic) shows excessive CPU usage
What shows that?
Remember that UART transmissions take some time; eg, at 9600 baud, it takes 104us for each bit - so over a millisecond per byte.
So: what baud rate are you using? what does "some millisecond" actually mean?
Again, where is that message coming from?
Are you, perhaps, running this in a simulator ... ?
If you are running in a simulator, then you should be able to see exactly where that point is.
If you are running on real hardware, then remember that the ATmega32 has on-chip debug - so use it! Again, that would allow you to see exactly where it is sticking.
yes i am using Proteus as an simulator.  And those are some run time messages (u can say error) when i start simulation it occurs
Manish verma
You've given us no further information regarding your problem. We do the impossible everyday, but miracles take a little longer. How about showing us some code so we can at least have some idea.
So pay attention to those messages!
Presumably, they also tell you where the reported problems are occurring?
Proteus is a tool - take some time to learn how to use it properly!
https://www.labcenter.com/simulation/
https://www.labcenter.com/tutorials/
http://support.labcenter.co.uk/forums/
EDIT
Add quote
Setting up comm's between two micros can be tricky if using unproven comm's functions, you don't know if the problem is not correctly sending or not correctly receiving.
So, separate the two and work on proving one, then the other.   How?  Use known good h/w + s/w, i.e. your PC,  use a terminal program (hyperterm, teraterm, putty or others) and a USB to serial TTL (TTL is important, not rs232) and connect it to one micros usart TX/RX pins (note: PC TX connects to micro RX, micro TX connects to PC rx)
and then begin testing your putchar() function by sending a "U" char over and over again.    If you can see this on your PC, then the baud rate init is working correctly.
Then test the getchar() function by doing the reverse sending "U" from the PC to the micro.
Once that is working, you now have a base of working h/w + s/w to begin working on the second micro, duplicate the same tests on it.
Good luck with your project, and for more help, post your code using the "<>" icon above.
Or both!
Full, illustrated instructions here: http://www.avrfreaks.net/comment...
Oh this Proteus, please use there support, after all your paying for it!   https://www.labcenter.com/contact/
ki0bk wrote:
 you're paying for it!
Or, if your school is paying for it - get your teachers to show you how to use it properly.
well i am not paying anything to anyone.
Manish verma
So you have stolen your copy of Proteus?
what do you mean stolen.?
Manish verma
Proteus is not free software - so, if you haven't paid for it (and your employer or school hasn't paid for it), then you must have stolen it.
Please try to understand i am beginner and trying to understand the concepts.
ISR (TIMER1_OVF_vect)    // Timer1 ISR
   if(PINA!=0x1f)                                // this is for button sense
	 val=PINA;
	 button(val);
	while(!(UCSRA&(1<<RXC)));                        //this is what i am trying for receiving
		  received_data=UDR;                     //passing UDR value to another variable
		  if(received_data==0)
		    counta1=1;
			PORTD=1<<7;
		  if(received_data==1)
		    countb1=1;
		  if(received_data==2)
		    countc1=1;
		  if(received_data==3)
		    countd1=1;
      TCNT1 = 63974;
This is my ISR for Timer1 in here i m trying to receive data from 1st microcontroller and passing those value  into another variables.
void logic()
    if(counta>7)
      	  while(!(UCSRA&(1<<UDRE)))
	   UDR=0;
     else if(countb>7)
	   UDR=1;
     else if(countc>7)
	   UDR=2;
     else if(countc>7)
	   UDR=3;
This is how i m sending my data from 1st microcontroller.
int UBBRValue = 25;
   UBRRH = (unsigned char) (UBBRValue >> 8);
   UBRRL = (unsigned char) UBBRValue;
   UCSRB = (1 << RXEN) | (1 << TXEN);
   UCSRC = (1 << USBS) | (3 << UCSZ0);
And this my USART setting i did on both controllers with F_CPU 1000000UL (i.e. 1MHz).
void cycle()
    send_a_command(0xcf);
    send_a_string("A");
    PORTC=1<<2;
   if(PORTC==1<<2)
     if(counta1!=1)
      PORTD=1<<3;
      PORTC=1<<6|1<<3|1<<2;
      _delay_ms(gtim[0]*1000);
      PORTC=1<<6|1<<3|1<<1;
      _delay_ms(ytim*1000);
      PORTC=1<<5;
      counta=0;
     gtim[0]=6;
     PORTC=1<<5;
   send_a_string("B");
   if(PINC==1<<5)
    if(countb1!=1)
      PORTD=1<<3;
      PORTC=1<<6|1<<0|1<<5;
      _delay_ms(gtim[1]*1000);
      PORTC=1<<6|1<<0|1<<4;
	  PORTD=1<<2;
      countb=0;
    gtim[1]=6;
	PORTD=1<<2;
   send_a_string("C");
   if(PORTD==1<<2)
    if(countc1!=1)
      PORTD=1<<2|1<<3;
      PORTC=1<<0|1<<3;
      _delay_ms(gtim[2]*1000);
      PORTD=1<<3;
      PORTC=1<<0|1<<3|1<<7;
      PORTD=1<<5;
      countc=0;
     gtim[2]=6;
	 PORTD=1<<5;
    send_a_string("D");
   if(PORTD==1<<5)
    if(countd1!=1)
      PORTD=1<<5;
      PORTC=1<<0|1<<3|1<<6;
      _delay_ms(gtim[3]*1000);
      PORTD=1<<4;
       PORTD=1<<2;
      countd=0;
     gtim[3]=6;
	 PORTC=1<<2;
And this is what i am trying to do with received values. This is my main while loop and i dont want to interrupt it while receiving and transmitting data
Manish verma
It looks like you wrote the code before you designed the system. I seem to recall suggesting you use the timer CTC mode rather than interrupting on overflow and reloading the timer. You would do this on an 8051 cpu because there was no other choice. The AVR has a better and simpler solution -CTC mode.
Why would you wait for a rx character in an isr? The usual solution would be to use a rx interrupt - that's why they put it there. Your reading of the button is effectively useless. The usual method is to have debounce code in the isr.
Did you read the manual on the delay functions? They say something about the delay value being constant. You broke that rule.
I can't make much sense of of the code - there's few comments and i can't understand what you were trying to achieve. Design the system first then write the code.
+999 !!!
SEE this system
Manish verma
 will you please help me by sharing how to use CTC mode with interrupt ISR. Actually i tried searching for it but aint got anything related to it.
Manish verma
You seem to be doing a great job of wasting not only your time but ours as well. Where did you search? Did you read the mega32 datasheet? Or google avr ctc ?
As for the picture of your system - all i see is blocks. What are they supposed to do? am. Am I to guess this is a school project and you have to make a traffic light system?
first thing is i m not in school second thing i m doing this for my own . there is no school , no office, no college kind of thing involved. and last but not the least i really wanna do something in it thats y i am working on it but not wasting my time.
Manish verma
And instead of wires i used wire labels so i guess thats why it seems like boxes only but if u zoom that image u can see there is a label on every single wire.
Manish verma
Aw traffic lights, perhaps this tutorial would help!   http://www.avrfreaks.net/forum/t...
ty so much ki0bk its really very helpful....thanks a ton i'll be back after reading that stuff. thanks again
Manish verma
Hello friends i did try using CTC mode but due to less information and examples i am unable to understand that without using any particular pin like OCP1 and OC1A ....i want to use any pin as input (as i have numbers of pin as an input. ) But in CTC mode i onlu understand that whenever interrupts occur on these pin OCP1 and OC1A/B it will genrate interrupt but i want if i press button on any pin like PORTA=1<<PINA1 then interrupt occur and receive data by another microcontroller.
Manish verma
Please help me with this code...
#include <avr/interrupt.h>
// initialize timer, interrupt and variable
void timer1_init()
    // set up timer with prescaler = 64 and CTC mode
    TCCR1B |= (1 << WGM12)|(1 << CS11)|(1 << CS10);
    // initialize counter
    TCNT1 = 0;
    // initialize compare value
    OCR1A = 24999;
    // enable compare interrupt
    TIMSK |= (1 << OCIE1A);
    // enable global interrupts
    sei();
// this ISR is fired whenever a match occurs
// hence, toggle led here itself..
ISR (TIMER1_COMPA_vect)
    // toggle led here
    PORTC ^= (1 << 0);
    // connect led to pin PC0
    DDRC |= (1 << 0);
    // initialize timer
    timer1_init();
    // loop forever
        // do nothing
        // whenever a match occurs, ISR is fired
        // toggle the led in the ISR itself
        // no need to keep track of any flag bits here
        // done!
i got this after searching over net.....now i want that if somehow i can modify this code as if button pressed interrupt call and that led toggle not on its own but after getting my button input
Manish verma
May I ask why you decide to use CTC for your button?
Your proteus schematics showed you use buttons, traffic leds and LCD. Have you succeded to integrate all that task but having trouble with the buttons or you don't know what you're doing at all?
When someone try to help you he should know how far you understand about the problem you're facing.
Please tell us your progress so far. Messing with code you found on the net won't suddenly solve your problem.
If you want to learn then learn it in the right way.
MG
hey friends i acheived what i wanted. Now i want to explain you what i've got and how it works.....i will make attach an document here and show you with schemtic diagram what did i acheive please let me know if i can improve more on that.
Manish verma
#define F_CPU 1000000UL                          //set at 1Mhz
#define DATA_PORT	    PORTB                //LCD DATA PORT
#define ThreePIN        PORTA                   //RS RW E PORT of LCD
#define RS              5
#define RW              6
#define E               7
#define MAX_vehicles    10                     //MAX value set used in logic formation
#define fix_time        8                       // MAX time set used in logic formation
#include<avr/io.h>
#include<util/delay.h>
#include<avr/lcd.h>                           //user made library for LCD
#include<avr/interrupt.h>
unsigned char counta=0,countb=0,countc=0,countd=0;
unsigned char gtim[]={6,6,6,6};                     // global variables
unsigned char ytim=2;
unsigned char finalvalue,val,val1;
unsigned char i=0,received_data;
char counta1=0,countb1=0,countc1=0,countd1=0,stop_A=0,stop_B=0,stop_C=0,stop_D=0;
void button(unsigned char val);
void display();
void cycle();
void logic();                                     // function declaration
void logicoccur();
void timeslicecycle();
void formula(unsigned char current_count, unsigned char i);
void decide_func(unsigned char val1);
ISR (TIMER1_COMPA_vect)    // Timer1 ISR in CTC mode
   if(PINA!=0x1f)
	 val=PINA;
	 button(val);                                   //passing button number
	  if((UCSRA&(1<<RXC)))                      // receiving using UART
	   received_data=UDR;
	   decide_func(received_data);             // passing received value
int main()
   DDRA=0xe0;                                       //PORT for button and lcd rs rw e
   PORTA=0x1f;
   DDRB=0xff;                                       //PORT for DATA PORT of lcd
   PORTB=0x00;
   DDRC=0xff;                                       //PORT for traffic lights
   PORTC=0x00;
   DDRD=0xfe;                                        //PORT for Traffic lights
   PORTD=0x01;
   TCCR1B |= (1 << WGM12)|(1 << CS11)|(1 << CS10);    // timers setting for CTC mode
   TCNT1 = 0;
   OCR1A = 2499;                                     // value to compare
   unsigned char UBRR_value=25;                     //UART with baud 2400 in 1MHz
   UBRRH=(unsigned)(UBRR_value>>8);
   UBRRL=(unsigned)UBRR_value;
   UCSRB = (1 << RXEN) | (1 << TXEN);              // Enabling RXEN and TXEN
   UCSRC = (1 << USBS) | (3 << UCSZ0);             //START bit, 8-bit register
   lcd_init();
   send_a_string("WELCOME");                      //this command will display "welcome" on lcd very first time
   _delay_ms(500);                               // delay of .5 sec
   send_a_command(0x01);                        // clearing lcd
   display();                                   //calling display function to display A,B,C,D values which is 0 in initial.
    sei();                                      //global interrupt enable
      cycle();                                 //this is the main cycle (endless) for traffic signals
void button(unsigned char val)               // this function we used to get the button number and take action according to desired input
   send_a_command(0x80);
   switch(val)
      case 0x1e:
	          counta++;                 // if this button pressed counta will increase
       send_a_command(0x82);                // and cursor moved to this point of LCD
       send_a_integer(counta, 3);           // and here we displaying the counta value with upto 3 places
     logicoccur();                          // calling another function to check if count is high i.e. greater than 7
      break;
      case 0x1d:
	          countb++;
       send_a_command(0x86);
       send_a_integer(countb, 3);
       logicoccur();
      break;
      case 0x1b:
	          countc++;
       send_a_command(0xc2);
       send_a_integer(countc, 3);                 // all same as above
      logicoccur();
      break;
      case 0x17:
	          countd++;
       send_a_command(0xc6);
       send_a_integer(countd, 3);
      logicoccur();
      break;
      case 0x0f:
	          display();
      break;
void logicoccur()
   if((counta>7)|(countb>7)|(countc>7)|(countd>7))           // here we check if any count is greater than 7
      logic();                                                // if yes then go to this function which is to know at which point count is high
void display()                                              //this is the function to display A,B,C,D values over lcd
       send_a_string("A=");
       send_a_string("B=");
       send_a_command(0xc0);
       send_a_string("C=");
       send_a_string("D=");
void logic()
    if(counta>7)
      send_a_string("count high at A");                       // if counta high then display this
	  while(!(UCSRA&(1<<UDRE)));                         // and send this data to another microcontroller
	  UDR=0;                                             //this the value stroed in  UDR and transmitted
      timeslicecycle();                                          // after transmitting go to another function which will be used
     }                                                        //to save the time from other signals
     if(countb>7)
      send_a_string("count high at B");
	  UDR=1;
      timeslicecycle();
     if(countc>7)
      send_a_string("count high at C");
	  UDR=2;                                          //same as above
      timeslicecycle();
     if(countd>7)
      send_a_string("count high at D");
	  UDR=3;
      timeslicecycle();
	   formula(counta,0);
	   formula(countb,1);                  // here we used this to pass value of counta, countb,c,d
	   formula(countc,2);
	   formula(countd,3);
  void formula(unsigned char current_count,unsigned char i)
     if((current_count==0)|(current_count==1))            //we used this if any count is 0 or 1 then
	gtim[i]=1;                                         //pass 1 to it and move on
     gtim[i]=((fix_time*current_count)/MAX_vehicles);       // if any count is greater than 0 or 1 then use this formula to calculate desired time to pass vehicles
     ytim=2;
void cycle()                                                //this is the cycle which is start from the very begining and never ends
    send_a_string("A");                                    // this dsiplay A on LCD at right most corner
    PORTC=1<<2;
   if(PORTC==1<<2)
    if(stop_A==0)
      PORTD=1<<3;
      PORTC=1<<6|1<<3|1<<2;                         // this is where 1 greeen and 3 red glows
      _delay_ms(gtim[0]*1000);                     // after calculating desired value of gtim the delay occurs
      PORTC=1<<6|1<<3|1<<1;                          //here 1 yellow and 3 red will glow
      PORTC=1<<5;
      counta=0;
     gtim[0]=6;
      PORTC=1<<5;
	  stop_A=0;
   send_a_string("B");
   if(PORTC==1<<5)
    if(stop_B==0)
      PORTD=1<<3;                         //same process
	  PORTD=1<<2;
      countb=0;
    gtim[1]=6;
	  PORTD=1<<2;
	  stop_B=0;
   send_a_string("C");
   if(PORTD==1<<2)
     if(stop_C==0)
      PORTD=1<<2|1<<3;
      PORTC=1<<0|1<<3;
      PORTD=1<<3;
      PORTD=1<<5;
      countc=0;
     gtim[2]=6;
	   PORTD=1<<5;
	   stop_C=0;
   send_a_string("D");
   if(PORTD==1<<5)
    if(stop_D==0)
      PORTD=1<<5;
      PORTD=1<<4;
       PORTD=1<<2;
      countd=0;
     gtim[3]=6;
     PORTD=1<<2;
	 stop_D=0;
 switch(val1)
 case 0: PORTD^=1<<6;
         stop_A=1;
 break;
 case 1: PORTD^=1<<6;                            // receive data will be compared and according to received data desired action taken i.e. glow led to show that
         stop_B=1;                             //count goes at high at this point.
 break;
 case 2: PORTD^=1<<7;
         stop_C=1;
 break;
 case 3: PORTD^=1<<7;
         stop_D=1;
 break;
Manish verma
It is unwise to post .docx on the internet - they could contain a virus. Anyway I risked it and all it contains is:
Communication between 2 microcontrollers using UART and Timer in CTC mode.
Here I am using two Atmega32 microcontrollers with two 16x2 LCD, 8 traffic lights, 4 LEDS, and 10 Buttons.
Connection made using wire labels in proteus.
Not sure why you need to put that in a .docx anyway?
Tells us absolutely nothing that isn't immediately obvious from the diagram!
Indeed!
ok my bad again. but there is no reason to say it again and again.
Manish verma
You've not told us how you want the system to operate. You seem to think we can read your mind and know exactly what you want. Once we understand how you want the system to operate, then we can begin to assist with the code. At the moment, your code is defective and looks like you wrote it before considering what you want the system to do.
1. Describe the system - you have pushbuttons and lights. What do they do? How do they operate? Draw a state diagram how you want the traffic lights to work. At this stage, do not think about implementation- ie coding. All you should describe is buttons,lights and sequences.
2. decompose the problem - what are the major operations you need to perform? Button debouncing, outputs to lights, timing etc.
3. abstraction - view the system as boxes. what do these boxes do and how do they interact? For each of your traffic lights - what do you want them to do? red,amber,green,flash? all off? Then you might have a box the controls the logic - this has inputs and outputs. define these and describe the operations.
Once you've got this far, the code basically writes itself.
ok kartman i'll try... give me 5 mins
Manish verma
Just to note that you may not be the first person in the world (with access to the internet) who has wanted to simulate a four way junction with traffic lights (and presumably "user present" buttons?) so you can probably google and find 10+ working solutions for this stuff to compare against.
give me 5 mins
You'll need more than that.
Don't skimp on the design phase.
Getting the design right should be the major part of the project; given a good design, it's the coding that should be just "5 mins" ...
clawson wrote:
Just to note that you may not be the first person in the world (with access to the internet) who has wanted to simulate a four way junction with traffic lights (and presumably "user present" buttons?) ...
I've lost track a bit here in the thread.  The original question(s) were USART and timers -- how to work with AVR peripheral subsystems.
Later in the thread, it seems to be more of the application.  In this case, traffic control.
Over 40 years ago, traffic signal control was always [ ;) at least IME] used for learning state machines.  If the more formal class, "Automata Theory".  It is a good exercise as the student can relate to the application.  And we didn't have any new-fangled "vehicle present" sensors back then, so I suppose it was easier.  ;)
Another typical/classic is passenger elevator operation.
I don't know how a post here, even extensive, can outline the content of a semester course in automata theory.  There are different ways of laying out the states, and formal and informal methods for optimization.
I think that's what Jim was getting at in #24 ?
Lee,
   PORTC=0x00;
   PORTD=0x01;
etc.
It seems he is trying to wire together 5 micros to operate these lights. Each set being operated by a separate micro and then they all "talk" on some kind of "network" (which may be MPCM) to let each other know what they are doing or be commanded what to do.
The skill of engineering is surely to analyse and simplify the thing whereas this seems to be a case of over-engineering to see just how complex I can make something that is actually trivially easy.
Only OP knows why he thinks there needs to be 5 micros in this.
Indeed.
Hence the old saying,
An Engineer is someone who can make for a penny what any fool could make for a pound
The clever bit is to make it as simple as possible - but not simpler.
The opposite of over-complication is over-simplification; where necessary details are omitted - usually the "corner cases"
It certainly does!
Probably due, largely, to the all-too-common failure to analyse  the problem before leaping in and throwing code and components at it.
clawson wrote:
It seems he is trying to wire together 5 micros to operate these lights ... Only OP knows why he thinks there needs to be 5 micros in this.
Are you mixing this thread up with his other one: http://www.avrfreaks.net/forum/m... - which mentions the 5 micros, but nothing about traffic lights ...
But, even so, I still don't see why this would require two micros ?
I am - oops blush
(EDIT: but that is the same poster? I thought this was all for a common goal?)
Are you guys out of your mind ? i mean really ?
Try to put some common sense. let me help you, if you saw that diagram you understand that there are 8 traffic signals which means i am doing that for 2 four way crossings i.e. 4 for 1 crossing.
4 traffic signals controlling 1 crossing and 4 for another crossing. 4 traffic signals controlled by 1 microcontroller which means I have the only option to control them is using 5 microcontrollers for 5 crossings.
And its really important for me to communicate with every microcontroller or you can say crossing to know the traffic status to control according to the current condition.
Hope this time i am clear about my needs.
Manish verma
I don't think you act right, they just tried to help you and look what you said to them...
promotional signature removed by moderator.
I am so pissed, i need their help thats why i am here. I am so new with this stuff , may be i am not familiar with those technical terms  and my communication skills are not that good but i am trying my best to explain them atleast try to understand my problem.
Manish verma
Okey, I can understand..
my conclusion so far:
the OP is a total noob in electronics and is self learning, so the internet is most likely the only source of education here.
He has found a freeware version of protheus somewhere that he is using for self education.
to the OP....
your schematic was copy past form 1 'block of lights+lcd' to the second. keep that in mind while writing the FW you want.
I personally think you have bit way more of than you can chew. So you need to take a massive step back and start with the basics.
That is not fun and will not give you a "show off" project in the short term, but you are already frustrated, and if you continue in this direction that will only grow and most likely beyond what you can handle to keep going.
start with the basics......
get 1 led to be on / off and flashing in the speed you want it to.
then extend that to a full trafic light, make that do what you want it to do ( get a flashing pattern on it for instance)
that will give you IO knowledge and can help you in getting timer knowledge.
Note that the LEDs can be used as debug source also once you got them going.
Then you might choose to get the LCD up and running to show some stuff there for indication
Then perhaps start doing a traffic situation were no buttons are required. So a Dump crossing, were there is a certian time a direction can drive.
Then make it smart by adding the buttons.
and last but not least start worring about how to have 2 intersections communicate with eachother.
Yep, when dealing with this stuff, you need to ve a little crazy. I'm quite sure most of us fully understand how traffic lights work, but it seems like you struggle as you've not adequately explained how you want your system to work. If we were standing next to you, we would get a pencil and paper to sketch out the operation then decompose and abstract the problem. Then we'd start with some code. We's start with one micro and get that working first before tackling multiple processors. Whilst the task appears simple, you're having trouble solving it, so that suggests it might not be as simple as it seems. The human brain has trouble solving multiple problems at once, so we need to divide the problem. That's why we have a design phase. Even with experience you go through a design phase even though it may not be on paper.
I already did what you said above.
1. I started with 4 leds and tried them to blink with expected delay.
2. then i used buttons for increasing counts.
3. then i used lcd to display my counts.
4. then i tried to do these things together. light blinks, lcd display while button press, with button number(i.e. which button is pressed if 1st button pressed then counta++,if 2nd button pressed countb++) .
5. then i tried controlling 4 traffic signals at once and implemented it with above progress.
6. then i used timers so i can receive button inputs in every ms so there is no interrupt in traffic signal cycle.
7.then i tried using uart to communicate between 2 micros.
8. after that i used it in above progress.
9. then my whole system works as i expected.
10. but now i want 5 micros to communicate but unfortunately something unexpected happens.(5th micro is communicating with 4 micros (i.e. transmiting and receiving) but 4 micros can't transmit data to       that 5th micro but they are receiving ......so you can say i almost acheived what i want, except this thing. just a single step behind my goal.
Manish verma
anyone here use whatsapp or email id ? if yes please share your details with me in personal.
Thank you
Manish verma
your code has defects and is the result of poor design. Why not revisit it and apply some structure to it. Then you might find modifying it is easier.
You've already tried spamming us with personal messages - that didn't get you far. Just put in the work and don't try to go the lazy way.
Or the result of failing to do any design - but, instead, just jumping straight in and throwing code about.
https://drive.google.com/file/d/...
just watch this video and please reply....i made this video to show you how it works.
thanks
Please don't get me wrong but seriously i need your help.....thats why i m troubling you ....i kindly apologise if any inconvinience caused by me.....and kartman i really didn't meant to spam you in private i don't know the rules of here...i was just trying to communicate with someone who can help.
Manish verma
Sorry, your video doesn't have hamsters or cats doing funny things, so why would I want to watch it?
Somehow I think you're being a bit disingenuous - on one hand you're telling us you are doing this for your own learning, but you don't seem too interested in learning.
We're trying to help you by leading you down a path where you can hopefully solve your own problems, but you seem none too interested.
ohk. let it be. thanks for your help.
Manish verma
...now i want 5 micros to communicate but unfortunately something unexpected happens.(5th micro is communicating with 4 micros (i.e. transmiting and receiving) but 4 micros can't transmit data to       that 5th micro but they are receiving...
Have we seen how you are connecting your 5 micros together?
5th microcontroller Rx and Tx connected to 4 micros Tx and Rx.
Manish verma
Ah, OK, so on your 4 'slaves' you have connected all 4 TX lines together and then connected that to the 'master' RX pin?
If so, have you read and understood what was said in posts #32, #35 and #43 in your other topic?
That probably won't happen.
The point with forums is that it is an open discussion where anyone interested can join the talk, and future readers can learn from the past experience of others,
Asking for one-on-one help via mail or similar will only make you come through as wanting special attention (or just looking spoiled). If you want that kind of help then then find someone who does that for a monetary return (i.e. you pay for it).
What's wrong with the forums?
Did someone call?
I'm not "selling". I only tried to explain the lay of the land.
