HOW CREAT Custom Large Font for 16x2 LCDs
19 posts / 0 new
HI
How can I display large words on a character's LCD 2*16
You can't. You would find like a lot easier with a small graphic LCD (ie pixel addressable)
All the LCD controller in a 2x16 allows for is the definition of eight 5x7 "custom" characters but that's not enough to define a whole large font.
(and no you can't define 8, draw those, define another 8, draw those and so on because as soon as you redefine the original displayed one will change too)
Look at how it is done on a Arduino.   You create some User-defined characters with suitable shapes.   And make a digit with these 8 user defined chars,  and any "blocky" characters from the built in Font.   Probably a choice of 10 suitable shapes.
You end up with some pretty ugly digits on a 20x4.   And no hope of creating any usable letters.
With a 16x2 there is even less opportunity to get attractive digits.
Buy a ST7920 display.   It will replace a 20x4 and give you attractive graphics.
Something like this perhaps:
http://www.cwlinux.com/products/...
That's actually 128x32. If you define 8x8 "normal" size character you would get 4 lines of 16 characters (8x8 is actually higher resolution than the 5x7 that a normal text 16x2 display uses). As the picture shows - because each dot can be set separately you can also do large font and graphics.
I WANT SIMILLARY PICTURE:
Don't attach the image: embed it - so that we can see it:
That, surely, is just what David described in #3 ?
EDIT
Instructions for embedding an image: http://www.avrfreaks.net/comment...
sky_man847 wrote:
I WANT SIMILLARY PICTURE:...
So, as Cliff said, you have the ability to make 8 custom characters. You will need to work out how they should look to make your chosen large characters.
So go to wherever you found that picture - and look at the code which goes with it!!
Or (as I just did), do a google image search on that picture - it gives plenty of examples ...
So why would you actually want that - when proper graphic LCDs are widely available ... ?!?!
We had a lengthy thread here just a few months ago, discussing this very "problem". Search it out.
Also: The image you've shown seems to come from here; http://www.instructables.com/id/... , and that looks like a tutorial with code and schematics. What more do you need?
If your goal is double-height characters, then look at the datasheet for the LCD.  It's as simple as sending an instruction to the LCD to display double-height characters.
If your goal is custom fonts, see above posts.
EDIT: added this:
Greg Muth
Portland, OR, US
Xplained Boards mostly
Which controller is that?  I see nothing like that in a representative HD44780 datasheet e.g. https://cdn-shop.adafruit.com/da...
Perhaps a good option for OP if the controller for his LCD supports it.
The Electronic Assembly DOG series.  Webpage.
Greg Muth
Portland, OR, US
??? But that ain't no 16x2 character LCD, is it?
Well, to be techincally correct there actually is a 16x2 text display in the DOG series that does offer double-height characters. The controller on it is a ST7036 which is "Instruction compatible to ST7066U and KS0066U and HD44780" but offers a superset o the 44780 functionality (e.g. the double-height is not supported by 44780/KS0066U). Data sheet: http://www.lcd-module.com/eng/pd... .
But yes, it is safest (and likely right) to assume that what the OP has is a 44780/KS0066U-based display and if so then Gregs "trick" won't work.
8x1, 16x2, 16x3, 10x4, 20x4, etc...  128x64 pixel-addressable.
Greg Muth
Portland, OR, US
very thank but i want for codevision avr...I want  starting to go up on lcd numbers{ 3 }[delay_ms(100);]then number{2} [delay_ms(100);] .then number{1} [delay_ms(100);]
If you have a regular 16x2 you can only do the blocky letters like in #6.
You can do it Codevision, GCC, Arduino, ... or any other language / platform.
Create the 8 building blocks. CV has an example that shows how to create a custom character.
Then put each "blocky recipe" into an array. And a printbigletter() function to display on your 16x2.
I suggest that you try it for yourself. If you have a problem, ask. We could do it all for you but you don't learn as well as when you try for yourself.
I always recommend designing your project on pencil and paper. e.g. draw each big letter with the special building blocks.
Good Luck.
Did you not read #8 and #9 ?
That includes tutorials and YouTube videos showing how to do it.
Or do you expect us to do it all for you, and just hand you a working project on a plate ?
The "Arduino Cookbook" has a section on making large digits on an 16x2 LCD screen.  It is section 11.7 Displaying Symbols Larger Than a Single Character that starts on page 349 of the book's downloadable PDF file.   These big digits are quite impressive.
However to get the chars with the rounded corners like those shown in your image, it would be best to make custom characters.
