ATSAM4S TWI read
3 posts / 0 new
I have a problem with a ATSAM4S16C using the TWI interface.
I run always into a timeout when reading from the slave device. The slave and the addresses are correct (tested with an aduino).
I followed the instructions of the ASF tutorial for ATSAM4S TWI (common api), but maybe the instructions are not complete as &TWIM0 is unknown and I replaced it with TWI0.
What is the problem or what init step did it forget? My code is:
#include <asf.h>
void twi_init(void)
        twi_master_options_t opt = {
                .speed = 100000,
                .chip  = 0x28
        twi_master_setup(TWI0, &opt);
int main (void)
    /* Insert system clock initialization code here (sysclk_init()). */
    board_init();
     twi_init();
     twi_enable_master_mode(TWI0);
      uint8_t data_received[10];
         twi_package_t packet_read = {
               .addr         = 0x00,      // TWI slave memory address data
               .addr_length  = sizeof (uint8_t),    // TWI slave memory address data size
               .chip         = 0x28,      // TWI slave bus address
               .buffer       = data_received,        // transfer data destination buffer
             .length       = 10                    // transfer data size (bytes)
         // Perform a multi-byte read access then check the result.
         uint32_t status1 = twi_master_read(TWI0, &packet_read) ;
         if(status1 == TWI_SUCCESS){
               //Check read content
               if(data_received[0]==0xA0)
                LED_On( LED0_GPIO);
Have you checked the clock line with an oscilloscope?
I am having problems to configure the TWI of a SAMC21 with ASF and I can't see nothing on my SCK line.
If you solve the problem would be great if you post here, maybe I can use it too.
Regards!
FS.
Have you programmed the PIO controller to specify that whatever pins you are using for TWI should be configured as such?
