Counting input pulses and show it on lcd
6 posts / 0 new
i need a code for Atmega32.
the program will take pulses. calculate the pulse rate. multiply with a constant. and show it in lcd.
thanks in advance
Dipu Mahbub
Tell us about the characteristiccs pulse input. Clean transitions, or are we talking about "bouncy" switch signals? What frequency range?
What kind of LCD? Character-based (i.e. 44780 or compatible) or graphics display?
A recent pertinent discussion:  http://www.avrfreaks.net/forum/f...
Whether to use timer-as-counter or input capture (or "manual" creation of thos facilities) IMO/IME depends largely on the characteristics of the input signal.
Yup, Lee.
Let's wait and see if the OP actually is prepared to put in the bulk of the effort himself, or if this is a "give me finished solution" thing..
OP here tacked the request onto a heart-rate monitoring thread, so we can infer some of the information.
Still, if planning to attack the oft-solved heart-rate-monitor app there is still a lot of thinking.  "Multiply with a constant"?  Not really that easy.  First, what does the input look like?  Has that part been "solved"?  Next, do you want to update the display every beat?  Or some kind of rolling average over the last n seconds?  High and low rate tracking/display?  Alarms?
With clean input the rate is so slow that any method could be used.
The OP can continue here http://www.avrfreaks.net/forum/i... , he is spamming all forums with his begging for code. This thread is locked.
Topic locked
