Unable to properly program 324PAs but 324PBs work
35 posts / 0 new
So I have a custom PCB which was designed for the ATMega324PA that I'm trying to troubleshoot. When we populate the board with the 324PB chip, it is proogrammed and behaves properly. However, when we put in the 324PA, the programmer cannot verify the flash. It sometimes gets as far as address 0x1954 (which is 6484 out of ~11 000 bytes total) but will fail randomly along the Flash.
As far as I know, the only difference in the hook ups for the PA and the PB is the need for extra filtering capacitors on the two additional Vcc and GND lines. W have those capacitors, but the PB chips all work and the PA chips don't. Maybe this specific behavior is known and you guys can quickly tell me precisely how I am being an idiot tody. Or maybe not, in which case I guess we wait the 26 week lead time for 324PBs, because circuit boards are voodoo to me.
Thanks in advance!
If the 'PA are "virgin", then perhaps your ISP speed is borderline too fast?
I don't know if there is a migration app note for the 'PB.  I think there is a thread where the 'Freaks discussed the differences when it came out.
Are you using ISP, or an ICE, or ???
Using AVR Dragon with JTAG. The slider on the JTAG can't go any slower.
Dunno, then.  Still could be ratty signal lines, I guess.  Grab an ISP and try that?
I would like to know where the OP got their hands on Mega 324PB's.....
Unless they bought a lot of them.
JIm
EDIT:
Looks like Digikey has some:
https://www.digikey.com/product-...
I got some engineering samples about a year ago.
Curiously your link shows ERROR for availability.
The whole reason we hae to get this working with PAs is the PBs are impossible to get our hands on.
OK, new update. Our PA chips are programmable in ISP mode but not in JTAG. Thiss is a real bummer because you cannot program the chips in ISP on our current boards (and why would we supply it when we have the perfectly good JTAG interface?.........)
Jtag fuse not programmed?
That would be a neat trick, to get the JTAG to work partially with the JTAG fuse disabled.
The JTAG is enabled. I now have a minimal setup of a 324PA on a 44pin DIP breakout board. With nothing other than the breakout board being jumpered to the Dragon, and using the Dragon for power, I am able to program using the ISP interface but not the JTAG interface. A PB on the exact same breakout in the exact same breadboard with the exact same binary works with both.
WHY?!?!?!?!?!?!
and Mouser in QFN
http://www.avrfreaks.net/forum/mega324pb-tough-find-split-mega328pb-thread#comment-2237886
Yesterday's lead time report from microchipDIRECT states 17-Dec-2017 for QFP.
Edit : URL
The Dragon cannot power a target!
Use a proper power supply for your target and proper connections from teh dragon to the target JTAG.
JIm
Transparency - I do not operate an AVR Dragon.
AVR Dragon
Introducing AVR Dragon
Overview
http://www.atmel.com/webdoc/avrdragon/avrdragon.Overview.html
AVR Dragon is powered by the USB cable, and can also source an external target with up to 300mA (from the VCC connector, 5V) when programming or debugging. For more information on technical details, read the AVR Dragon Requirements section. If the target is already powered by an external power source, the AVR Dragon will adapt and level convert all signals between the target and the AVR Dragon.
Note
If the target board is powered by an external power source, no connection should be made between the VCC connector and the external board.
Was the board designed for a ATMega324PB chip? If so you will be missing about 4 power pins for the ATMega324PA version and it will not like it.
Since when can't the Dragon power a target when that target is a 20mA AT?
And I tried it with everything I owned that could produce 3-5 volts. None mattered.
No, it was designed for PA. As stated previously, I have those lines connected.
We have hacked the board to pieces to use SPI and that does work. The PB works with either.
Ok so as a matter of interest how long is the JTAG cable? Tools seem not to like anything longer than about 4-6inches (100-150mm)
On the chips that work, 2 feet. For my testing I used 3 inch duponts to connect the breakout to the Dragon. The 3 inch duponts didn't work.
Provided the USB port can actually handle 500ma...many do not.
If you search this site there are countless threads about dead dragons because of them being used(attempted to use) them as power sources.  It was a DUMB, STUPID, LAME idea from the vendor formerly known as Atmel to offer the idea of the Dragon being able to source the target.
THen take a step back and re-evaluate your entire setup.  Draw a schematic of everything...capacitors, resisters, inductors connections etc. and post it here for us to review.
JIm
Ok, so I would and did only use the Dragon power when I have a bare chip in order to reduce all sources of issues. Regardless, it's clearly not the problem so let's forget I mentioned it.
I can't give you the schematics for our proprietary board, but I'll upload a schematic of my test setup soon. It's literally just vcc and ground, plus filter caps, and the JTAG.
surprise I vaguely remember having a similar problem years ago, Atmel could not give me any answers. A short (~4") cable fixed things.
Ok, but if you read the line that you quoted you'd realize that doesn't really apply here. The ones that WORK work just fine with the long cable. The ones that won't work don't work with 3" connections.
Microchip Technology Inc
Microchip
AVR42769: Differences Between ATmega324 and ATmega324PB
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en591045
via http://www.microchip.com/wwwproducts/en/atmega324pb
Thanks! It really is a great chip, if you can get your hands on it.
But it is NOT a PA chip, I had the problem with a M164 (edited) chip, others worked OK, I used to have ~250mm leads before this happened.
That's all I can contribute.
And this was my email to Atmel 9/06/2007, the problem was with a M164
At 10:29 PM 8/06/2007, you wrote:
test the dragon by putting the device in STK500 and
connect the STK500 to dragon JTAG connector.
As I didn't have a JTAG connector on the STK500 I decided to
wire up the M164 to the Dragon's zif socket with the JTAG
connection and to my surprise it WORKED!!
I then went back to my board and stripped it down to the bare minimum
but nothing I would do would get it to work with the M164 even though
it works with the M32.
As a last resort I changed the JATG cable and all of a sudden it worked,
tried another cable and it work MOST of the times but not all the time.
So it seems that the LENGTH of the 10 way ribbon cable is causing all the
problems, the original cable is about 300mm and it works with the M32 with
both the Dragon and the JTAG MK1 but not with the M164.
The second cable that worked MOST of the times is about 200mm.
The cable that seems to work ALL the times is only 150mm.
So the first thing you would have to suggest anyone with a similar problem
is to use a shorter cable perhaps. :'(
I will post my findings on avrfreaks, hopefully someone will be spared the
pain and headache I have been going through for the past 2 weeks.
Thank you very much for your help.
Ok, and I'm not trying to sound ungrateful. But I thought I was clear that my shortest 3" leads didn't help.
EDIT: 3" is ~75mm
So, I might suggest you try with some current version chips.
I still recall some subtle differences with some pre-release XmegaE5 series chips.
An issue or two, (one of which involved the PDI programming interface, as a matter of fact), suddenly disappeared when using the production model chips a version or two post-release.
from the current datasheet :
(page 437)
37. Errata
37.1  Rev.A-H
Rev. A to H are not sampled.
37.2  Rev. I
Sampled. Not released in production.
37.3  Rev. J - K
(PTC malfunction when enter sleep mode)
An assumption is rev I is on the mega324PB Xplained Pro.
Well, the engineering samples are the ones that are working. The PAs are real production chips from I wanna say Mouser.
OK I have a schematic of my test setup in which I can program a 324PB but not the 324PA. There's some contention in the office over whether or not the 644PAs work, because we only tried one, before we had any idea of what was happening.
"All caps 100pf"; assume that's a typo and should be 100nF.
Should be a bulk cap for mega324PB VCC (pin 5)
mega324PB pin 17 is SPI1 / UART2 / PTC
mega324PB pin 18 is SPI1 / UART2 / PTC
mega324PB pin 38 is SDA1
mega324PB pin 39 is SCL1
(dual pin 22 in picture) mega324PB pin 22 is JTAG TMS
mega324PB pin 24 is JTAG TDI
Did not compare mega324PA and mega324PB pinouts; should there be separate schematics?
Damn, you got me. I typo'd those two. The PB is backward compatible with the PA. In the PA those lines are additional Vcc's and Grounds.
Alright, I feel that I have to reply to this with the resolution. Turns out when I said 4" leads, we were actually using 6" leads. (My boss and i have differing definitions of "the short leads" apparently) I tried it with the 4" leads, and IT WORKS. IT WORKS! And I remember what oxygen tastes like.
Thanks for your general help and specific guidance, as applicable. I made the tiniest JTAG ribbon cable I could manage and have been programming them like mad.
I'm also going to buy those 324PBs and get new boards designed for both chip sizes.
Well done!
DragonLair has series termination of 100R (better impedance match)
http://www.aplomb.nl/TechStuff/Dragon/Dragon.html (after mid-page for the schematic)
or local : http://www.avrfreaks.net/sites/default/files/DragonLair.sch.png
Same except for XMEGA PDI :
http://www.avrfreaks.net/forum/dragon-and-xmega32e5-difficulties-solved
https://oshpark.com/shared_projects (Dragon has 6 hits)
hmmm maybe someone should have told you this 3 days ago. wink
Hmmm, something sounds very marginal there. I'd still be looking for a problem if such a small change makes such a big difference.
[Yes, I know that 6" down to 4" is a 33% decrease but in real terms that's a drop of just 2.5pF, 25nH and 0.25ns.]
In the Dragon or the chips not on our boards, the same problem occurred more than 10 years ago with chips of the same family and the Dragon, other problems were also experienced with other programming mode like PDI from memory.
As I said before: Dragons are wimps. wink
