SAM D20 Xplained pro SPI Slave not receive data
4 posts / 0 new
I used a Sam D20 Xplained pro connect to Atmega32 though SPI.
When Atmega32 is master and Atmega32 is slave I can receive data from master.
But in revert mode Atmega32 is master, Sam D20 is slave, I can't receive any data.
I used ASF code (both Polling and Callback).
Have any point I must config for working?
Thanks.
#define EXT3_SPI_MODULE              SERCOM5
#define EXT3_SPI_SERCOM_MUX_SETTING  SPI_SIGNAL_MUX_SETTING_E
#define EXT3_SPI_SERCOM_PINMUX_PAD0  PINMUX_PB16C_SERCOM5_PAD0 -- MOSI
#define EXT3_SPI_SERCOM_PINMUX_PAD1  PINMUX_PB17C_SERCOM5_PAD1 -- SS
#define EXT3_SPI_SERCOM_PINMUX_PAD2  PINMUX_PB22D_SERCOM5_PAD2 -- MISO
#define EXT3_SPI_SERCOM_PINMUX_PAD3  PINMUX_PB23D_SERCOM5_PAD3 -- SCK
I used default ASF code in SPI Slave Polled but in
spi_is_ready_to_read
I cannot reach true.
have any suggestion?
flag receive_complete cannot true? Do you have any ideal?
Finally, I got solution.
Samd20 Xplained pro have power at 3.3v, I used 5v for atmega32. Now change to 3.3v it's working ok.
