Simultaneous TCP and UDP communication problem
3 posts / 0 new
We're using the FreeRTOS and LWIP that came with the EVK1100 evaluation board. (LWIP version 1.2.0)
We have implemented a TCP server and a UDP "server" running in the same thread with the lwip_select (). - Both works as command interpreters, sending answer back.
Running TCP alone and UDP alone works fine
Running TCP and UDP at the same time make the network hang after a while. Other threads are still running.
We have traced to problem down to the while loop below when calling a lwip_sendto on the UDP port: (Always the same)
Does anyone know if this is a known problem of the LWIP port to AVR32 ?
Does anyone know of a fix ?
Thank you.
lwip_sendto()
  lwip_send()
    err = netconn_send(sock->conn, buf);
        sys_mbox_fetch(conn->mbox, NULL);
           sys_arch_mbox_fetch(mbox, msg, 0);
             while( pdTRUE != xQueueReceive( mbox, &(*msg), 10000 ) ) // time is arbitrary
Did you check that the thread's stack size is enough?
I can't remember how lwIP supports configuring buffer sizes etc, but perhaps check that too?
/Jakob Selbing
Jaksel,
Thank you for your comment.
The stacksize of the thread os 384 bytes. How to check if this is enough ?
