ADS8332 Interfacing With MCU
3 posts / 0 new
I have a question about how I can go about polling or using interrupts for ADC values on an ADS8332.
It's a 16-bit, external ADC that I have connected via SPI on my XmegaA3.
The context is that so far I can read back the device's Configuration Register (CFR). The ADS has two registers, a Command Register (CMR) that takes up bits 15:12, and the CFR register which takes up bits 11:0. So the good thing is that the SPI is working, and seems to be set-up okay to communicate with the ADC.
The problem is when I try reading the values. At the moment, I have a Read Value function that plain and simple doesn't work. I get back weird clusters of 1's like 0xff, 0xfe, or 0xfb. Like I said, it's wrong, but here it is, where the first command 0xd0 writes a Read request to the CMR. It's 3 bytes of data because the last byte is meant to hold the tag bits that tell what channel it's from.
ADS8332 Read Data
void Read_24Bit_Data(uint8_t *Data) {
	PORTC.OUTCLR = PIN4_bm;			_delay_ms(2);
	Data[0] = SPI_Data_Transfer(0xd0);	_delay_ms(2);
	Data[1] = SPI_Data_Transfer(0x00);	_delay_ms(2);
	Data[2] = SPI_Data_Transfer(0x00);	_delay_ms(2);
	PORTC.OUTSET = PIN4_bm;
I call this function from a while(1) loop in main. TI's forum suggested that I use the Eval. Board's interrupt pin to indicate an end-of-conversion (EOC) and that's what I'm asking help for. I'm wondering what the pseudo-code for that might be. I'm thinking that I will
1. Setup an ISR with a generic pin change interrupt trigger, with the pin connected to the board's interrupt pin
2. Clear the interrupt pin inside the ISR
3. Call the Read_Data function inside the ISR
4. Return to main
They say in the datasheet that
This status pin can also be used as an interrupt output, INT (CFR_D[7:6] = 10), which is set low at the end of a conversion, and is brought high (cleared) by the next read cycle. The polarity of this pin, whether used as EOC or INT, is programmable through the CFR_D7 bit.
This is a picture of the timing diagram, and this is the datasheet.
Does this look like a good plan? Thanks
How fast do you want to sample? 500ksps is a sample every 64 clk cycles, so an isr is going to chew up most of them.
Ok true, thanks for the heads up. I got the ADC to work, so damn am I glad.
I think I'll try it with DMA
