Exception in AVR
8 posts / 0 new
Hello experts
Basically i have a AVR32UC3C0512 chipset we encountered multiple times exceptions when i look in the file exception.S most of it is in assembly with multiple exception handlers executing
rjmp $ which is nothing but an infinite while loop
so i want to track down each of the exception and trace what was the reason for exception by printing some useful information on the log file.
can someone please help with assembly code which can do that
Regards
Not sure how similar to ARM the UC3 is but the classic reason you keep hitting the exceptions in ARM is if you try operating instructions on data with the wrong alignment (like a 32 bit, 4 byte load from a location that is not 4 byte aligned etc). Could it be something similar?
If you've hit an Exception, it means your system is (probably) in a bad state - so trying to do stuff like printing, or using a filesystem may well not be reliable.
A more common approach would be to set a breakpoint in each handler, and then examine the call stack in the debugger.
Or write some data to a RAM area that will not be overwritten on startup, and examine that when the system restarts.
thanks Raving
i agree with your solution but i think it is not very efficient in our case because of the device is a bit like a robot machine when we execute out  software the robots runs all over a fixed area hence Breakpoint and single step
are not the solution for us
what i am trying to achieve is
rather my approach would be remove the rjmp $ in each exception and replace it with something assembly code which can either output some value on the GPIO pin every seconds or every 100 millisecond & reads the call stack
which will indicate one of the exception & to find the reason for the exception we some how need to read the call stack and print it on the file or on the terminal. since the exception.S is in assembly we must do the coding in assembly language
_handle_Unrecoverable_Exception
_handle_TLB_Multiple_Hit
_handle_Bus_Error_Data_Fetch
_handle_Bus_Error_Instruction_Fetch
_handle_NMI
_handle_Instruction_Address
_handle_ITLB_Protection
_handle_Breakpoint
_handle_Illegal_Opcode
_handle_Unimplemented_Instruction
_handle_Privilege_Violation
_handle_Floating_Point
_handle_Coprocessor_Absent
_handle_Data_Address_Read
_handle_Data_Address_Write
_handle_DTLB_Protection_Read
_handle_DTLB_Protection_Write
_handle_DTLB_Modified
_handle_ITLB_Miss
_handle_DTLB_Miss_Read
_handle_DTLB_Miss_Write
_handle_Supervisor_Call
Regards
Nick123 wrote:
i agree with your solution (sic) but i think it is not very efficient in our case
Errr ... I gave two options
Although it may well be wise for other reasons to code such things in assembler, that statement is a non-sequitur.
No need in this case.  Once you have a system that's "in the weeds" just connect the jtag debugger and "break-in" on the execution.  Since all the exception handlers are simple infinite loops, the debugger will show which one it is once you "break-in".  From there you can examine the stack, etc. to gather more info as to the cause.
Good point - assuming that your debugger allows you to "break-in" on the execution - without first doing a reset.
On the old IBM 1130 I learned on way back when, when it encountered an error it would halt, by looking at the address lights one could "see" what the error was that caused the halt.
You could do something similar with some leds, write a uniq light pattern at each vector for each error to the LEDs......
