Xmega DFU (via FLIP). An "address is out of range" error.
9 posts / 0 new
Hi All
My question is about device firmware upgrade via FLIP. I'm using ATxmega128A4U, and according to Atmel Studio 7 my program is:
Program Memory Usage : 36054 bytes   25.9 % Full
Data Memory Usage : 1674 bytes   20.4 % Full
An error comes up when trying to load a hex file of my program to a FLIP buffer. So it says "address is out of range", although the xmega's flash memory is 128 kB(application) + 8 kB(bootloader).
What should I change in my program or in FLIP in order to make writing the hex file possible?
Appreciate any help.
Roman
Are you using something like -Wl-Ttext= or -Wl,-section-start=.text= or similar?
Or are you doing something to defeat the discard of .eeprom, .fuse, .lock etc from the ELF during the objcopy?
Yes, I use "-Wl,-section-start=.BOOT=0x20000" to point out where my bootloader section begins.
So how do you think it can influence on the situation?
I made a research and found out that FLIP doesn't allow us to burn a .hex file which somehow touches a bootloader section.
So in my application I use the NVM library for controlling flash memory and almost all the methods of the library are SPM instructions after all. SPM instructions are located in the bootloader section
I'm guessing this may be a bug in Flip. It maybe does not account for chips (Xmega) where the bootloader section is BEYOND the end of the main flash. In a lot of previous AVRs the boot code just stole a small area within the bounds of the chip. So if you had a 32K chip and a 2K bootloader section then it was at 30K but everything was within 32K.  Now, with Xmega you really would have 32K of application and then +2K of bootloader. I wonder if someone has told Flip ?
Unfortunately the bootloader section starts at 0x2000. So I had to remove all NVM related methods from my app in order to provide a possibility of DFU via FLIP.
So do you know any alternative way of Xmega DFU excpt for FLIP? Would be veeery glad to know.
Roman
Well if this is a bug in Flip then I would be looking to see if there is an update version that "knows" about the extra flash that Xmega have for the bootloader. if not I would report it to Atmel and see if they have some kind of immediate workaround.
I've downloaded and installed the last version from the Atmel's web site. Reporting to Atmel is a good suggestion, thanks.
dfu-programmer
http://dfu-programmer.github.io/
... and this is a lightweight alternative to Atmel's own FLIP/BatchISP program.
