How to Detect Two Buttons Are Simultaneously True using Danni Debounce
9 posts / 0 new
I'm attempting to develop a C program for the ATMega8 that increments/decrements a value onto a LCD screen using two (increment and decrement) pushbuttons. For debouncing, I'm using the standard Danni Debounce code. One of my requirements is to reset the LCD value back to zero when both button inputs are true at any time. I'm having trouble achieving this, and I have a feeling that it stems from the Danni Debounce code (or at least my understanding of it).
My attempt for simultaneous button press sensing is as follows:
	if(get_key_press(1<<PB1))
		SendCommand(0x01); //clear display
		++LCDValueInt; //inc LCDValueInt
		sprintf(LCDValueString, "%d", LCDValueInt); //convert LCDValueInt to string
		SendAString(LCDValueString); //send string to LCD
	if(get_key_press(1<<PB2))
		--LCDValueInt; //decrement LCDValueInt
	if((get_key_press(1<<PB1)) && (get_key_press(1<<PB2)))
	    LCDValueInt = 0; //reset LCD to zero
For testing, I press and hold the increment button down, and then press and hold the decrement button. The code above will increment the LCD value, but then decrement the value when I press the decrement button instead of resetting the value to zero.
Maybe get_key_press() is the incorrect value for checking if the button is being held down. Maybe there's some value that maintains true while the button remains pressed, but returns to zero when the button is depressed.
Any thoughts on how to achieve the LCD value reset using two simultaneously-pressed, Danni debounced buttons?
The Danni Debounce code I'm using, for reference
ISR(TIMER1_COMPA_vect) ////// debounce interrupt code
  static uint8_t ct0 = 0xFF, ct1 = 0xFF;	// 8 * 2bit counters
  uint8_t i;
  i = ~PINB;				// read keys (low active)
  i ^= key_state;			// key changed ?
  ct0 = ~( ct0 & i );			// reset or count ct0
  ct1 = ct0 ^ (ct1 & i);		// reset or count ct1
  i &= ct0 & ct1;			// count until roll over ?
  key_state ^= i;			// then toggle debounced state
  key_press |= key_state & i;
uint8_t get_key_press( uint8_t key_mask )
	ATOMIC_BLOCK(ATOMIC_FORCEON) // read and clear atomic !
		key_mask &= key_press;		// read key(s)
		key_press ^= key_mask;		// clear key(s)
	return key_mask;
Principally speaking, Dannis debouncer can not detect keys pressed at the same time - and store that information for later. There is no timestamp information stored.
Heres one (weird?) idea
1) Detect that "KEY1" has been pressed and "KEY2" has been pressed, and then, qiuckly
2) Read the raw input pins and if they both are in the pressed state then you have a "simultaneously pressed" situation.
Mind you, if the switches/keys are on different I/O ports then it is theoretically impossible to make a foolproof mechanism for detecting simultaneously pressed keys. Since you can not read two registers at the same time there will be some time glitch between the reads where port stat might change. Perhaaps less than a microsecond, but it is possible.. ;-)
EDIT: Reformulated ingress to my idea.
I'm no expert on this code but as the thing passed to get_key_press() is a bit mask why can't you simply:
if (get_key_press((1 << PB1) | (1 << PB2)) == ((1 << PB1) | (1 << PB2)) { ...
then?
(may have got that wrong - but hopefully the idea is clear?)
I think you would have to "debounce" the condition that both keys are pressed - rather than each key individually ... ?
then?
clawson,
This is exactly what I needed. An interesting find, though:
When this condition is separate from the other 'if' statements in the main For loop, it resets back to zero if both buttons are pressed, but I get strange behavior from the inc/dec buttons - The buttons require multiple sporadic presses before they they inc./dec. the LCD value. They don't inc./dec. as smoothly as without the additional resetting 'if' statement.
See the code below:
for(;;)
		++LCDValueInt;
		--LCDValueInt;
	if(get_key_press((1<<PB1)|(1<<PB2)) == ((PINB & (1<<PB1|1<<PB2))))
		LCDValueInt = 0;
Any thoughts as to why this is? Mostly just out of curiousity. Perhaps a buffering/memory issue with the debounce code?
What I did do what put each resetting conditional if statement into each inc./dec. if statement. This seemed to work just fine, and the values inc./dec. as smoothly as before, as well as resetting when both buttons are pressed.
for(;;)
		++LCDValueInt;
			LCDValueInt = 0;
		--LCDValueInt;
			LCDValueInt = 0;
It might be sloppy, but it seems to work OK so far.
Thanks everyone for the help!
You should clear global var key_press after you detect a key?
MG
get_key_press() does that:
	return key_mask;
Sigh. I feel old.
MG
I'm surprised at that because you follow one get_key_press() with another on the same key.
As JohanEkdahl wrote: get_key_press() clears the global var key_press after you detect a key and that behaviour causes the original code to fail.
This reading of the raw port pin is a bit of a code smell and takes [me] a few read through to determine exactly what's going on.
You could avoid the messy code by reading the key presses into a local variable like this: (There's a code design rule called "Don't repeat Yourself" (DRY) https://en.wikipedia.org/wiki/Don%27t_repeat_yourself I've tried to follow that here also).
for(;;)
    uint8_t key_press = get_key_press((1<<PB1)|(1<<PB2));
    if((key_press & (1<<PB1)) && (key_press & (1<<PB2)))
        LCDValueInt = 0;
        reprintLCDValueInt();
    else if(key_press & (1<<PB1))
        ++LCDValueInt;
    else if(key_press & (1<<PB2))
        --LCDValueInt;
void reprintLCDValueInt (void)
