Studio 7.0.1417 can't find device in io.h
4 posts / 0 new
I just installed the latest Studio (1417).  Can't compile.  The preprocessor seems to find the io.h file but the io.h file can't find the device.
The device I specify in the Build > Device is there but it appears the device doesn't get passed to the preprocessor.
I noticed something in the Build > toolchain that doesn't exist in my Studio 6.2.  The field is blank.  Could this be the problem?
Here is the device being set:
Here is the empty field:
Complete build output?
steve17 wrote:
Device is [set in the project properties] but it appears the device doesn't get passed to the preprocessor.
The build system should pass a -mmcu option to the compiler with the actual device name as its value. (Check this looking at the complete build output.) It should result in a preprocessor symbol being defined. You can test it in your main.c, with something like this at the very beginning:
#ifndef defined (__AVR_ATxmega256A3BU__)
#warning "MCU model not defined!"
#endif
Have you tried simply "wiggling" the device model in the project settings? (Change to something else, then change back.)
Is it the  same when you set up a new empty project with the same device?
Thanks Johan.  Yes, the problem is the lack of the -mmcu option.  Why does this keep happening to me?   It happened a year ago with an earlier version of Studio 7.0.  Now I remember I have to put -mmcu in 3 places.  Compiler, linker, and assembler.
Could it be because I  use the offline installer?  The on-line installer is always recommended.  Why is that?
I prefer offline installs because I often install stuff on several OS installations on a couple of computers.  I'm testing this thing now on a Win10 installation I use for testing on my secondary computer.
I'm still running Studio 6.2 on my main computer because 7.0 had a bug with links and folders.  Maybe it's fixed in this version.  Hope springs eternal.
P.S.  Changing the device didn't help.  I feed Studio with a 6.2 project which it upgrades.  I haven't tried a new project.  Studio should come with a warning:  THIS SOFTWARE CAN BE HAZARDOUS TO YOUR HEALTH.
Okay, it looks like the bug in earlier versions of 7.0 has been fixed.  It was worth the torment.  I was doubtful because I saw no mention of this fix in the version release notes.
