atprogram TypeError: unhashable type: 'list'
3 posts / 0 new
Hi this is my first post to this forum, anyway
I'm trying to program an atxmega64a4u with an Atmel ICE 3 using a PDI interface. I have to program around 1000 boards so I would like to write a batch file to help me program them faster. I can program the bootloader using Atmel Studio 7.0 however when I am using atprogram.exe I get an ERROR...  The attached picture shows the input line and the error message.
Thanks for the help!
atprogram List Error
First, you say you have an Atmel ICE 3. There is no such device in existence. It is either a JTAGICE3 or an Atmel ICE. If you have the latter, you need to change that in the commandline.
And then you write -d atxmega64a4u twice. Once should be plenty. I don't know if that could cause such an error, but it's worth a try.
Thanks you were right. I got confused with the different devices that were available
I ended up using the list command to get the name of the device and then implemented the following line
atprogram -d atxmega64a4u -t atmelice -s J41800042662 -i PDI program -f "C:\Users\moipi\Dropbox\Fable2.1\pcb\Firmware Fable\Joint_Bootloader_atxmega64a4u.hex"
and this seems to be working. :D
