SAMD21 will not wake from standby from timer
5 posts / 0 new
I am trying to wake a SAMD21 from sleep mode using a timer. The timer has the correct period, but stops when in standby mode.
I have tried clocking it from the internal 32KHZ and an external 32KHZ (gclk 1 and 2) and they both stop when in standby.
Here is my conf_clock.h (sorry for the formating the <> button freezes the page in my browser):
 * \file
 * \brief SAM D21 Clock configuration
 * Copyright (C) 2013-2015 Atmel Corporation. All rights reserved.
 * \asf_license_start
 * \page License
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 *    this list of conditions and the following disclaimer in the documentation
 *    and/or other materials provided with the distribution.
 * 3. The name of Atmel may not be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * 4. This software may only be redistributed and used in connection with an
 *    Atmel microcontroller product.
 * THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
 * EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
 * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
 * \asf_license_stop
 * Support and FAQ: visit <a href="http://www.atmel.com/design-supp...">Atmel Support</a>
#include <clock.h>
#ifndef CONF_CLOCKS_H_INCLUDED
#  define CONF_CLOCKS_H_INCLUDED
/* System clock bus configuration */
#  define CONF_CLOCK_CPU_CLOCK_FAILURE_DETECT     false
#  define CONF_CLOCK_FLASH_WAIT_STATES            4
#  define CONF_CLOCK_CPU_DIVIDER                  SYSTEM_MAIN_CLOCK_DIV_1
#  define CONF_CLOCK_APBA_DIVIDER                 SYSTEM_MAIN_CLOCK_DIV_1
#  define CONF_CLOCK_APBB_DIVIDER                 SYSTEM_MAIN_CLOCK_DIV_1
#  define CONF_CLOCK_APBC_DIVIDER                 SYSTEM_MAIN_CLOCK_DIV_1
/* SYSTEM_CLOCK_SOURCE_OSC8M configuration - Internal 8MHz oscillator */
#  define CONF_CLOCK_OSC8M_PRESCALER              SYSTEM_OSC8M_DIV_1
#  define CONF_CLOCK_OSC8M_ON_DEMAND              false
#  define CONF_CLOCK_OSC8M_RUN_IN_STANDBY         true
/* SYSTEM_CLOCK_SOURCE_XOSC configuration - External clock/oscillator */
#  define CONF_CLOCK_XOSC_ENABLE                  true
#  define CONF_CLOCK_XOSC_EXTERNAL_CRYSTAL        SYSTEM_CLOCK_EXTERNAL_CRYSTAL
#  define CONF_CLOCK_XOSC_EXTERNAL_FREQUENCY      12000000UL
#  define CONF_CLOCK_XOSC_STARTUP_TIME            SYSTEM_XOSC_STARTUP_32768
#  define CONF_CLOCK_XOSC_AUTO_GAIN_CONTROL       true
#  define CONF_CLOCK_XOSC_ON_DEMAND               false
#  define CONF_CLOCK_XOSC_RUN_IN_STANDBY          true
/* SYSTEM_CLOCK_SOURCE_XOSC32K configuration - External 32KHz crystal/clock oscillator */
#  define CONF_CLOCK_XOSC32K_ENABLE               true
#  define CONF_CLOCK_XOSC32K_EXTERNAL_CRYSTAL     SYSTEM_CLOCK_EXTERNAL_CRYSTAL
#  define CONF_CLOCK_XOSC32K_STARTUP_TIME         SYSTEM_XOSC32K_STARTUP_0
#  define CONF_CLOCK_XOSC32K_AUTO_AMPLITUDE_CONTROL  true
#  define CONF_CLOCK_XOSC32K_ENABLE_1KHZ_OUPUT    true
#  define CONF_CLOCK_XOSC32K_ENABLE_32KHZ_OUTPUT  true
#  define CONF_CLOCK_XOSC32K_ON_DEMAND            false
#  define CONF_CLOCK_XOSC32K_RUN_IN_STANDBY       true
/* SYSTEM_CLOCK_SOURCE_OSC32K configuration - Internal 32KHz oscillator */
#  define CONF_CLOCK_OSC32K_ENABLE                true
#  define CONF_CLOCK_OSC32K_STARTUP_TIME          SYSTEM_OSC32K_STARTUP_130
#  define CONF_CLOCK_OSC32K_ENABLE_1KHZ_OUTPUT    true
#  define CONF_CLOCK_OSC32K_ENABLE_32KHZ_OUTPUT   true
#  define CONF_CLOCK_OSC32K_ON_DEMAND             false
#  define CONF_CLOCK_OSC32K_RUN_IN_STANDBY        true
/* SYSTEM_CLOCK_SOURCE_DFLL configuration - Digital Frequency Locked Loop */
#  define CONF_CLOCK_DFLL_ENABLE                  true
#  define CONF_CLOCK_DFLL_LOOP_MODE               SYSTEM_CLOCK_DFLL_LOOP_MODE_OPEN
#  define CONF_CLOCK_DFLL_ON_DEMAND               false
/* DFLL open loop mode configuration */
#  define CONF_CLOCK_DFLL_FINE_VALUE              (512)
/* DFLL closed loop mode configuration */
#  define CONF_CLOCK_DFLL_SOURCE_GCLK_GENERATOR   GCLK_GENERATOR_1
#  define CONF_CLOCK_DFLL_MULTIPLY_FACTOR         1500
#  define CONF_CLOCK_DFLL_QUICK_LOCK              true
#  define CONF_CLOCK_DFLL_TRACK_AFTER_FINE_LOCK   false
#  define CONF_CLOCK_DFLL_KEEP_LOCK_ON_WAKEUP     true
#  define CONF_CLOCK_DFLL_ENABLE_CHILL_CYCLE      true
#  define CONF_CLOCK_DFLL_MAX_COARSE_STEP_SIZE    (0x1f / 4)
#  define CONF_CLOCK_DFLL_MAX_FINE_STEP_SIZE      (0xff / 4)
/* SYSTEM_CLOCK_SOURCE_DPLL configuration - Digital Phase-Locked Loop */
#  define CONF_CLOCK_DPLL_ENABLE                  false
#  define CONF_CLOCK_DPLL_ON_DEMAND               false
#  define CONF_CLOCK_DPLL_RUN_IN_STANDBY          false
#  define CONF_CLOCK_DPLL_LOCK_BYPASS             false
#  define CONF_CLOCK_DPLL_WAKE_UP_FAST            false
#  define CONF_CLOCK_DPLL_LOW_POWER_ENABLE        false
#  define CONF_CLOCK_DPLL_LOCK_TIME               SYSTEM_CLOCK_SOURCE_DPLL_LOCK_TIME_DEFAULT
#  define CONF_CLOCK_DPLL_REFERENCE_CLOCK         SYSTEM_CLOCK_SOURCE_DPLL_REFERENCE_CLOCK_XOSC32K
#  define CONF_CLOCK_DPLL_FILTER                  SYSTEM_CLOCK_SOURCE_DPLL_FILTER_DEFAULT
#  define CONF_CLOCK_DPLL_REFERENCE_FREQUENCY     32768
#  define CONF_CLOCK_DPLL_REFERENCE_DIVIDER       1
#  define CONF_CLOCK_DPLL_OUTPUT_FREQUENCY        40000000
/* DPLL GCLK reference configuration */
#  define CONF_CLOCK_DPLL_REFERENCE_GCLK_GENERATOR  GCLK_GENERATOR_1
/* DPLL GCLK lock timer configuration */
#  define CONF_CLOCK_DPLL_LOCK_GCLK_GENERATOR     GCLK_GENERATOR_1
/* Set this to true to configure the GCLK when running clocks_init. If set to
 * false, none of the GCLK generators will be configured in clocks_init(). */
#  define CONF_CLOCK_CONFIGURE_GCLK               true
/* Configure GCLK generator 0 (Main Clock) */
#  define CONF_CLOCK_GCLK_0_ENABLE                true
#  define CONF_CLOCK_GCLK_0_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_0_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_DFLL
#  define CONF_CLOCK_GCLK_0_PRESCALER             1
#  define CONF_CLOCK_GCLK_0_OUTPUT_ENABLE         true
/* Configure GCLK generator 1 */
#  define CONF_CLOCK_GCLK_1_ENABLE                true
#  define CONF_CLOCK_GCLK_1_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_1_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_XOSC32K
#  define CONF_CLOCK_GCLK_1_PRESCALER             1
#  define CONF_CLOCK_GCLK_1_OUTPUT_ENABLE         true
/* Configure GCLK generator 2 (RTC) */
#  define CONF_CLOCK_GCLK_2_ENABLE                true
#  define CONF_CLOCK_GCLK_2_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_2_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_ULP32K
#  define CONF_CLOCK_GCLK_2_PRESCALER             16
#  define CONF_CLOCK_GCLK_2_OUTPUT_ENABLE         true
/* Configure GCLK generator 3 */
#  define CONF_CLOCK_GCLK_3_ENABLE                true
#  define CONF_CLOCK_GCLK_3_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_3_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_DFLL
#  define CONF_CLOCK_GCLK_3_PRESCALER             250
#  define CONF_CLOCK_GCLK_3_OUTPUT_ENABLE         true
/* Configure GCLK generator 4 */
#  define CONF_CLOCK_GCLK_4_ENABLE                true
#  define CONF_CLOCK_GCLK_4_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_4_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_OSC8M
#  define CONF_CLOCK_GCLK_4_PRESCALER             1
#  define CONF_CLOCK_GCLK_4_OUTPUT_ENABLE         true
/* Configure GCLK generator 5 */
#  define CONF_CLOCK_GCLK_5_ENABLE                false
#  define CONF_CLOCK_GCLK_5_RUN_IN_STANDBY        false
#  define CONF_CLOCK_GCLK_5_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_OSC8M
#  define CONF_CLOCK_GCLK_5_PRESCALER             1
#  define CONF_CLOCK_GCLK_5_OUTPUT_ENABLE         false
/* Configure GCLK generator 6 */
#  define CONF_CLOCK_GCLK_6_ENABLE                false
#  define CONF_CLOCK_GCLK_6_RUN_IN_STANDBY        false
#  define CONF_CLOCK_GCLK_6_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_OSC8M
#  define CONF_CLOCK_GCLK_6_PRESCALER             1
#  define CONF_CLOCK_GCLK_6_OUTPUT_ENABLE         false
/* Configure GCLK generator 7 (touch)*/
#  define CONF_CLOCK_GCLK_7_ENABLE                true
#  define CONF_CLOCK_GCLK_7_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_7_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_OSC8M
#  define CONF_CLOCK_GCLK_7_PRESCALER             1
#  define CONF_CLOCK_GCLK_7_OUTPUT_ENABLE         true
/* Configure GCLK generator 8 (UARTBitBang)*/
#  define CONF_CLOCK_GCLK_8_ENABLE                true
#  define CONF_CLOCK_GCLK_8_RUN_IN_STANDBY        true
#  define CONF_CLOCK_GCLK_8_CLOCK_SOURCE          SYSTEM_CLOCK_SOURCE_DFLL
#  define CONF_CLOCK_GCLK_8_PRESCALER             1
#  define CONF_CLOCK_GCLK_8_OUTPUT_ENABLE         true
#endif /* CONF_CLOCKS_H_INCLUDED */
And here are the functions that setup the timer, the timer interrupt, and the callback itself:
void sleep_polling_configure_tc(void)
  struct tc_config sleep_polling_config_tc;
  tc_get_config_defaults(&sleep_polling_config_tc);
  sleep_polling_config_tc.counter_size = TC_COUNTER_SIZE_16BIT;
  sleep_polling_config_tc.clock_source = GCLK_GENERATOR_2;
  sleep_polling_config_tc.clock_prescaler = TC_CLOCK_PRESCALER_DIV1;
  sleep_polling_config_tc.run_in_standby = true;
SYSCTRL->VREG.bit.RUNSTDBY = 1;
  // counts until interrupt = Period in ms * (clk div * 1000) / (clk freq)
  sleep_polling_config_tc.counter_16_bit.compare_capture_channel[0] = (uint16_t)(((unsigned long)SLEEP_POLLING_PERIOD_MS * (unsigned long)32768 / (unsigned long)16) / (unsigned long)1000);
  tc_init(&sleep_polling_tc_instance, SLEEP_POLLING_TC, &sleep_polling_config_tc);
  tc_enable(&sleep_polling_tc_instance);
  tc_stop_counter(&sleep_polling_tc_instance);
void sleep_polling_callback(void)
    port_pin_toggle_output_level(HALL_INT_PIN);
    tc_start_counter(&sleep_polling_tc_instance);
    deepsleep_config();
    system_sleep();         //sleepy time
void sleep_polling_tc_callback_config(void)
  tc_register_callback(&sleep_polling_tc_instance, (tc_callback_t) &sleep_polling_callback, TC_CALLBACK_CC_CHANNEL0);
  tc_enable_callback(&sleep_polling_tc_instance, TC_CALLBACK_CC_CHANNEL0);
Thanks for your help!
Hi Levi,
Do you have the code for functions:
deepsleep_config();
system_sleep();
Did you try configuring the clocks with 'on demand'? In theory that should not improve things, but I'm curious if it changes anything.
Vincent
I did try configuring with an 'on demand' and it didn't help things.
Here are the functions you requested:
void deepsleep_config(void)
  SCB->SCR |= 1<<2; // ensure enabled
  //processor will wake on interrupt from eic8 -> hall
  EIC->WAKEUP.reg = EIC_WAKEUP_WAKEUPEN8;
  //set default to standby
  system_set_sleepmode(SYSTEM_SLEEPMODE_STANDBY);
static inline void system_sleep(void)
__DSB();
__WFI();
The issue turned out to be calling 'system_sleep()' from the interrupt callback. When I call 'system_sleep()' from main everything is hunky-dory.
Calling 'system_sleep()' from the interrupt callback is likely messing up the stack (which in retrospect I should have guessed)
Thanks to all you playing at home!
Hi Levi,
Hmm... if the callback is directly from an interrupt, then unless you have configured nested interrupts, it may block other interrupt from happening (tough technically I would expect it to wake up). I doubt that it would mess up the stack. But __WFI(); inside an interrupt context is never a good idea smiley . Thanks for the update!
Vincent
