music player help
14 posts / 0 new
I am new here. I am using ATMEL STUDIO 7.0 and using an ATMEGA 1284. I am following the tutorial from http://aquaticus.info/pwm-music. When I load their code onto the ATMEGA 1284
the buzzer just make a lot of
fast tapping noises. I have tried fixing the code by trying out the recommendations from one of the people that commented which is pasted below. It was still a bunch of tapping with some delay. What can I do to fix this?
void PlayMusic( const int* pMusicNotes /** Pointer to table containing music data */,
				uint8_t tempo /** paying tempo from 0 to 100. Higher value = slower playback*/ )
	int duration;
	int note;
	int i;
	uint16_t delay = tempo * 10000;
	while( *pMusicNotes )
		note = *pMusicNotes;
		pMusicNotes++;
		duration = *pMusicNotes;
		pMusicNotes++;
		if( p == note )
			//pause, do not generate any sound
			OCR1B = 0;
			//not a pause, generate tone
			OCR1B = DEFAULT_VOLUME;
			//set frequency
			ICR1H = (note >> 8);
			ICR1L = note;
		//wait duration
		for(i=0;i<32/duration;i++)
			_delay_loop_2( delay );
	//turn off any sound
	OCR1B = 0;
Show more of the code. You are clearly using PWM but have not shown the setup of that. You haven't even shown how the note/duration data is defined and passed.
Why did you use the code button to insert your non-code text?!
Anyhow, that page starts by saying,
Aquaticus wrote:
 Playing music is a bit more complicated then generating simple “beep”
So, before trying the (more complicated) music project, did you get the simple "beep" to work?
http://aquaticus.info/pwm-beep
If not, you should probably do so.
even for that, using PWM seems over-complicated - so have you successfully done a simple LED blink, or a really simple beep?
What hardware are you using?
Are you sure that your CPU is running at the frequency you think it is ?
Yes, I did.
Yes, I have.
I am using a Piezzo buzzer/speaker connected to PD4/OC1B (pin 18), the ATMEGA 1284
When I go to |tools > device programming > interface settings| the ISP clock is at 125 kHz. In the comments of the code it says the clock is 8MHz. Idk if this is what you meant in your question.
	Music demo.
	Microcontroller: ATmega16 or ATmega32
	Clock: 8 MHz
	External hardware: Piezzo buzzer/speaker connected to PD4/OCR1B (PDIP pin 18)
	Compiler: AVR GCC
	$Revision: 142 $
#include <util/delay.h>
// The output file from notegen.pl script
#include "notes.h"
/// Default volume, value assigned to OCR1B
#define DEFAULT_VOLUME 100
	Initialize timer1
	PWM output on OCR1B
void InitMusic()
	// Configure OC1B pin as output
	DDRD |= _BV(DDD4); //OC1B as output
	// timer1 configuration (for PWM)
    TCCR1A |= _BV(COM1B1);  // Clear OC1A/OC1B on compare match
	TCCR1B |= _BV(WGM13) 	//mode 8, PWM, Phase and Frequency Correct (TOP value is ICR1)
		   |_BV(CS11); 		//prescaler(8)
	Plays music.
	int duration;
	int note;
	int i;
		pMusicNotes++;
		pMusicNotes++;
		if( p == note )
			OCR1B = 0;
			//set frequency
			ICR1L = note;
		//wait duration
	OCR1B = 0;
const int octave[] = {c4, 8, d4, 8, e4, 8, f4, 8, g4, 8, a4, 8, h4, 8, c5, 8, MUSIC_END};
// Star Wars
const int starwars[] =
	Ais2,8, Ais2,8, P,16, F3,8, F3,8, P,16, Dis3,16, P,16, D3,16, P,16, C3,16, P,16, Ais3,8,
	Ais3,8, P,16, F3,8, P,16, Dis3,16, P,16, D3,16, P,16, C3,16, P,16, Ais3,8, Ais3,8, P,16,
	F3,8, P,16, Dis3,16, P,16, D3,16, P,16, Dis3,16, P,16, C3,8, C3,8,
	MUSIC_END
// Fur Elise
const int furelise[] =
    e4, 8, d4x, 8, e4, 8, d4x, 8, e4, 8, b3, 8, d4, 8, c4, 8, a3,8, p, 8,
    c3, 8, e3, 8, a3, 8,  b3, 4, p, 8, e3, 8, g3x, 8, b3, 8, c4, 4, p, 8, e3, 8,
    e3, 8, d4x, 8, e4, 8, d4x, 8, e4, 8, b3, 8, d4, 8, c4, 8, a3, 8, p, 8, c3, 8,
    e3, 8, a3, 8, b3, 4, p, 8, e3, 8, c4, 8, b3, 8, a3, 4,
    MUSIC_END
// Beatles, Hey Jude
const int Jude[] =
	G2,8, E2,8, P,16, E2,16, E2,16, G2,16, A2,16, D2,8, P,16, D2,16, E2,16, F2,8,
	C3,8, C3,16, C3,16, H2,16, G2,16, A2,16, G2,16, F2,16, E2,8, P,16, G2,16,
	A2,16, A2,8, A2,16, D3,16, C3,16, H2,16, H2,16, C3,16, A2,16, G2,8, P,16,
	C2,16, D2,16, E2,16, A2,16, A2,16, G2,8,
	MUSIC_END
int main()
	PORTB = 0x00;
	InitMusic();
		//PlayMusic( octave, 40 );
		//_delay_ms(1000);
		PlayMusic( furelise, 20 );
		_delay_ms(1000);
		//PlayMusic( starwars, 17 );
		//_delay_ms(1000);
		//PlayMusic( Jude, 35 );
		//_delay_ms(1000);
This is the code I have been using. I isolated to only one song in the main so that I could tell if it was working. I have included the header file as an attachment.
Please clarify: the term "buzzer" would normally be applied to something where you just apply a power supply, and it generates the tone all by itself - whereas a "speaker" has to be supplied with the appropriate drive signal.
See also: http://www.avrfreaks.net/comment...
What I was really asking was whether that's on a commercial board, or your own PCB, or a bread board, or ... ?
But what is the actual clock frequency?
If the code is expecting it to be 8MHz - as the comment says - but it is actaully 1MHz, then the sounds are obviously not going to be quit right ...
I have attached pictures.
How would I check for that?
You can't necessarily tell if it's a "buzzer" or a "speaker" just by looking at it.
Where did you get it? How was it described? give a link.
You could test it by just applying 3V (observing any polarity indication): if it beeps, it's a "buzzer" - not a "speaker"
See http://www.avrfreaks.net/forum/tuthardsoft-avr-clocking regarding clocking
EDIT
polarity
	if( p == note )
That line bothers me. I must be going blind. I don't see this "p" variable anywhere. Something in notes.h perhaps?
EDIT: OK just realised notes.h was an attachment. I can't believe what I am seeing in that!!! ....
#define P 1
#define PAUSE P
#define p P
Seriously?
This is a buzzer. I applied 3V to it and it buzzed.
As for the clocking I have included info about as an attachment. From what I see "the device is shipped with internal RC oscillator at 8.0MHz" according the to ATmega 1284 datasheet. The PDF tutorial was informative thank you.
So that's not going to work for this application - is it?
But the sentence doesn't end there, does it?
You need to read the full sentence:
Note how much easier it is when you embed the image in the post - instructions here: http://www.avrfreaks.net/comment...
I got it working now that I changed that the clock. http://www.avrfreaks.net/forum/solved-atmel-studio-not-compiling-properly
There is not problem using a buzzer or a speaker. (speaker sounds a lot better) The delay between each note is not that bad. The only problem I have now is that each note does not hit the frequency that it needs to hit. It sounds like buzzing with a delay but with the pattern of the melody.
So please mark that post as the solution - to help others who may have the same problem.
Yes, there is:
Think about it: this is bound to be the case - isn't it?
