Recurring C++ Error
11 posts / 0 new
Greetings -
As I work on a C++ project, this error has become the single most frequent one, and I don't know what it is trying to tell me or how to identify the cause. Pretty sure that it is a C++ error rather than a simple C syntax error (eg, badly formed if() statement, for example). So, here is the header file where the IDE points to the errors (two which likely have the same cause):
#ifndef ORE_SERIAL_H
#define ORE_SERIAL_H
#include <stdint.h>
#include "ArduinoConstants.h"
#define PRINT_CR	1
#define PRINT_LF	2
#define PRINT_CRLF	3
#define PRINT_EOL	PRINT_CRLF
//base designators for print() functions
#define BIN  2		//binary
#define OCT  8          //octal
#define DEC  10		//decimal
#define HEX  16		//hexadecimal
#define BITS8  (1<<UCSZ01)|(1<<UCSZ00)
#define STOP1  0
#define PARITYN	0
#define SERIAL_8N1  BITS8|PARITYN|STOP1   // (the default)
class ORE_Serial {
	private:
	uint8_t RxIdx;
	char * RxPtr;
	char RxBuf[64];
	char NumBuf[34];  //for 32bit ascii binary string plus null terminator
	uint16_t printEOL ( );
	public:
	void begin(uint16_t,uint8_t);
	void end();
	//character
	uint16_t print( char );
	uint16_t println( char );
	//string
	uint16_t print( char * );
	uint16_t println( char * );
	//8-bit number
	//16-bit number
	uint16_t print( int16_t , uint8_t );
	uint16_t println( int16_t , uint8_t );
	uint16_t print( uint16_t , uint8_t );
	uint16_t println( uint16_t , uint8_t );
	uint16_t print( int16_t );
	uint16_t println( int16_t );
	uint16_t print( uint16_t );
	uint16_t println( uint16_t );
	//32-bit number
	uint16_t print( int32_t , uint8_t );
	uint16_t println( int32_t, uint8_t );
	uint16_t print( int32_t );
	uint16_t println( int32_t);
	uint16_t print( uint32_t , uint8_t );
	uint16_t println( uint32_t, uint8_t );
	uint16_t print( uint32_t );
	uint16_t println( uint32_t);
	//double (floating point)
	uint16_t print( double , uint8_t );
	uint16_t println( double , uint8_t );
	uint16_t print( double );
	uint16_t println( double );
#endif //ORE_SERIAL_H
There are other defines that have been commented out, attempting to remove them as possible error sources. The errors point to the line
class ORE_Serial {
The Error List shows:
Severity
Code
Description
Project
File
Line
Error
unknown type name 'class'
ORE_Test
C:\Users\Jim\Dropbox\FloodWatcher\Code\ORE_Test\ORE_Test\ArduinoCompatibility\ORE_Serial.h
90
Error
expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
ORE_Test
90
The Output shows:
------ Build started: Project: ORE_Test, Configuration: Debug AVR ------
Build started.
Project "ORE_Test.cppproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\Jim\Dropbox\FloodWatcher\Code\ORE_Test\ORE_Test\ORE_Test.cppproj" (target "Build" depends on it):
    Task "RunCompilerTask"
        Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
        C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all
        Building file: ../ArduinoCompatibility/ORE_Serial.cpp
        Invoking: AVR8/GNU C Compiler : 4.9.2
        "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega328p" -c -MD -MP -MF "ORE_Serial.d" -MT"ORE_Serial.d" -MT"ORE_Serial.o"   -o "ORE_Serial.o" "../ArduinoCompatibility/ORE_Serial.cpp"
        Finished building: ../ArduinoCompatibility/ORE_Serial.cpp
        Building file: .././main.cpp
        "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega328p" -c -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.cpp"
        Finished building: .././main.cpp
        Building file: ../ArduinoCompatibility/ORE_Digital.c
        "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega328p" -c -std=gnu99 -MD -MP -MF "ORE_Digital.d" -MT"ORE_Digital.d" -MT"ORE_Digital.o"   -o "ORE_Digital.o" "../ArduinoCompatibility/ORE_Digital.c"
        In file included from ../ArduinoCompatibility/ArduinoCompatibility.h:27:0,
                         from ../ArduinoCompatibility/ORE_Digital.c:32:
C:\Users\Jim\Dropbox\FloodWatcher\Code\ORE_Test\ORE_Test\ArduinoCompatibility\ORE_Serial.h(90,1): error: unknown type name 'class'
         class ORE_Serial {
C:\Users\Jim\Dropbox\FloodWatcher\Code\ORE_Test\ORE_Test\ArduinoCompatibility\ORE_Serial.h(90,18): error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
         class ORE_Serial {
        make: *** [ORE_Digital.o] Error 1
    Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "ORE_Test.cppproj" -- FAILED.
Done building project "ORE_Test.cppproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
I HAD been able to build this project, successfully, until removing some tests for the presence or absence of a specific define that were sprinkled through all of the header files.
At this point, I have no clue about where to look. Suggestions, hints, references to previous threads where someone already gave me the answer to this :=) are all welcome.
Many thanks
jim
If you include that header file into a C file, then of course you get errors. C does not know about 'class'.
Enclose the class definition in '#ifdef __cplusplus', then you can use it in C files.
Stefan Ernst
It is included in a cpp file and this is a cpp project.
Other classes seem to work OK. Hmm, actually, ALL of the classes are suddenly throwing the same error. This one appears representative. This is in a cpp project that used to build.
         class ORE_Serial {
ORE_Digital.c is a C file.
Stefan Ernst
Ahh, it appears that I have my #includes messed up! Thanks for catching that.
That was, indeed, the problem. I had a generic "includer" that included a whole bunch of header files. Unfortunately, I did not pay attention to which were C headers and which were C++ headers. That is now fixed. Again, thanks.
It seems odd to me to have a class definition header file with anything else in the file.  But ya gotta learn and maybe you invented a new and better programming scheme.  wink
Some people use .hpp (to match .cpp) to differentiate C++ headers from C .h files.
Of course if all source is .cpp then you know all .h files are C++ headers anyway.
Thanks, Cliff -
That might actually provide a good reminder of what-is-what in a mixed environment.
This is also a lesson in the need to read the output report more carefully :)
Arrrrg.
I hate .cpp , but it, like Windows, seems to have conquered the world.
.cpp makes me think C PreProcessor.
When I have a choice, I use .cc for top-level C++ files and .hh for C++-only headers.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
I use .cpp out of habit.
I found something on the internet that claims to give the options for Microsoft and GNU and several other compilers.  Those are the only 2 compilers I use so I have 3 choices.  I'll stick with .cpp because breaking habits is extra work.
And just one common denominator. So .cpp it is then ;-)
