How to get -5V for operational amplifier
14 posts / 0 new
Hi !
I need -5V for 6 OPA to measure 6 analog channels.
Till now I was getting -5V form DC/DC converter ISA0505.
It's space consuming and expensive solution.
Now I'm trying to use TPS62160 but I have some issues with it and I'm waiting for response form TI.
So, what can you suggest me to achieve -5V ?
Thank you !
Regards !
What current do you require?
You have two main choices - charge pump or inverting boost converter.
Or a Max232
Another charge pump ic is the NCP1729 Switched Capacitor Voltage Inverter.
Thank you for suggestions !
I suppose I need currents up to few teens of mA.
OP-a don't require many mA or do they?
I've found TPS6400 and it looks simple
Do you need -5V?
Perhaps make 2.5 as 0 for the opamp, so 0=-2.5 and 5V =2.5
valusoft wrote:
Or a Max232
;)  That was my old-school idea as well.  Back when I was OP's age, many/most micro apps had an RS232 link and a modest supply of -10V came "for free".  Not nearly as common nowadays.
It'll be pretty noisy, though ?
???  The -10V?  Dunno. We've used it in past apps for getting op amps down to the low rail.
Another way we would get a V- rail would be to create an oscillator with an NE555 or even an op-amp and feed a rectifier circuit.
As Sparrow mentions you could bias the opamp at half the Vs.  Make sure you use Rail to Rail opamps for best accuracy
Surely you can use a purpose made chip if you really need tens of mA.
I suspect you only need a few mA. In which case you can use an AVR Timer for a charge-pump. You save an i.c. but still have external capacitors and diodes
Brilliant!
JIm
I've done the same to achieve the +12V needed for an HVSP programmer.  At first I fiddled with software regulation via the ADC, then via the AC.  In the end I decided to regulate with a 78L12.
You'll likely need fairly 'clean' power for the opamp, so a 79L05 or similar is probably the best bet.  Might make due with a zener.  However chances are something like the NCP1729 will end up having a smaller footprint and a lower BOM anyway.
"Read a lot.  Write a lot."
Op, what is the *actual* signal range your opamp needs to accomodate? If you are only driving the avr adc, you may only need a small amount of v-, or perhaps none at all.
Tom Pappano
Tulsa, Oklahoma
