Solved: TS1620A-17 V2 lcd
9 posts / 0 new
hi
i'm trying to use a Alphanumeric lcd i bought ts1620A-17 V2
i cant get it working
in datasheet says D4_D7 are not used during  4 bit  operation
i tested the code in  proteus
ATMEGA32A
ts1620A-17 V2
can somebody tell mr how this lcds work ts1620A-17 V2
sorry for my bad english
The datasheet I found for this module:
https://www.google.com/search?si...
Page 3 shows D4 - D7 used for 4 bit mode.
This is a standard LCD module that has EXTENSIVE threads on its implementation on this site.  I recommend you use teh Peter Gleury LCD driver library to get it working.  Again there is ample resources on this site for it as well.
Just so you are aware the LCD module is a generic HD44780 LCD, there are hundreds of thousands of Google hits on its use.
EDIT:  It appears that in another datasheet the OP's statement rings true:
http://datasheet.elcodis.com/pdf...
The information on page 6 of this data sheet seems horribly messed up when it comes to the data pins.
It shows pins 7 -10 (four pins) with the symbols DB0 - DB4 (five symbols).  Then the 'function' section calls these the low-order bits but also says that DB7 can be used as a busy flag.
It also shows pins 11 - 14 (four pins) with the single symbol DB5.  Here the 'function' section also lists these as the four low-order bits.
I would go along with your original assumption that this is a run-of-the-mill HD44780 compatible device.
Don
I think he meant Fleury,  here is the link:  http://homepage.hispeed.ch/peter...
ki0bk wrote:
Peter Gleury
A portmanteau for thinking of Fleurys LCD code as Glue logic? ;-)
thanks for responding
i use Codevisionavr and cod wizard and test it in proteus  and it works
do i have to use a potentiometer for PIN 3   VO ?
How to connect the pins to ATmega32      D1-d4 or D4 -D7
#include <mega32.h>
#include <delay.h>
#include <alcd.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRA=(0<<DDA7) | (0<<DDA6) | (0<<DDA5) | (0<<DDA4) | (0<<DDA3) | (0<<DDA2) | (0<<DDA1) | (0<<DDA0);
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTA=(0<<PORTA7) | (0<<PORTA6) | (0<<PORTA5) | (0<<PORTA4) | (0<<PORTA3) | (0<<PORTA2) | (0<<PORTA1) | (0<<PORTA0);
// Port B initialization
DDRB=(0<<DDB7) | (0<<DDB6) | (0<<DDB5) | (0<<DDB4) | (0<<DDB3) | (0<<DDB2) | (0<<DDB1) | (0<<DDB0);
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
DDRC=(0<<DDC7) | (0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
PORTC=(0<<PORTC7) | (0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 8
lcd_init(16);
while (1)
      lcd_putchar('A');
      delay_ms(250);
You have tested in Proteus. So you just wire up your LCD to match your Proteus schematic.
In practice VO pin can be connected to GND. It should have a readable result with 0.00V but a potentiometer might get a better contrast at about 0.45V
i rewired it and it worked
but connecting VO pin directly to GND  did'not worked i had to use a 3k3res
thanks for the help
it worked
Measure the supply voltage to your LCD.   I would expect a good contrast with VO about 4.5V below the VCC.
With a 5V supply,  this would be somewhere between 0.00V and 0.50V
Many LCD modules have an on-pcb resistor from VCC to VO.   So a single resistor between VO and GND forms the other leg of a potentiometer.
3k3 implies that your VCC is higher than 5V.
