Cannot get SPI on XmegaA3BU-Xplained to work
9 posts / 0 new
Hi Group,
I am having an issue getting the SPI on Port C to work on the XmegaA3BU-Xplained to work.
I started with an Atmel example program (ADC_EXAMPLE1_GFX1) so I could display values on the LCD.
This worked just fine.
Then I added some simple code for the SPI which I cannot get to work.
I write to Port C; the SS signal toggles; the LEDs also blink; but the SPI does nothing.
The values read back from the SPI registers are 0.
It's almost like I am not accessing the SPI Port.
Please tell me what I am doing wrong, I am sure I applied something incorrectly.
The program is below.
Thanks for your help and suggestions.
Paul
 * ADC Test v2
 * Created:	6/30/2017 7:33:47 AM
 *  Author: Paul A. Teseny
 * Company: Scaletron Industries, LLC
 * Processor: ATxmega256A3BU
 *     Board: Xmega-A3BU Xplainned
 * This program reads 24 bit data from the LT2400 ADC using the
 * SPI interface then it writes it on the integrated LCD screen.
 * This software is based on the ADC_Example1_GFX1 example from Atmel.
#include <asf.h>
#include <stdio.h>
 *  Hardware defines
#define SPI_SS_bm           0x10	/* Bit mask for the SS pin.		*/
#define SPI_MOSI_bm         0x20	/* Bit mask for the MOSI pin.	*/
#define SPI_MISO_bm         0x40	/* Bit mask for the MISO pin.	*/
#define SPI_SCK_bm          0x80	/* Bit mask for the SCK pin.	*/
/*	SPI master status code defines	*/
#define SPI_OK              0		/* The transmission completed successfully. */
#define SPI_INTERRUPTED     1		/* The transmission was interrupted by another master. */
#define SPI_BUSY            2		/* The SPI module is busy with another transmission. */
/*	Size of the string output to the display	*/
#define OUTPUT_STR_SIZE		32
#define NUM_BYTES			4
*  Global Variables
char		out_str[OUTPUT_STR_SIZE] ;
uint16_t	paul	=	0x2A ;
uint16_t	joe		=	0x3C ;
uint16_t	herman	=	0x4D ;
/*  Test data to send from master. */
uint8_t masterSendData[NUM_BYTES] = {0x10, 0x20, 0x30, 0x40} ;
/*  Data received from slave. */
uint8_t masterReceivedData[NUM_BYTES] ;
 *	Program Start
	board_init() ;
	sysclk_init() ;
	sleepmgr_init() ;
	irq_initialize_vectors() ;
	cpu_irq_enable() ;
	gfx_mono_init() ;
	/*	Turn ON the LCD Back light	*/
	ioport_set_pin_high(LCD_BACKLIGHT_ENABLE_PIN) ;
	/*	Make Port C Bit 6 an Input	*/
	PORTC_DIRCLR	=	SPI_MISO_bm ;
	/*	Make Port C Bits 7, 5, 4 Outputs	*/
 	PORTC_DIRSET	=	SPI_SCK_bm | SPI_MOSI_bm | SPI_SS_bm ;
	/*	Make Port C Outputs	have pullups	*/
	PORTC_PIN4CTRL	=	PORT_OPC_PULLUP_gc ;	// !SS
	PORTC_PIN5CTRL	=	PORT_OPC_PULLUP_gc ;	// MOSI
	PORTC_PIN7CTRL	=	PORT_OPC_PULLUP_gc ;	// SCK
	/*	Setup SPI on Port C	*/
	SPIC_CTRL = SPI_ENABLE_bm | SPI_MASTER_bm | SPI_MODE_0_gc | SPI_PRESCALER_DIV128_gc ;
	/*	Setup stuff to display	*/
	paul	=	PORTC_DIRSET ;
	joe		=	SPIC_CTRL ;
	herman  =	SPIC_STATUS ;
	/*	Display Values	*/
	snprintf(out_str, OUTPUT_STR_SIZE, "Paul:   %6X  \n", paul) ;
	gfx_mono_draw_string(out_str, 0, 0, &sysfont) ;
	snprintf(out_str, OUTPUT_STR_SIZE, "Joe:    %6X  \n", joe) ;
	gfx_mono_draw_string(out_str, 0, 10, &sysfont) ;
	snprintf(out_str, OUTPUT_STR_SIZE, "Herman: %6X  \n", herman) ;
	gfx_mono_draw_string(out_str, 0, 20, &sysfont) ;
 *  Program Loop
 *	Write a byte to the SPI on Port C
	while (1)
		/*	PHASE 1: Send individual bytes out SPI	*/
		for(uint8_t i = 0; i < NUM_BYTES; i++)
			LED_Toggle (LED0_GPIO) ;
			/*	MASTER: Pull SS line low	*/
			PORTC_OUTCLR = PIN4_bm ;
			/*	Slow it down to see what is happening	*/
			delay_us (5) ;
			/*	MASTER: Transmit data from master	*/
			SPIC_DATA = masterSendData[i] ;
//			while(!(SPIC_STATUS & (1<<7))) ;
			delay_us (5) ;
			/*	MASTER: Release SS to slave. */
			PORTC_OUTSET = PIN4_bm ;
			delay_ms (10) ;
		}	/*	End of Phase 1	*/
			LED_Toggle (LED2_GPIO) ;
	}	/*	End of Program Loop	*/
}	/*	End of MAIN	*/
 *        That's all folks!
You never know where life is going to take you; sit back and enjoy the ride!
This is where a logic analyzer or Oscope comes in handy.
The call to sysclk_init() is enabling Power Reduction (turning off the peripheral clock) for ALL peripherals.  You must TURN OFF power reduction for SPIC.
Greg Muth
Portland, OR, US
Xplained Boards mostly
I have an o'scope connected, there is just nothing to see!
Paul
Thanks Greg,
I'll give that a try.
Paul
Not even these?
Okay; valid point! wink
Paul
Thanks Greg,
That did it! I see 8 clocks per byte now!
Paul
@Paul,
Been there, done that, got the T-shirt.  (More times than I care to admit!)
Greg Muth
Portland, OR, US
