maXTouch Xplained Pro Datasheets
5 posts / 0 new
Hi all,
I would like to integrate the maXTouch Xplained Pro into a project.
Before ordering the board I'm looking for the datasheets for both the display controller (ILI9488) and the maXTouch capacitive touch screen controller.  I found the datasheet for the display controller, but didn't found one for the capacitive touch controller.  Where can I find more info about this controller?
Thanks in advance,
Paul
"As simple as possible, but not simpler"
GUI Framework for Atmel Xplained Pro
AIUI/IIRC Atmel tend to work directly with large customers for these controllers; they don't tend to release datasheets.
http://www.atmel.com/products/to...
If you're not a "large customer", you're probably best going through a 3rd party like http://www.touchnetix.com/ (founded by the people from whom Atmel bought the technology)
Or just look for established drivers...
You could try raising a case through whatever the Atmel/Microchip support system is these days...
PaulVdBergh wrote:
Where can I find more info about this controller?  [ATmXT112S]
Another third party is Precision Design Associates (PDA)
PDA has a module with ILI9488 and ATmXT112S; its datasheet states ASF and the Linux kernel.
http://www.pdaatl.com/doc/tm3500.pdf
(page 11)
3.2 Software
via http://www.pdaatl.com/tx35xx.htm
http://asf.atmel.com/docs/latest/asf_components.html
maXTouch - ATMXT122S Controller
http://www.microchip.com/wwwproducts/en/ATmXT112S
and they also go back to Quantum Research: http://www.pdaatl.com/about.htm
+1 for using the SAM4S
+1 For the Pink Floyd background on your project page
I was thinking for picking up a MaxPro but its a bit costly for a 4.3 in TFT. But I do like the FFC connector.
"When all else fails, read the directions"
