SPI Initialization on UC3B (no ASF)
3 posts / 0 new
how do I initialize the SPI module on the UC3B without using the ASF? I found already found the topic here, but it doesen't work.
My code so far:
void SPI_Transmit()
    data = 0b00000001;          //dummy data
    AVR32_SPI.TDR.td = data;        //write data to the register
    while(!AVR32_SPI.SR.tdre)   //wait for buffer to be cleared
int main (void)
    //clock setup
    AVR32_SPI.MR.mstr = 1;          //master mode
    AVR32_SPI.MR.pcs = 0b0111;  //periphal chip select
    AVR32_SPI.CSR0.scbr = 60;   //setting clockrate to 1 MHz
    AVR32_SPI.CR.spien = 1;     //Enable SPI
So, a pretty basic setup with SPI mode 0 and a SCK frequency of 1 MHz. But I don't see a clock signal on PA15 and the loop is never left by the program. Can someone help please smiley
You have configured, or are selecting, the wrong CSRn (Chip Select Register n)
MR.pcs = 0b0111 will use the configuration in CSR3.
Yup, got it. I changed it to AVR32_SPI.MR.ps = 1; think, that links it to the correct NCPS. But I got it working smiley You are very experienced in using the AVR32 without the ASF, aren't you?
