ASF ignore CLKPR
3 posts / 0 new
I have ATMEGA48PA, ASF 3.34.2. I want to use devider on 4 for XTAL (3686400/4=921600Hz) via CLKPR, but SYSCLK_PSDIV_4 don't use CLKPR(
conf_board.h
/* =====  Select connected clock source */
/*#define  SYSCLK_SOURCE         SYSCLK_SRC_RC16MHZ */
/* #define SYSCLK_SOURCE        SYSCLK_SRC_RC128KHZ */
/* #define SYSCLK_SOURCE        SYSCLK_SRC_TRS16MHZ */
 #define SYSCLK_SOURCE        SYSCLK_SRC_EXTERNAL
/* ===== System Clock Bus Division Options */
#define CONFIG_SYSCLK_PSDIV         SYSCLK_PSDIV_4
#endif
conf_board.h
#ifndef CONF_BOARD_H
#define CONF_BOARD_H
#define BOARD_EXTERNAL_CLK 3686400UL
The solvetion:
  CLKPR = ( 1 <<CLKPCE);//сначало разлочим регистр
     CLKPR = 0b10;
but it isn't beautiful
What I did wrong?
Greetings and Welcome to AVR Freaks!
Do you really have an external 3.68MHz crystal? What are the CLKSEL fuse bits set to? How do you know that the clock is wrong?
I don't have an ATmega48PA, but according to the simulator, I was able to set the CLKPR to 2 (divide-by-4):
You didn't show main(), are you calling sysclk_init()?
conf_clock.h:
#ifndef CONF_CLOCK_H_INCLUDED
#define CONF_CLOCK_H_INCLUDED
/* ===== System Clock Source Options */
#define SYSCLK_SRC_RC16MHZ    0
#define SYSCLK_SRC_RC128KHZ   1
#define SYSCLK_SRC_TRS16MHZ   2
#define SYSCLK_SRC_RC32KHZ    3
#define SYSCLK_SRC_XOC16MHZ   4
#define SYSCLK_SRC_EXTERNAL   5
#endif /* CONF_CLOCK_H_INCLUDED */
main.c:
#include <asf.h>
int main (void)
	sysclk_init();
	board_init();
	do {
		nop();
	} while (1);
EDIT: typo and
PS: As Jim mentioned, you have to set the CLKSEL fuses to enable the external clock.
Greg Muth
Portland, OR, US
Xplained Boards mostly
Atmel Studio 7.0 on Windows 8.1
