"mystdout" FILE declaration returning error
17 posts / 0 new
Dear freaks
I was trying to implement printf function in my uart code to make it more easy.I write code in modular style.But the problem is whenever i am declaring the buffer for printf (i.e mystdout in my case) in a uart.h header file and using extern in the main file,it is returning error that "multiple definition of mystdout".
But
Whenever i am declaring mystdout within the main.c file,the code is working properly.What is getting wrong?
Please take a look at the non working code below...
uart.h
#ifndef UART_H
#define UART_H
#include <avr/interrupt.h>
#include <stdio.h>
void uart_init(void);
void uart_send(unsigned char data);
void uart_sendstring(char*str);
int uart_putchar(char c, FILE *stream);
FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL,_FDEV_SETUP_WRITE);
#endif
uart.c
#include "uart.h"
volatile uint8_t rcv_flag;
volatile uint8_t uart_data;
UCSR0B = (1<<TXEN0)|(1<<RXEN0);
UCSR0C = (1<<UCSZ01)|(1<<UCSZ00);
UBRR0L = 0x67;//UBRRL is 0x67 for 9600 baud @ 16Mhz crystal
UCSR0B |=(1<<RXCIE0);//receive interrupt enable
while(!(UCSR0A & (1<<UDRE0)));
UDR0 = data;
unsigned char a = 0;
while(str[a] != 0)
uart_send(str[a]);
a++;
ISR (USART_RX_vect)
rcv_flag=1;
uart_data=UDR0;
int uart_putchar(char data, FILE *stream)
	UDR0 = data;
	return 0;
main.c
#include <util/delay.h>
#include <stdio.h>
#include "uart.h"
extern FILE mystdout;
    uart_init();
	stdout = &mystdout;
	int data = 100;
	while (1)
	printf("Test success %d\r\n",data);
	_delay_ms(1000);
error screenshot
Go on. Remove the mystdout assignment from usart.h
Put it as a global in main.c
Alternatively put it in usart.c
Never in an H file.
SHARANYADAS wrote:
whenever i am declaring (sic) the buffer for printf (i.e mystdout in my case) in a uart.h header
you are not declaring it - you are defining it!
So, obviously, if you #include it in more than one file you will get more than one definition - ie, multiple definitions
is totally the wrong way around!
The extern is the declaration - and that should go in the header.
http://c-faq.com/decl/decldef.html
http://www.avrfreaks.net/forum/tut-modularizing-c-code-managing-large-projects
SHARANYADAS wrote:
uart.h
FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL,_FDEV_SETUP_WRITE); // this is a DEFINITION!!
uart.c
#include "uart.h" // So this gives you a DEFINITION here
main.c
#include "uart.h" // and this gives you *another* DEFINITION here
So, clearly, you have multiple definitions!
EDIT
Note that your screenshot shows that AS actually tells you where the two definitions are - one in main.o (the result of compiling main.c), and the other in uart.o (the result of compiling uart.c),
That would be my suggestion. It's really "internal" to the UART operation. So simply:
#ifndef UART_H
#define UART_H
#include <stdio.h>
extern volatile uint8_t rcv_flag;
extern volatile uint8_t uart_data;
#endif
#include "uart.h"
    UCSR0B = (1 << TXEN0) | (1 << RXEN0);
    UCSR0C = (1 << UCSZ01) | (1 << UCSZ00);
    UCSR0B |= (1 << RXCIE0);//receive interrupt enable
    stdout = &mystdout;
    UDR0 = data;
    // dropping 'a' from this means you are not limited
    // to 256 character strings
    while(*str)
        uart_send(*str++);
ISR (USART_RX_vect)
    rcv_flag = 1;
    uart_data = UDR0;
    while(!(UCSR0A & (1 << UDRE0)));
    UDR0 = data;
    return 0;
#include <stdio.h>
#include "uart.h"
    uart_init();
    int data = 100;
    while (1)
        _delay_ms(1000);
Thanks a lot guys for your time.Now my problem is resolved.
If you need it in the uart module, you can
static int uart_fputc (char c, FILE *stream)
  (void) stream;
  uart_putchar (c);
  return 0;
static void __attribute__ ((__constructor__,__used__))
uart_init_stdout (void)
  static FILE mystdout
    = FDEV_SETUP_STREAM (uart_fputc, NULL, _FDEV_SETUP_WRITE);
  stdout = &mystdout;
Is the use of the constructor attribute assuming C++ rather than C and, if it is, does this mean uart_init_stdout() does not need to be called directly because it's called as a c'tor?
The constructor attribute works in C too.
  Yes.
Stefan Ernst
You can have c'tor in C? Oh wow, you could write some really obfuscated code where the path of execution was quite tricky to follow! cheeky
Thanks guys, that definitely counts as today's "learn something new every day" for me.
+1!
I would like to think of it as there being a difference between a "constructor" (does not apply to C) and a "function having the __constructor__ attribute" (if applied in C actually should be read as "call this on system startup"). Perhaps I'm being to philosophical?
Also learned that there's __constructor(4)__ where 4 sets the priority/execution order.
Similarly __destructor__ (also optional (N) variant) to run functions after exit from main().
The cleanup attribute on a variable could also prove fun for "unexpected" execution flow.
Oh, great. More obfuscated code flow!
Used by atomic.h.
"Read a lot.  Write a lot."
You know that thing you do with c'tor then d'tor in a C++ class to time code in a statement block? You could almost do the same in C with cleanup - interesting. Not sure how this passed me by, I guess I never studied atomic.h in sufficient detail.
C constructors are handled at the same stage as C++ static constructors, same for destructors (there is attribute destructor) and static destructors.
avr-gcc doesn't support init priority, so avr-gcc will throw a warning at constructor(prio). There is a PR to support that, but IIRC it needs Binutils support like extension of linker script.
avr tools run static constructors at .init6, i.e. after .init4 which clears .bss and inits .data. The bit of startup-code that runs static constructors/destructors is __do_global_ctors/dtors, and the respective addresses reside in .ctors/.dtors.
I'd like to create a "sidetrack" for that (i.e. new thread): http://www.avrfreaks.net/forum/t...
