Debug / Release Strange Timer behaviour
13 posts / 0 new
I just realised that my debug / release options can generate different F_CPU frequency and I dont know why is that.
For programming my device I am using USBASP 2.0
For Debug I am using:
-c usbasp -p atmega8 -U flash:w:$(ProjectDir)Debug\$(TargetName).hex:i
and for Release:
-c usbasp -p atmega8 -U flash:w:$(ProjectDir)Release\$(TargetName).hex:i
Recently I changed my F_CPU frequency via ExtremeBurner and realised that on Debug frequency  of _ms_delay() is too high (LED blinks too fast)
while on release it is fine...
My other concern connected to these 2 functions is that with big chunks of code (a lot libs included etc) sometimes Debug wasnt writing code to the device, while release was.
I suppose it is connected to the optimalization as debug option propably didnt do opt for space and just couldnt 'fit'.
However I thought for optimalization were responsible 2 functions placed here (atmel studio 7)
As you can see here it is stated however I have no idea how these AVRdude declarations are corresponding with it as they seem to be completly different set of tools...
As I am quite fresh to AVR programming could someone put some light on this please?
Chris
Chris_Irathil wrote:
that on Debug frequency of _ms_delay() is too high (LED blinks too fast) while on release it is fine...
But the rate of flashing is determined at the time you COMPILE the code, not when you program it. So if Debug/Release differ then it suggests that F_CPU was defined differently in the two. So show the code and the way in which F_CPU is being defined for both Debug and Release.
There is no point in using separate USBASP_Debug and USBASP_Release.
Just configure your external Tools "Arguments" as:
-c usbasp -p ATmega8 -e -U flash:w:$(TargetName).hex:i -U eeprom:w:$(TargetName).eep:i
and "Initial Directory" as:
$(TargetDir)
I would avoid "Extreme Burner" like the Plague.    Or at least use it very carefully.
Thank you Clawson for response,
I couldn't find definitions of F_CPU for these tools
here is the code:
#ifndef F_CPU
#define F_CPU 8000000UL // 8 MHz clock speed
#endif
#include <util/delay.h>
//TESTING PROGRAM FOR AVR AND CLOCK FREQUENCY(delay)
	DDRC = 0xFF; //Makes PORTC as Output
	PORTC= 0xFF; //Turns PORTC to HIGH state
	while(1) //infinite loop
		PORTC = 0xFF; //Turns ON All LEDs
		_delay_ms(1000); //1 second delay
		PORTC= 0x00; //Turns OFF All LEDs
	return 0;
apparently as I turned on AVR and tested is everything was fine, so to again I changed F_CPU via extreme burner to 8 Mhz (4 previously).
After Build -> Debug works correcly. However releasing this pasted code effects in LED blinking in 2x frequency it is supposed to.
PS: even if it was compiled and debugged and is working correcly, pressing release makes led blink twice as fast as it is supposed to.
Chris
Just out of interest, why is that?
Thank you David,
After changing again Frequecny (well... I had  to test it somehow -,-' ), building and using your commands to build/release it worked properly!
Could you bring closer the topic of avoiding Extreme Burner?
Also which of these 2 modes is more recommended to use?
So many questions in such simple matter!
Chris
See: http://www.avrfreaks.net/forum/m...
#ifndef F_CPU
#endif
Don't do it that way. If it is already defined (by a -D) then you could have a different result from what you intend. If you KNOW it is 8MHz then change those lines to be:
#undef F_CPU
That way it won't matter what it might defined as when it reaches this line (-D) - this will always set it to 8MHz, over-riding any previous setting.
clawson wrote:
#ifndef F_CPU
#endif
Agreed.
I guess whoever did that was trying to be "helpful" (sic) by providing a default.
Trouble is, in most cases, it's the wrong value - so it actually hinders and does not help at all.
It would have been far more helpful to have something like
#ifndef F_CPU
#error "F_CPU must be defined - see xyz for details"
#endif
Oh don't get me started! <util/delay.h> itself has an #ifndef F_CPU but instead of throwing such an error to say "this ain't gonna work unless you define F_CPU" what it actually (stupidly!) does is just define it to an arbitrary 1MHz anyway.
Thank you guys that was very useful!
Also could you leave some comment about Extreme Burner, as I am still confused about
So perhaps there are better ways of changiong fuses ?
You're using Atmel Studio - can't you just do it straight from there?
He said USBAsp so not exactly "straight" from there. But he can follow the usual advice about setting up an "external tool" to invoke avrdude and that would work.
