TSL3301 issue
5 posts / 0 new
(Don't know if its the correct forum or not)
I'm using SAMV71 with TSL3301 sensor.
Using USART( RX,TX and CLK) communication lines.
getting continuous clock and clock frequency is 750KHz( as sensor maximum clock frequency is 10MHz).
offset and gain is set to 0.
After reading pixel, i'm getting 102 bytes of data.(which is ok i guess)
We are Facing issue with TSL3301 concept (as its the very first we are using).
Under normal condition, output is
(255,255,255,255,255,255,255,255............255,255,255)
Oposit to the sendor VSMY2850G is placed and if turned ON, Im getting
(0,0,0,0,0,255,0,0,0,0,255,0,0,0,0,255,0,0,0,0,255,0,0,0,0,255......)
If object placed, the value 0 is changed to 255
wanted to know if the above output is correct or not
madhu
What does the Datasheet say for the device?
I will move this to the SAM forums as thats the device you are interfacing to.
JIm
datsheet says only it will give 102 pixels. i dont no the sensor behaves with/without IR emitter
madhu
