xmega128a1u stackoverflow or what?[solved]
44 posts / 0 new
I have a pretty large code and sometimes my code jump to first line main.c and  SRAM is empty at that moment but all ports and periphery  are still configured. The optimization seems help, but the problem occurs in any time, it could work for days without problem or the problem could appear after 10 minutes. I tried to change size of the buffers but it seems its not helping.
How to find that bug?
UPDATE: I've found my bug, it wasn't a bug actually. I made a lot of changes for code optimization and it seems now I don't have stackoverflow.
the problem was that I have 6 spi devices, 2 gprs modules, several sensors, external flash memory, USB-cdc, so xmega stack was overloaded when I was getting too much data. So I don't know now what is the better option for me: moving form xmega to more powerful mcu or leave it on xmega and  hope for the best.
Thank you guys for your help, especially
1. Very powerful thing for monitoring stack  (Thanks mojo-chan ) here http://www.avrfreaks.net/forum/s...
2. Also thanks  gchapman for idea about static code analysis  Cppcheck found some bad moves. And I've never used data breakpoints before, with the canary algorithm it helped me a lot
You can monitor stack usage fairly easily. Just create code in .init that paints all unused RAM with a canary value and then periodically check what the lowest address between the top of RAM and the end of BSS is with that value.
However, this kind of reset can be caused by other things. A bad interrupt, corrupting the PC somehow, corrupting EIND causing a jump to unused flash and a wrap around to address 0 again, that sort of thing.
Again, you can try to diagnose it by putting some code in a .init section. For example you could try to dump some diagnostic data such as the stack pointer and upper few kilobytes of stack/RAM to try to determine where you came from.
Thank you, good ideas!
Hello SirLancevrot,
Check the "Cause of Reset" at the very beginning of your main.
Here is a link to Atmel Software Framework-based implementation/wrapper of it: http://asf.atmel.com/docs/latest/common.services.wtk.example2.xmega_a3bu_xplained/html/group__xmega__reset__cause__group.html
If you are not using ASF for some reason - it is still possible to get the reason of reset - check how ASF does it (which register do they check).
It should narrow down a list of reset sources you might be experiencing.
Let us know the outcome.
Regards
Most firmware's use a ms timer tick.
You can easily modify all interrupts to make a copy of that ms timer tick every time they fire and save it to the  .noinit section.
That will keep an up to date record of the last interrupt fired and you can dump those values after a reset.
For better resolution also read & save the timer register itself.
Or use a circular buffer for the last couple of 100's interrupts, but that's probably overkill.
I would probably go the route of lint & static code analysis.
It's often a runaway pointer.
The "const" keyword is your friend. (But a bit of a nuicanse to add everywhere to existing firmware).
Paul van der Hoeven.
http://www.hoevendesign.com
Could you elaborate on that?
Almost invariably, if changing the optimisation setting breaks the code, it means there is a flaw in the code - the code is relying upon or assuming something that it shouldn't.
Ah - intermittent problems are always the worst!
As the others have said, you need to instrument your code to get some insight into what's happening.
Also, log stuff that's available externally.
Can you send stuff to a serial port?
This will likely be an iterative process: start with the stack monitor and reset reason; possibly also the Event Log.
See what you can glean from these, and add further stuff as required.
I would definitely start with the circular buffer - as you don't know how long it's going to run before the symptoms present
0Pal wrote:
Hello SirLancevrot,
Regards
No, it defensively is not reset, because ports and periphery devices such as SPI for example are still configured
SirLancevrot wrote:
SRAM is empty
What do you mean by that?
I mean that all my variables are empty or they have their initialization values
They can't be empty - they must have some value!
But it sounds like you're saying that the 'C' runtime startup code has run - or, at least, the bit that initialises variables.
Can you leave a system (or some systems) running with the debugger attached, and a breakpoint set at the start of main() ... ?
What about all the other suggestions of instrumentation, logging, and static analysis?
If you do as I suggested and create some .init code, say in .init1, you can create a breakpoint immediately after the problem happens. You can also do it by using the disassembly view to set a breakpoint on the reset vector.
You don't have an exit from main() - do you ... ?
Paulvdh wrote:
I would probably go the route of lint ...
and assert
The Ganssle Group logo
The Ganssle Group
Automatically Debugging Firmware
by Jack Ganssle
May 2014
http://www.ganssle.com/dbc.htm
(next to last section)
Side Effects
... (you do use Lint, don't you? It's an essential part of any development environment) ...
There's a zero price lint in Microsoft Visual Studio Community.
Microsoft
MSDN
/analyze (Code Analysis)
https://msdn.microsoft.com/en-us/library/ms173498.aspx
Microsoft
Visual Studio
Compare
https://www.visualstudio.com/vs/compare/
(expand Advanced Debugging and Diagnostics)
My code  looks like
int main (void)
{                   //my code jumps here and all variables look like it was reset,
 <----                   //but xmega is already configured: CLK, USB, Timers, UARTs, SPIs, I2C, ADC, all are configured
    setup();
        func1();
        func2();
ISR()
ISR()
ISR()
Yes, i'm waiting for that bug right now, and i'll put disassembler here
SirLancevrot wrote:
int main (void)
So, as previously stated, it sounds like your code is actually jumping to somewhere earlier than that - so that it does the 'C' startup RAM initialisation stuff
eg, the Reset vector ... ?
I've got this
I'm not good in assembler, so maybe somebody could find somthing
I also put a trap, if it would be reset PORTA.DIR must be 0
    while (PORTA.DIR==0xC0)
        {LED_BLUE_ON;}
It sounds like your code is vectoring to address 0x0000 rather than the MCU being reset.  Does every enabled interrupt have an ISR defined?  If not, undefined ISRs cause a vector to 0x0000.
Greg Muth
Portland, OR, US
This looks a bit unusual:
while (PORTA.DIR == 0xC0)
    {LED_BLUE_ON;}
What is changing the value of PORTA.DIR while this loop is looping?
Greg Muth
Portland, OR, US
His theory is, I think, that after a proper (hardware) reset, PORTA.DIR would be zero; so, if it starts main and is non-zero, the problem (or its symptom) has occurred.
But dunno why he'd check for the specific value of 0xC0 - rather than just non-zero ?
Yes you're are absolutely right, the 0xC0 is value what it has to be after setup
PORTA.DIR!=0 is the same
Well, clearly not the same!
As you have "strange" behaviour anyhow, I'd think it best to just check for non-zero - not rely on just one non-zero value.
After all, if you catch it with a non-zero value other than 0xC0, you have gained an extra bit of information - haven't you?
Yes, in any case, thank you all, now I have some new ideas.
I'll write and update post when I find a solution
yes
Might be possible to test the SP in the function prologue (test frame extent, create stack frame, call)
https://gcc.gnu.org/onlinedocs/gcc-7.2.0/gcc/AVR-Options.html#AVR-Options
-mcall-prologues
Functions prologues/epilogues are expanded as calls to appropriate subroutines. Code size is smaller.
https://gcc.gnu.org/wiki/avr-gcc?highlight=%28prologue%29#Frame_Layout
Indeed via a hardware debugger and XMEGA's two data breakpoints.
There can be a case of dis-continuous stack frames such that two data breakpoints would not be enough.
AVR simulator can have unlimited breakpoints but would need to stub I/O functions; those functions could be a source of the issue(s).
Atmel Studio
Stack Overflow Detection Using Data Breakpoint
http://www.atmel.com/webdoc/GUID-ECD8A826-B1DA-44FC-BE0B-5A53418A47BD/index.html?GUID-A4FC8DB5-6B28-4893-93BA-7A4406698E5D
Atmel Studio
General Information on Data Breakpoint
http://www.atmel.com/webdoc/GUID-ECD8A826-B1DA-44FC-BE0B-5A53418A47BD/index.html?GUID-CC67F575-4C06-4BD1-B5BF-44ED2142C215
(table)
Maximum Data breakpoint supported
Simulator
Using Simulator in Atmel Studio
Using the Simulator in a Debugging Session
http://www.atmel.com/webdoc/simulator/simulator.section.bld_gud_lc.html
  • Unlimited numbers of breakpoints regardless of device and OCD system limitations.
Thank you all who commented this post. I've updated the top message
SirLancevrot wrote:
... moving form xmega to more powerful mcu ...
Choices ... choices wink
SirLancevrot wrote:
... or leave it on xmega and  hope for the best.
No need to hope.
XMEGA128A1U is a follow-on to mega1280; both have only 8KB of local RAM and an EBI (64KB for mega, 16MB for XMEGA)
64KB of external RAM can be attached via ports H and J.
XMEGA Xplained Pro has 512KB of RAM.
Stack can roll into or out of external RAM though it's not ideal for throughput; some AVR C compilers will have two stacks (AVR GCC is one stack)
XMEGA may be why it was selected due to
several sensors
XMEGA C has reduced analog performance than XMEGA A but XMEGA384C3 has 32KB of internal RAM.
A CPLD can be attached to an XMEGA to add I/O.
SirLancevrot wrote:
... about static code analysis  Cppcheck found some bad moves.
lint (cppcheck) is not much of a static analyzer.
lint plus C assert goes a long way for zero price; the cost is slightly more program space and lines of source code, and a slight increase in execution time.
PC-lint is commonly operated and about an order of magnitude less expensive than a full static analyzer.
C and C++ static analyzers can be effective once one learns how to operate it; the demand for C and C++ static analysis has lead to the creation of several analyzers (choices wink
A limited form of static analysis is stack usage analysis.
AVR1312: Using the XMEGA External Bus Interface
http://ww1.microchip.com/downloads/en/AppNotes/doc8058.pdf
via http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en592037
and http://www.microchip.com/wwwproducts/en/atxmega128a1u
http://www.atmel.com/products/microcontrollers/avr/avr_xmega.aspx?tab=documents
(pull-down menu, Application Notes)
(file size: 133875, 10 pages, revision A, updated: 06/2010)
(Software updated 09/2015. File size: 760KB)
This application note describes the basic functionality of the XMEGA EBI with code examples to get up and running quickly. A driver interface written in C is included as well.
(AVR1312.zip is missing)
http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=ATXMEGAA1U-XPRO
http://www.microchip.com/wwwproducts/en/atxmega384c3
Gimpel Software
Gimpel Software
http://www.gimpel.com/html/index.htm
It [PC-lint] will thoroughly check your C/C++ source code for bugs, glitches, inconsistencies, non-portable constructs, and much more,  so you can find and fix your bugs more quickly, and more economically, than with traditional debugging procedures
GNATstack User's Guide
http://libre.adacore.com/developers/documentation-single/gnatstack-users-guide
https://gallery.atmel.com/?q=stack&orderBy=undefined&SelectedCategoryId=undefined
Edit : attempt at AVR1312.zip (source code)
SirLancevrot wrote:
1. Very powerful thing for monitoring stack  (Thanks mojo-chan ) here http://www.avrfreaks.net/node/33...
Access denied
You are not authorized to access this page.
gchapman wrote:
Access denied
My bad here the link http://www.avrfreaks.net/forum/s...
also there are no any stack extensions for AS 7, but i found code analyzer  for AS 6 https://gallery.atmel.com/Produc... (it was deleted but I think there is a copy somewhere on the Internet)
None of this thread makes any sense to me. I guess it might be because #1 has been edited? It says
why would the STACK be "overloaded" with data? Are you saying that all your Rx buffers are stack frame autos? Why would you write code like that? Why not buffers in BSS?
Maybe i'm wrong but let me explain my theory
I had a lot of fucntions which were called in while (1) and also I have a lot of UARTS, timer etc interrupts, so my stack was running low very fast. (at least canary algorithm showed to me that )
I've moved some functions from "always call" part, also I've realeased some SRAM, now it seems my resets are gone.
All my buffers are in BSS, It seems the problem was in a large amount of calls and interrupts
But now I've got new problem some of my variables is changing their value, but most of my vars are packed in structure together
If someone interested I could post whole my code here
Sorry are you the same person who started this thread?
So were all your buffers previously stack frame automatics?
sorry, I have to usernames it's a long story about my work and home computers
I can't get what does it means 'stack frame automatics'  my buffers is regular arrays and pointers
like uin8_t buffer[100];
or a structure with pionter
 volatile uint16_t lora1_fifo_data[LORA_B_SIZE][2];
fifo_t fifo_lora_buf1 ={
    .data = &lora1_fifo_data,
    .max_size = LORA_B_SIZE,
    .start_cell=5121,
    .end_cell=10240,
"automatics" are non-static local variables.
https://en.wikipedia.org/wiki/Automatic_variable
Almost all 'C' compilers implement these on the stack.
So having large local buffers (arrays) is generally a great way to blow your stack!
no I almost do not have any local buffers, the biggest buffers are global
Possibly still a stack overflow.
Stack overflow overwrites static data
from
EmbeddedGurus
Are We Shooting Ourselves in the Foot with Stack Overflow?
Monday, February 17th, 2014
by Miro Samek
https://embeddedgurus.com/state-space/2014/02/are-we-shooting-ourselves-in-the-foot-with-stack-overflow/
A Shot in the Foot
A Smarter Way
How to Change the Default Order of Sections in RAM
But, may be an effect of the change in optimization.
Edit : But
Then I still don't understand why you thought this has anything to do with stack growth. Unless you use recursion it is VERY difficult to fill the stack with just the PUSH's and CALL return addresses of normal function nesting - you would need to be getting hundreds of function calls deep to get anywhere near risk using the stack UNLESS each such function was using large amounts of automatics - hence my question.
@SirLancevrot: As Cliff suggests, it is really unhelpful & confusing to change the opening post - especially when people have already replied to it!
Instead, post updates as replies - so that the flow of the discussion is maintained.
Also, note that there is a 'Mark Solution' button on each reply to identify where & when a problem has been solved
How would that give you stack overflow?
Having a lot of functions in a while(1) loop does not, in itself, cause a lot of stack usage: each function is called, then returns, before the next function in the loop can be called - so there is no "nesting" of function calls just because of the loop.
What does that mean??
My point entirely. Sure if you have:
void function10() {
void function9() {
    function10();
void function8() {
    function9();
void function7() {
    function8();
void function6() {
    function7();
void function5() {
    function6();
void function4() {
    function5();
void function3() {
    function4();
void function2() {
    function3();
void function1() {
    function2();
int main(void) {
    while(1) {
        function1();
Then by the time you reach function10() the stack contains nine return addresses (18 bytes). But if you are really talking about:
void function10() {
void function9() {
void function8() {
void function7() {
void function6() {
void function5() {
void function4() {
void function3() {
void function2() {
void function1() {
int main(void) {
    while(1) {
        function1();
        function2();
        function3();
        function4();
        function5();
        function6();
        function7();
        function8();
        function9();
        function10();
there is never more than one address on the stack - so it only ever uses 2 bytes of stack space.
You are using a micro that has 8192 bytes of RAM!
It's true that if the code is really:
void function10() {
    char buff[40]
void function9() {
    int bigArray[140];
    function10();
void function8() {
    long longArray[30];
    function9();
etc.
Then because those variables are all stack frame automatics (they are created on the stack as the function is entered and removed when it leaves - hence "automatic" creation/deletion) the size of all of them would add up and add significantly to the overhead for RETurn addresses alone. But that's the only way to eat large chunks of stack space - you would either need both heavily nested functions each with moderately sized automatics. Or you would need just a few levels of nesting and some really huge automatics to get anywhere near using the whole 8K. Of course you could do it with:
void fuction() {
    char oneBigVar[8150];
int main(void) {
    function();
But doing that kind of thing on an 8K micro is never a good plan !
Hi guys,
tiny update: I've resolved all my problems with memory.
1. I found large local buffer (I didn't know that local buffers are located in the stack)
2.  My code is full of nested functions
3. I thought if Atmel Studio shows me  Data Memory Usage  :    7590 bytes   92,6 % Full It means that the everything is fine and we have enough memory for normal work.
Thank you again guys
Again, it's automatics that are located on the stack; not all locals are automatic.
EDIT
See #35
93% is scary full.
Recommendations :
  • stack high watermark dynamic test to obtain a warm fuzzy
  • static stack analysis to measure worst case stack usage
May be time to evaluate a 192KB or 256KB XMEGA AU as these have 16KB of local RAM; if that's a no go then shoehorn a 32KB SRAM via EBI onto the PCBA.
