Why interrupt-based TWI instead of polling?
7 posts / 0 new
I've heard that interrupt-based TWI has many advantages over polling, and yes, it does, during slave mode. However, what I don't understand is why interrupt-based TWI still applies for master mode. I mean, interrupt-based or not, we still have to wait for the interrupt flag set before moving on to the next write/read cycle, something that can be done with polling with almost no difference to interrupts, otherwise we get collision errors. So, are interrupts at all necessary for master modes?
avr newbie
At <400kHz, interrupt driven I2C gives you time in between bytes to do other work, if you're using interrupts.
If your TWI communication is interrupt-driven, then you can just pass the whole data packet (SLA+W and payload bytes) to the driver and then go on to do something else in your main loop. The point is, you don't have to wait in a loop for the operation to finish, so you can use CPU time for something else. In the main loop you instead check periodically if TWI operation has completed yet, and if so then you take some action based on the result of the operation (read data, errrors, etc).
Note that this means that in your main loop you in general have to use a state variable to keep track of the TWI operations that you previously started. If you use blocking TWI calls (i.e. not interrupt-driven) then you simply execute operations line by line so that does not necessarily require a state variable.
Sometimes I like to think of interrupt-driven code as "do something only when some kind of action is actually required".
Did you look at Atmel AVR315? It contains a TWI master driver plus the application example below:
 * \file
 * \brief Application to generate sample driver to AVRs TWI module
 * Copyright (C) 2014-2015 Atmel Corporation. All rights reserved.
 * \asf_license_start
 * \page License
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 *    this list of conditions and the following disclaimer in the documentation
 *    and/or other materials provided with the distribution.
 * 3. The name of Atmel may not be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * 4. This software may only be redistributed and used in connection with an
 *    Atmel micro controller product.
 * THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
 * EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
 * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
 * \asf_license_stop
 * Support and FAQ: visit <a href="http://www.atmel.com/design-support/">Atmel Support</a>
#include <avr/interrupt.h>
#include "TWI_Master.h"
#define TWI_GEN_CALL         0x00  // The General Call address is 0
// Sample TWI transmission commands
#define TWI_CMD_MASTER_WRITE 0x10
#define TWI_CMD_MASTER_READ  0x20
// Sample TWI transmission states, used in the main application.
#define SEND_DATA             0x01
#define REQUEST_DATA          0x02
#define READ_DATA_FROM_BUFFER 0x03
unsigned char TWI_Act_On_Failure_In_Last_Transmission ( unsigned char TWIerrorMsg )
                    // A failure has occurred, use TWIerrorMsg to determine the nature of the failure
                    // and take appropriate actions.
                    // Se header file for a list of possible failures messages.
                    // Here is a simple sample, where if received a NACK on the slave address,
                    // then a retransmission will be initiated.
  if ( (TWIerrorMsg == TWI_MTX_ADR_NACK) | (TWIerrorMsg == TWI_MRX_ADR_NACK) )
    TWI_Start_Transceiver();
  return TWIerrorMsg;
 int main( void )
 unsigned char messageBuf[4];
 unsigned char TWI_targetSlaveAddress, temp, TWI_operation=0,
 pressedButton, myCounter=0;
  //LED feedback port - connect port B to the ST600 LEDS
  DDRB  = 0xFF;
  PORTB = myCounter;
  //Switch port - connect portD to the STK600 switches
  DDRD  = 0x00;
  TWI_Master_Initialise();
  sei();//set global interrupt enable
  TWI_targetSlaveAddress   = 0x10;
  // This example is made to work together with the AVR311 TWI Slave application note and STK600.
  // In addition to connecting the TWI pins, also connect PORTB to the LEDS and PORTD to the switches.
  // The code reads the pins to trigger the action you request. There is an example sending a general call,
  // address call with Master Read and Master Write. The first byte in the transmission is used to send
  // commands to the TWI slave.
 for(;;)
    pressedButton = ~PIND;
    if (pressedButton)       // Check if any button is pressed
      do{temp = ~PIND;}      // Wait until key released
      while (temp);
      switch ( pressedButton )
        // Send a General Call
        case (1<<PD0):
          messageBuf[0] = TWI_GEN_CALL;     // The first byte must always consists of General Call code or the TWI slave address.
          messageBuf[1] = 0xAA;             // The command or data to be included in the general call.
          TWI_Start_Transceiver_With_Data( messageBuf, 2 );
          break;
        // Send a Address Call, sending a request, followed by a receive
        case (1<<PD1):
        // Send the request-for-data command to the Slave
          messageBuf[0] = (TWI_targetSlaveAddress<<TWI_ADR_BITS) | (FALSE<<TWI_READ_BIT); // The first byte must always consists of General Call code or the TWI slave address.
          messageBuf[1] = TWI_CMD_MASTER_READ;             // The first byte is used for commands.
          TWI_operation = REQUEST_DATA;         // To release resources to other operations while waiting for the TWI to complete,
                                                // we set a operation mode and continue this command sequence in a "follow up"
                                                // section further down in the code.
        // Get status from Transceiver and put it on PORTB
        case (1<<PD2):
        PORTB = TWI_Get_State_Info();
        break;
        // Increment myCounter and put it on PORTB
        case (1<<PD5):
        PORTB = ++myCounter;
        break;
       // Send a Address Call, sending a command and data to the Slave
        case (1<<PD6):
        messageBuf[1] = TWI_CMD_MASTER_WRITE;             // The first byte is used for commands.
        messageBuf[2] = myCounter;                        // The second byte is used for the data.
        TWI_Start_Transceiver_With_Data( messageBuf, 3 );
        break;
        // Reset myCounter and put it on PORTB
        case (1<<PD7):
          PORTB = myCounter = 0;
          break;
    if ( ! TWI_Transceiver_Busy() )
    // Check if the last operation was successful
      if ( TWI_statusReg.lastTransOK )
        if ( TWI_operation ) // Section for follow-up operations.
        // Determine what action to take now
          if (TWI_operation == REQUEST_DATA)
          { // Request/collect the data from the Slave
            messageBuf[0] = (TWI_targetSlaveAddress<<TWI_ADR_BITS) | (TRUE<<TWI_READ_BIT); // The first byte must always consists of General Call code or the TWI slave address.
            TWI_operation = READ_DATA_FROM_BUFFER; // Set next operation
          else if (TWI_operation == READ_DATA_FROM_BUFFER)
          { // Get the received data from the transceiver buffer
            TWI_Get_Data_From_Transceiver( messageBuf, 2 );
            PORTB = messageBuf[1];        // Store data on PORTB.
            TWI_operation = FALSE;        // Set next operation
      else // Got an error during the last transmission
        // Use TWI status information to determine cause of failure and take appropriate actions.
        TWI_Act_On_Failure_In_Last_Transmission( TWI_Get_State_Info( ) );
    // Do something else while waiting for TWI operation to complete and/or a switch to be pressed
  asm("nop"); // Put own code here.
 /* // This example code runs forever; sends a byte to the slave, then requests a byte
  // from the slave and stores it on PORTB, and starts over again. Since it is interrupt
  // driven one can do other operations while waiting for the transceiver to complete.
  // Send initial data to slave
  messageBuf[1] = 0x00;
  TWI_operation = REQUEST_DATA; // Set the next operation
  for (;;)
    // Check if the TWI Transceiver has completed an operation.
        if (TWI_operation == SEND_DATA)
        { // Send data to slave
          TWI_operation = REQUEST_DATA; // Set next operation
        else if (TWI_operation == REQUEST_DATA)
        { // Request data from slave
          TWI_operation = SEND_DATA;    // Set next operation
    // Do something else while waiting for the TWI Transceiver to complete the current operation
/Jakob Selbing
To put it another way, using interrupts means that the TWI code is "non-blocking". You can have it go off and do something else until the transfer is complete.
Total votes: 2
Nothing specifically to do with TWI - the pros & cons of interrupt vs polled operation are the same for any context.
As others have said, interrupts let the rest of your program get on with stuff - instead of blocking the whole thing while polling.
The price you pay is (somewhat) increased complexity.
Upvoted awneil.
It is up to you whether  you want to bother with this extra complexity.
For small applications it usually is not worth it.
For example polling a rtc ic every now and then can easily be done either way.
But when moving multiple kB of data and your uC has other tasks to attend to in the same time then interrupts are becoming a necessity.
Paul van der Hoeven.
http://www.hoevendesign.com
1) Well you can keep polling & waiting & keep polling & waiting  &...then your sending of pending data will occur as fast as possible (especially if interrupts are off), but other non-interrupt events are being blocked. Of course, this may very well delay the generation of new data to send.  So the gain of one is at the expense of another.
2) You can poll and not wait & try again later & poll and not wait & try again later...then without blocking everything else moves along, but the sending might be comparatively much slower or sporadic  (or even blocked by some other event).
3) You can use interrupts, then sending is almost as fast as possible, depending on how much time is spent waiting on other interrupts.
Each of these could affect the worst-case sizing needed for buffering the data.
You could possibly even use both polling & interrupts, changing modes as the system state or demand changes.
