How to build a project in Atmel Studio 7?
106 posts / 0 new
Pages
That's an annoying thing I find with many (most?) IDEs: once you've fiddled with Project settings, there is no 'undo' or 'exit without saving'
angry
You just have to keep backup copies of the Project files.
Which is why God invented revision control ;-)
Using MSVS (not Atmel Studio - though it's the same) I do find it puzzling that many project property changes you make are written direct to the vcxproj file and yet sometime you File-Exit the IDE and it shows a tree saying you have unsaved changes to SLN->VCXPROJ->... etc. do you want to save it all now? It's never clear why some things are instantly committed to disk and some are only at a File-Save All or whatever ?!?
Hold it right there everyone - So all this while, I could not see what the errors or warnings were. Well the culprit was in the IDE settings - Tools ---> Options ----> Projects ----> Build and Run -----> MSBuild project build output verbosity ----> was set to MINIMAL -----> Changed it to Diagnostic ----> Thanks to the forum member from ATMEL.
This enabled me to see what the errors/warnings were----most of them were to update ISR names as mentioned in the previous posts. I updated them and the project build was successful.
Jim,
The confusion with makefile happened because I initially started with Win AVR  -- In the MFile, there was a line of code to update the programmer used. As of now, I don't have a programmer yet. I would like to know if this is required through AS7. I couldn't load the project that you had sent me (because, I tried to rename it) which actually showed the makefile as a separate window on AS7. So, I assumed that I had done something wrong when I built the project that I had created. I still have the zip you had sent me, strange that the project still doesn't open/cannot be located despite having it on the file. I could locate the makefile, hex files, etc., in the debug folder of the project.
Johan,
I am new to this platform and I want to learn things through this forum. I may have asked a stupid question all together but I have no clue as to how the settings where set to minimal. P.S. I did not mess up the installation.
Thanks everyone.
Best,
Azim
Amateur programmer.
Believe when I tell you that my struggle on here is real.
Someone clearly messed up the verbosity setting ;-)
I did not touch it.
Amateur programmer.
Pages
