SAM C21 analog comparator
3 posts / 0 new
Hey,
I've got a SAM C21 Xplained Pro board. I want to use the analog comparator.
I have two external voltages which I want to compare. At first I want to try the example code, but my question is:
Which pins should I use, which connections should be done?
Thanks for help and sorry for the question. I just startet with the Atmel Board a few weeks ago.
Greetings,
Joe
Well, you can read the datasheet for SAM C20/21. Chapter 6 shows which pins can be connected to the comparator. Chapter 28 explains how to configure the pins. Refer to chapter 40 to learn how to configure the AC.
Hey, thank you for your answer.
I still don't get it...
I have two inputs from an analog sensor which I want to compare.
To get familiar with the AC at the SAM C21 board I tried to use the example project and did the quick unit test of the AC component.
For that I should connect PA02 (DAC VOUT) with PA04 (AIN0). I ran the application but the test stops without a message at this spot:  "Testing Analog Comparator Module Initialization"
I know that I have to use the pin PA04 of the VREF-Header for my first signal. But which pin should I use for the second one? Chapter 6 shows me that AIN1 is the PIN PA05 but my board hasn't a pin PA05...
Sorry for this question, but could you please help me again and explain me, how to do it...
Thank you in advance!
