Errors after loading ASF wizard
3 posts / 0 new
Hello, I think my Atmel Studio is broken.
When I do the following steps:
- New project -> GCC C Executable Project
- Select chip (UC3B026)
- Starting the ASF wizard from the project
- try to select a board but no board selection is possible
- After hitting "cancel" and loading the INTC driver
when I try debugging the unchanged project, errors are thrown:
Severity    Code    Description    Project    File    Line
Error        first defined here    UC3B0256_Test5    c:\program files (x86)\atmel\studio\7.0\toolchain\avr32\avr32-gnu-toolchain\avr32\lib\ucr1\crt0.o    1
Error        recipe for target 'UC3B0256_Test5.elf' failed    UC3B0256_Test5    C:\Users\Markus\Documents\Atmel Studio\7.0\UC3B0256_Test5\UC3B0256_Test5\Debug\Makefile    206
Error        multiple definition of `_start'    UC3B0256_Test5    c:\users\markus\Documents\Atmel Studio\7.0\UC3B0256_Test5\UC3B0256_Test5\src\ASF\avr32\utils\startup\startup_uc3.S    61
Error        multiple definition of `_stext'    UC3B0256_Test5    c:\users\markus\Documents\Atmel Studio\7.0\UC3B0256_Test5\UC3B0256_Test5\src\ASF\avr32\utils\startup\startup_uc3.S    73
I absolutely don't have a clue what to do now sad
Those errors occur because your project is using the wrong C startup code.
go to the menu : Project -> ... Properties -> Toolchain -> AVR32/GNU Linker -> General and tick the "Do not use standard start files (-nostartfiles)" option.
Great, that solved the problem. Thank you!
