Atmel Studio giving error, The Operation Could not be completed
11 posts / 0 new
Hello Everyone,
I am using the latest version of Atmel Studio version-7.0.1417, but I am getting the following errors now.
I installed this setup on my Windows 10 Laptop (i3, 4GB DDR3 RAM), 1 month back, it was working fine and sometimes i get this error but like once in 10 days.
But from last  days I am frequently getting this and I am not able to do anything.
I searched with same keywords and followed the suggestion, like Run as Administrator but nothing works for me.
Even I repaired and reinstalled but again nothing works.
Now the situation is like that, it is working in 1 out of 20 times, most of the time I am restarting Atmel Studio and my Laptop.
Please suggest something to resolve this issue.
When do you see that? Is it when you try to "Build" or something else?
Perhaps tell what you are doing when it pops up.  Editing the source file?  Building? Other?
The top-rated reply (and some of the comments to it) at https://stackoverflow.com/questi... seem to give some good things to try.
The symptom in this https://camerondwyer.wordpress.c... seems to match OP's here...depending on what "operation" was attempted.
Yes, when i am trying to build my project. Rebuilding and Cleaning also results in same errors
I opened the project and the click of build, and I get this error.
Rebuilding and Cleaning also results in same error.
Thanks, I will check this.
But I want to update you guys with one thing, I recalled that few days back I installed an extension for data size, and now I disabled it and after this everything is working fine.
Source Code is building properly.
I don't know, why this happens.
Where, exactly, in the build process does it occur - at the beginning? at the end? during compiling? during linking? or what?
What extension, exactly?
Give a link.
So, when it was failing, were there any messages in the build output?
It rather sounds like the problem is either in or caused by that "extension" - doesn't it?
EDIT
typo
Can we see a complete build output (switch to the Output tab and copy everything and paste here) from a build that fails in this way?
+1
Also, watch the build output as the build proceeds and tell us where the pop-up occurs
(this will probably be easiest if you make the build output window as large as possible)
Hi All,
The extension I installed is "Data Size Viewer", I
https://gallery.atmel.com/Produc...
And there is no update on build output window, as soon as i press the build from menu, i get this error.
After disabling the extension, project is building properly.
But now the condition is even after enabling the extension everything is working properly.
I will post the output window content here, if i face this problem again, but as i remember there is no update and on pressing the build i get the error.
