Xmega384C3 + FATfs + SPI
4 posts / 0 new
Hi guys,
I have a custom board with xmega384c3 on it and currently I am trying to read/write from a uSD card through SPI interface (SPI C). I am using Elm-chan FatFS and I have modified necessary code to work with xmega384c3 but unfortunately I cannot write anything to the sd card. I think the SPI is inited properly, but the problem seems to be somewhere else in the hardware-dependent code.
A wierd thing I have spotted that after the whole code sample for writing to sd is executed, the SPI SS (CS) pin stays LOW, which it shouldn't, since once the operation is done it should be pulled high, and I have found the issue to be something with 'wait_ready' function.
Would be glad if you could give a check if I have missed something.
Thanks.
/* MMCv3/SDv1/SDv2 Controls via AVR SPI module                           */
/  Copyright (C) 2016, ChaN, all right reserved.
/ * This software is a free software and there is NO WARRANTY.
/ * No restriction on use. You can use, modify and redistribute it for
/   any purpose as you like UNDER YOUR RESPONSIBILITY.
/ * Redistributions of source code must retain the above copyright notice.
#include "diskio.h"
#include "mmc_avr.h"
/* Peripheral controls (Platform dependent) */
#define CS_LOW()		PORTC_OUT &= ~PIN4_bm	/* Set MMC_CS = low */
#define	CS_HIGH()		PORTC_OUT |= PIN4_bm	/* Set MMC_CS = high */
#define SPI_ENABLE_BM SPI_CLK2X_bm | SPI_MODE0_bm | SPI_ENABLE_bm | SPI_MASTER_bm
#define FCLK_SLOW() SPIC_CTRL = SPI_ENABLE_BM | SPI_PRESCALER_DIV128_gc;
#define FCLK_FAST() SPIC_CTRL = SPI_ENABLE_BM;
#define SPDR SPIC_DATA
#define SPSR SPIC_STATUS
#define SPIF SPI_IF_bp
   Module Private Functions
/* Definitions for MMC/SDC command */
#define CMD0	(0)			/* GO_IDLE_STATE */
#define CMD1	(1)			/* SEND_OP_COND (MMC) */
#define	ACMD41	(0x80+41)	/* SEND_OP_COND (SDC) */
#define CMD8	(8)			/* SEND_IF_COND */
#define CMD9	(9)			/* SEND_CSD */
#define CMD10	(10)		/* SEND_CID */
#define CMD12	(12)		/* STOP_TRANSMISSION */
#define ACMD13	(0x80+13)	/* SD_STATUS (SDC) */
#define CMD16	(16)		/* SET_BLOCKLEN */
#define CMD17	(17)		/* READ_SINGLE_BLOCK */
#define CMD18	(18)		/* READ_MULTIPLE_BLOCK */
#define CMD23	(23)		/* SET_BLOCK_COUNT (MMC) */
#define	ACMD23	(0x80+23)	/* SET_WR_BLK_ERASE_COUNT (SDC) */
#define CMD24	(24)		/* WRITE_BLOCK */
#define CMD25	(25)		/* WRITE_MULTIPLE_BLOCK */
#define CMD32	(32)		/* ERASE_ER_BLK_START */
#define CMD33	(33)		/* ERASE_ER_BLK_END */
#define CMD38	(38)		/* ERASE */
#define	CMD48	(48)		/* READ_EXTR_SINGLE */
#define	CMD49	(49)		/* WRITE_EXTR_SINGLE */
#define CMD55	(55)		/* APP_CMD */
#define CMD58	(58)		/* READ_OCR */
static volatile
DSTATUS Stat = STA_NOINIT;	/* Disk status */
static volatile
BYTE Timer1, Timer2;	/* 100Hz decrement timer */
static
BYTE CardType;			/* Card type flags (b0:MMC, b1:SDv1, b2:SDv2, b3:Block addressing) */
/* Power Control  (Platform dependent)                                   */
/* When the target system does not support socket power control, there   */
/* is nothing to do in these functions and chk_power always returns 1.   */
static
void power_on (void)
	/* Trun socket power on and wait for 10ms+ (nothing to do if no power controls) */
	/* Configure MOSI/MISO/SCLK/CS pins */
	PORTC.DIR = 0b10111111;
	PORTC_OUT |= PIN4_bm;
	PORTC_OUT |= PIN7_bm;
	PORTC_OUT |= PIN5_bm;
	PORTC.PIN6CTRL = PORT_OPC_PULLDOWN_gc;
	/* Enable SPI module in SPI mode 0 */
	SPIC.CTRL = SPI_CLK2X_bm | SPI_MODE0_bm | SPI_ENABLE_bm | SPI_MASTER_bm | SPI_PRESCALER_DIV128_gc;
static
void power_off (void)
	/* Disable SPI function */
	/* De-configure MOSI/MISO/SCLK/CS pins (set hi-z) */
	/* Trun socket power off (nothing to do if no power controls) */
/* Transmit/Receive data from/to MMC via SPI  (Platform dependent)       */
/* Exchange a byte */
static
BYTE xchg_spi (		/* Returns received data */
	BYTE dat		/* Data to be sent */
	SPDR = dat;
	loop_until_bit_is_set(SPSR, SPIF);
	return SPDR;
/* Receive a data block fast */
static
void rcvr_spi_multi (
	BYTE *p,	/* Data read buffer */
	UINT cnt	/* Size of data block */
	do {
		SPDR = 0xFF;
		*p++ = SPDR;
		SPDR = 0xFF;
		*p++ = SPDR;
	} while (cnt -= 2);
/* Send a data block fast */
static
void xmit_spi_multi (
	const BYTE *p,	/* Data block to be sent */
	do {
		SPDR = *p++;
		SPDR = *p++;
	} while (cnt -= 2);
/* Wait for card ready                                                   */
static
int wait_ready (	/* 1:Ready, 0:Timeout */
	UINT wt			/* Timeout [ms] */
	BYTE d;
	Timer2 = wt / 10;
	do
		d = xchg_spi(0xFF);
		/* This loop takes a time. Insert rot_rdq() here for multitask envilonment. */
	while (d != 0xFF && Timer2);
	return (d == 0xFF) ? 1 : 0;
/* Deselect the card and release SPI bus                                 */
static
void deselect (void)
	CS_HIGH();		/* Set CS# high */
	xchg_spi(0xFF);	/* Dummy clock (force DO hi-z for multiple slave SPI) */
/* Select the card and wait for ready                                    */
static
int select (void)	/* 1:Successful, 0:Timeout */
	CS_LOW();		/* Set CS# low */
	xchg_spi(0xFF);	/* Dummy clock (force DO enabled) */
	if (wait_ready(500)) return 1;	/* Leading busy check: Wait for card ready */
	deselect();		/* Timeout */
	return 0;
/* Receive a data packet from MMC                                        */
static
int rcvr_datablock (
	BYTE *buff,			/* Data buffer to store received data */
	UINT btr			/* Byte count (must be multiple of 4) */
	BYTE token;
	Timer1 = 20;
	do {							/* Wait for data packet in timeout of 200ms */
		token = xchg_spi(0xFF);
	} while ((token == 0xFF) && Timer1);
	if (token != 0xFE) return 0;	/* If not valid data token, retutn with error */
	rcvr_spi_multi(buff, btr);		/* Receive the data block into buffer */
	xchg_spi(0xFF);					/* Discard CRC */
	xchg_spi(0xFF);
	return 1;						/* Return with success */
/* Send a data packet to MMC                                             */
#if	_USE_WRITE
static
int xmit_datablock (
	const BYTE *buff,	/* 512 byte data block to be transmitted */
	BYTE token			/* Data/Stop token */
	BYTE resp;
	if (!wait_ready(500)) return 0;		/* Leading busy check: Wait for card ready to accept data block */
	xchg_spi(token);					/* Xmit data token */
	if (token == 0xFD) return 1;		/* Do not send data if token is StopTran */
	xmit_spi_multi(buff, 512);			/* Data */
	xchg_spi(0xFF); xchg_spi(0xFF);		/* Dummy CRC */
	resp = xchg_spi(0xFF);				/* Receive data resp */
	return (resp & 0x1F) == 0x05 ? 1 : 0;	/* Data was accepted or not */
	/* Busy check is done at next transmission */
#endif
/* Send a command packet to MMC                                          */
static
BYTE send_cmd (		/* Returns R1 resp (bit7==1:Send failed) */
	BYTE cmd,		/* Command index */
	DWORD arg		/* Argument */
	BYTE n, res;
	if (cmd & 0x80) {	/* ACMD<n> is the command sequense of CMD55-CMD<n> */
		cmd &= 0x7F;
		res = send_cmd(CMD55, 0);
		if (res > 1) return res;
	/* Select the card and wait for ready except to stop multiple block read */
	if (cmd != CMD12) {
		deselect();
		if (!select()) return 0xFF;
	/* Send command packet */
	xchg_spi(0x40 | cmd);				/* Start + Command index */
	xchg_spi((BYTE)(arg >> 24));		/* Argument[31..24] */
	xchg_spi((BYTE)(arg >> 16));		/* Argument[23..16] */
	xchg_spi((BYTE)(arg >> 8));			/* Argument[15..8] */
	xchg_spi((BYTE)arg);				/* Argument[7..0] */
	n = 0x01;							/* Dummy CRC + Stop */
	if (cmd == CMD0) n = 0x95;			/* Valid CRC for CMD0(0) + Stop */
	if (cmd == CMD8) n = 0x87;			/* Valid CRC for CMD8(0x1AA) Stop */
	xchg_spi(n);
	/* Receive command response */
	if (cmd == CMD12) xchg_spi(0xFF);		/* Skip a stuff byte when stop reading */
	n = 10;								/* Wait for a valid response in timeout of 10 attempts */
	do
		res = xchg_spi(0xFF);
	while ((res & 0x80) && --n);
	return res;			/* Return with the response value */
   Public Functions
/* Initialize Disk Drive                                                 */
DSTATUS mmc_disk_initialize (void)
	BYTE n, cmd, ty, ocr[4];
	power_on();							/* Turn on the socket power */
	FCLK_SLOW();
	for (n = 10; n; n--) xchg_spi(0xFF);	/* 80 dummy clocks */
	ty = 0;
	if (send_cmd(CMD0, 0) == 1) {			/* Put the card SPI mode */
		Timer1 = 100;						/* Initialization timeout of 1000 msec */
		if (send_cmd(CMD8, 0x1AA) == 1) {	/* Is the card SDv2? */
			for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF);	/* Get trailing return value of R7 resp */
			if (ocr[2] == 0x01 && ocr[3] == 0xAA) {				/* The card can work at vdd range of 2.7-3.6V */
				while (Timer1 && send_cmd(ACMD41, 1UL << 30));	/* Wait for leaving idle state (ACMD41 with HCS bit) */
				if (Timer1 && send_cmd(CMD58, 0) == 0) {		/* Check CCS bit in the OCR */
					ty = (ocr[0] & 0x40) ? CT_SD2 | CT_BLOCK : CT_SD2;	/* Check if the card is SDv2 */
		} else {							/* SDv1 or MMCv3 */
			if (send_cmd(ACMD41, 0) <= 1) 	{
				ty = CT_SD1; cmd = ACMD41;	/* SDv1 */
			} else {
				ty = CT_MMC; cmd = CMD1;	/* MMCv3 */
			while (Timer1 && send_cmd(cmd, 0));			/* Wait for leaving idle state */
			if (!Timer1 || send_cmd(CMD16, 512) != 0)	/* Set R/W block length to 512 */
				ty = 0;
	CardType = ty;
	deselect();
	if (ty) {			/* Initialization succeded */
		Stat &= ~STA_NOINIT;		/* Clear STA_NOINIT */
		FCLK_FAST();
	} else {			/* Initialization failed */
		power_off();
	return Stat;
/* Get Disk Status                                                       */
DSTATUS mmc_disk_status (void)
	return Stat;
/* Read Sector(s)                                                        */
DRESULT mmc_disk_read (
	BYTE *buff,			/* Pointer to the data buffer to store read data */
	DWORD sector,		/* Start sector number (LBA) */
	UINT count			/* Sector count (1..128) */
	BYTE cmd;
	if (!count) return RES_PARERR;
	if (Stat & STA_NOINIT) return RES_NOTRDY;
	if (!(CardType & CT_BLOCK)) sector *= 512;	/* Convert to byte address if needed */
	cmd = count > 1 ? CMD18 : CMD17;			/*  READ_MULTIPLE_BLOCK : READ_SINGLE_BLOCK */
	if (send_cmd(cmd, sector) == 0) {
		do {
			if (!rcvr_datablock(buff, 512)) break;
			buff += 512;
		} while (--count);
		if (cmd == CMD18) send_cmd(CMD12, 0);	/* STOP_TRANSMISSION */
	deselect();
	return count ? RES_ERROR : RES_OK;
/* Write Sector(s)                                                       */
#if _USE_WRITE
DRESULT mmc_disk_write (
	const BYTE *buff,	/* Pointer to the data to be written */
	if (Stat & STA_PROTECT) return RES_WRPRT;
	if (count == 1) {	/* Single block write */
		if ((send_cmd(CMD24, sector) == 0)	/* WRITE_BLOCK */
			&& xmit_datablock(buff, 0xFE)) {
			count = 0;
	else {				/* Multiple block write */
		if (CardType & CT_SDC) send_cmd(ACMD23, count);
		if (send_cmd(CMD25, sector) == 0) {	/* WRITE_MULTIPLE_BLOCK */
			do {
				if (!xmit_datablock(buff, 0xFC)) break;
				buff += 512;
			} while (--count);
			if (!xmit_datablock(0, 0xFD)) count = 1;	/* STOP_TRAN token */
	deselect();
#endif
/* Miscellaneous Functions                                               */
#if _USE_IOCTL
DRESULT mmc_disk_ioctl (
	BYTE cmd,		/* Control code */
	void *buff		/* Buffer to send/receive control data */
	DRESULT res;
	BYTE n, csd[16], *ptr = buff;
	DWORD *dp, st, ed, csize;
#if _USE_ISDIO
	SDIO_CTRL *sdi;
	BYTE rc, *bp;
	UINT dc;
#endif
	res = RES_ERROR;
	switch (cmd) {
	case CTRL_SYNC :		/* Make sure that no pending write process. Do not remove this or written sector might not left updated. */
		if (select()) res = RES_OK;
		deselect();
		break;
	case GET_SECTOR_COUNT :	/* Get number of sectors on the disk (DWORD) */
		if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) {
			if ((csd[0] >> 6) == 1) {	/* SDC ver 2.00 */
				csize = csd[9] + ((WORD)csd[8] << 8) + ((DWORD)(csd[7] & 63) << 16) + 1;
				*(DWORD*)buff = csize << 10;
			} else {					/* SDC ver 1.XX or MMC*/
				n = (csd[5] & 15) + ((csd[10] & 128) >> 7) + ((csd[9] & 3) << 1) + 2;
				csize = (csd[8] >> 6) + ((WORD)csd[7] << 2) + ((WORD)(csd[6] & 3) << 10) + 1;
				*(DWORD*)buff = csize << (n - 9);
			res = RES_OK;
		deselect();
		break;
	case GET_BLOCK_SIZE :	/* Get erase block size in unit of sector (DWORD) */
		if (CardType & CT_SD2) {	/* SDv2? */
			if (send_cmd(ACMD13, 0) == 0) {	/* Read SD status */
				xchg_spi(0xFF);
				if (rcvr_datablock(csd, 16)) {				/* Read partial block */
					for (n = 64 - 16; n; n--) xchg_spi(0xFF);	/* Purge trailing data */
					*(DWORD*)buff = 16UL << (csd[10] >> 4);
					res = RES_OK;
			if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) {	/* Read CSD */
				if (CardType & CT_SD1) {	/* SDv1 */
					*(DWORD*)buff = (((csd[10] & 63) << 1) + ((WORD)(csd[11] & 128) >> 7) + 1) << ((csd[13] >> 6) - 1);
				} else {					/* MMCv3 */
					*(DWORD*)buff = ((WORD)((csd[10] & 124) >> 2) + 1) * (((csd[11] & 3) << 3) + ((csd[11] & 224) >> 5) + 1);
				res = RES_OK;
		deselect();
		break;
	case CTRL_TRIM:		/* Erase a block of sectors (used when _USE_TRIM in ffconf.h is 1) */
		if (!(CardType & CT_SDC)) break;				/* Check if the card is SDC */
		if (mmc_disk_ioctl(MMC_GET_CSD, csd)) break;	/* Get CSD */
		if (!(csd[0] >> 6) && !(csd[10] & 0x40)) break;	/* Check if sector erase can be applied to the card */
		dp = buff; st = dp[0]; ed = dp[1];				/* Load sector block */
		if (!(CardType & CT_BLOCK)) {
			st *= 512; ed *= 512;
		if (send_cmd(CMD32, st) == 0 && send_cmd(CMD33, ed) == 0 && send_cmd(CMD38, 0) == 0 && wait_ready(30000)) {	/* Erase sector block */
			res = RES_OK;	/* FatFs does not check result of this command */
		break;
	/* Following commands are never used by FatFs module */
	case MMC_GET_TYPE :		/* Get card type flags (1 byte) */
		*ptr = CardType;
		res = RES_OK;
		break;
	case MMC_GET_CSD :		/* Receive CSD as a data block (16 bytes) */
		if (send_cmd(CMD9, 0) == 0 && rcvr_datablock(ptr, 16)) {	/* READ_CSD */
			res = RES_OK;
		deselect();
		break;
	case MMC_GET_CID :		/* Receive CID as a data block (16 bytes) */
		if (send_cmd(CMD10, 0) == 0 && rcvr_datablock(ptr, 16)) {	/* READ_CID */
			res = RES_OK;
		deselect();
		break;
	case MMC_GET_OCR :		/* Receive OCR as an R3 resp (4 bytes) */
		if (send_cmd(CMD58, 0) == 0) {	/* READ_OCR */
			for (n = 4; n; n--) *ptr++ = xchg_spi(0xFF);
			res = RES_OK;
		deselect();
		break;
	case MMC_GET_SDSTAT :	/* Receive SD statsu as a data block (64 bytes) */
		if (send_cmd(ACMD13, 0) == 0) {	/* SD_STATUS */
			xchg_spi(0xFF);
			if (rcvr_datablock(ptr, 64)) res = RES_OK;
		deselect();
		break;
	case CTRL_POWER_OFF :	/* Power off */
		power_off();
		Stat |= STA_NOINIT;
		res = RES_OK;
		break;
#if _USE_ISDIO
	case ISDIO_READ:
		sdi = buff;
		if (send_cmd(CMD48, 0x80000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | ((sdi->ndata - 1) & 0x1FF)) == 0) {
			for (Timer1 = 100; (rc = xchg_spi(0xFF)) == 0xFF && Timer1; ) ;
			if (rc == 0xFE) {
				for (bp = sdi->data, dc = sdi->ndata; dc; dc--) *bp++ = xchg_spi(0xFF);
				for (dc = 514 - sdi->ndata; dc; dc--) xchg_spi(0xFF);
				res = RES_OK;
		deselect();
		break;
	case ISDIO_WRITE:
		sdi = buff;
		if (send_cmd(CMD49, 0x80000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | ((sdi->ndata - 1) & 0x1FF)) == 0) {
			xchg_spi(0xFF); xchg_spi(0xFE);
			for (bp = sdi->data, dc = sdi->ndata; dc; dc--) xchg_spi(*bp++);
			if ((xchg_spi(0xFF) & 0x1F) == 0x05) res = RES_OK;
		deselect();
		break;
	case ISDIO_MRITE:
		sdi = buff;
		if (send_cmd(CMD49, 0x84000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | sdi->ndata >> 8) == 0) {
			xchg_spi(sdi->ndata);
			for (dc = 513; dc; dc--) xchg_spi(0xFF);
		deselect();
		break;
#endif
	default:
		res = RES_PARERR;
	return res;
#endif
/* Device Timer Interrupt Procedure                                      */
/* This function must be called in period of 10ms                        */
void mmc_disk_timerproc (void)
	BYTE n, s;
	n = Timer1;				/* 100Hz decrement timer */
	if (n) Timer1 = --n;
	n = Timer2;
	if (n) Timer2 = --n;
	s = Stat;
				/* Write enabled */
		s &= ~STA_PROTECT;
			/* Card inserted */
		s &= ~STA_NODISK;
	Stat = s;				/* Update MMC status */
So put a breakpoint in deselect() and check that it is hit and watch what actually happens.
It seems that there is some issue with the Timer, for example the code below causes some kind of infinite loop.
for (Timer1 = 2; Timer1; ); /* Wait for 20ms */
You do know that part of using FatFs involves setting up a timer that calls disk_timerproc() regularly don't you? That routine ticks down the TimerN volatile variables that FatFs uses internally for timeouts.
The main.c for AVR in ffsample.zip has this...
/* 100Hz timer interrupt generated by OC0A                 */
ISR(TIMER0_COMPA_vect)
Timer++; /* Performance counter for this module */
disk_timerproc(); /* Drive timer procedure of low level disk I/O module */
