Can DMA be used with SERCOM5 on SAML21J18B?
3 posts / 0 new
Hi Atmel. I am using the SAML21J18B.
I notice that the SERCOMx_DMAC_ID_TX  are numbers between 0 and 10 for SERCOM0-4.
This is what I see in sercom5.h  -
#define SERCOM5_DMAC_ID_RX                   // Index of DMA RX trigger
#define SERCOM5_DMAC_ID_TX                   // Index of DMA TX trigger
They are blank, and cause a build error when I tried to use it.
Is SERCOM5 not capable of DMA?
I could not find a list of specific DMA ready peripherals in the datasheet.
Can someone point me to a clue? Thanks.
I've seen people use 11 and 12 on the SAMR21.
THanks.
-M
To follow up, I saw the datasheet also does not list an DMA trigger index for SERCOM5.
It is on a different power domain and clocked differently than the other SERCOMs
It does say that sleep walking is available for this peripheral.
I don't really have any experience with that so I will need to do some research.
-M
And page 568 of the data sheet says no DMA with SERCOM5.
Huzzah!
-M
