Stupid Stupid USART
13 posts / 0 new
Hi guys, I'm having great difficulty finding why this USART does not work, it wont send the it not printing the test sting, "sms_print_string("AT+CMGF=1\r\n");".
Maybe someone with a fresh pair of eyes can see it?
 * _SMS.h
 * Created: 02/06/2017 18:10:51
 *  Author: wmjen
#ifndef SMS_H_
#define SMS_H_
#  define SMS_USART               (&AVR32_USART2)
#  define SMS_USART_RX_PIN        AVR32_USART2_RXD_0_0_PIN
#  define SMS_USART_RX_FUNCTION   AVR32_USART2_RXD_0_0_FUNCTION
#  define SMS_USART_TX_PIN        AVR32_USART2_TXD_0_0_PIN
#  define SMS_USART_TX_FUNCTION   AVR32_USART2_TXD_0_0_FUNCTION
#  define SMS_USART_IRQ           AVR32_USART2_IRQ
static const gpio_map_t SMS_MAP =
 {SMS_USART_RX_PIN, SMS_USART_RX_FUNCTION},
 {SMS_USART_TX_PIN, SMS_USART_TX_FUNCTION}
// USART options.
static const usart_options_t SMS_USART_OPTIONS =
 .baudrate     = 9600,
 .charlength   = 8,
 .paritytype   = USART_NO_PARITY,
 .stopbits     = USART_1_STOPBIT,
 .channelmode  = USART_NORMAL_CHMODE
void sms_print_string(char * );
void sms_print_char(char c);
void sms_hardware(void);
// Function prototypes for GFX Driver
void smsDriver(void);
# define buffer_size 100
#define carriage_return (char)13
#define linefeed (char)10
static volatile char sms_inbuffer[buffer_size];
static volatile unsigned int sms_inbuffer_inptr  = 0;
static volatile unsigned int sms_inbuffer_outptr = 0;
static volatile unsigned int sms_chars_in_inbuffer = 0;
static volatile char sms_outbuffer[buffer_size];
static volatile unsigned int sms_outbuffer_inptr    = 0;
static volatile unsigned int sms_outbuffer_outptr   = 0;
static volatile unsigned int sms_chars_in_outbuffer = 0;
void sms_print_char(char c){
 //enter_critical_section();
 // if transmitter is ready and buffer is empty
 if (usart_tx_ready(SMS_USART) && (sms_chars_in_outbuffer == 0))
  // write to transmitter and enable interrupt (interrupt service routine disables it)
  SMS_USART->ier |= AVR32_USART_IER_TXRDY_MASK; //Enable Tx IRQ
  SMS_USART->thr= c;
  // store in the output buffer
  sms_outbuffer[sms_outbuffer_inptr++]= c;
  if(sms_outbuffer_inptr >= buffer_size){
   sms_outbuffer_inptr= 0;
  if(sms_outbuffer_inptr == sms_outbuffer_outptr){
   delay_us(100);
  sms_chars_in_outbuffer++;
 } //leave_critical_section();
void sms_hardware(void){
 int character, status;
 if (SMS_USART->csr & AVR32_USART_CSR_RXRDY_MASK)
  // receive interrupt, read the char
  status = usart_read_char(SMS_USART, (int *)&character);
  if(status == USART_SUCCESS){
   extern void cs_print_char(char c); cs_print_char(character);
  else{
   SMS_USART->cr = AVR32_USART_CR_RSTSTA_MASK;
 else{
  // transmit interrupt
  if (sms_chars_in_outbuffer == 0)
   // nothing more to send, disable interrupt
   SMS_USART->idr = AVR32_USART_IDR_TXRDY_MASK;
  else if(usart_tx_ready(SMS_USART)){
   // send next char
   SMS_USART->thr= sms_outbuffer[sms_outbuffer_outptr++];
   if(sms_outbuffer_outptr >= buffer_size){
   sms_chars_in_outbuffer--;
 }//leave_critical_section();
void sms_print_string(char * string){
 while(* string != '\0'){
  cs_print_char(*string); string++;
 // Assign GPIO to USART.
 gpio_enable_module(SMS_MAP, sizeof(SMS_MAP) / sizeof(SMS_MAP[0]));
 // Initialize USART in RS232 mode.
 usart_init_rs232(SMS_USART, &SMS_USART_OPTIONS, 66000000);
 // Register the USART interrupt handler to the interrupt controller.
 // usart_int_handler is the interrupt handler to register.
 // EXAMPLE_USART_IRQ is the IRQ of the interrupt handler to register.
 // AVR32_INTC_INT1 is the interrupt priority level to assign to the group of
 // this IRQ.
 // void INTC_register_interrupt(__int_handler handler, unsigned int irq, unsigned int int_lev);
 INTC_register_interrupt(&sms_hardware, SMS_USART_IRQ, AVR32_INTC_INT0);
 // Enable USART Rx interrupt.
 SMS_USART->ier |= AVR32_USART_IER_RXRDY_MASK;
#endif /* SMS_H_ */
One Error is:
// Should Read:
  sms_print_char(*string); string++;
But the error still remains
1) initialise the INTC module.
2) use the correct declaration for the USART interrupt handler.
3) do not try to read from a write-only register (IER).
1. INTC is initialised else where
2. USAT Interrupt Handler does not require __interrupt__, it's called by the main interrupt
3. Am I reading to ier?
be back in a moment!
What error, exactly?
Have you stepped the code in the debugger to see what is (and is not) happening?
BTW: Note that AT commands are terminated by just CR - not CRLF.
The Error is that It Displays Nothing.  Even sending one byte does not work. I have the same code working on another USAT that woks so maybe it is not the code.
But what does that mean?
What is "It" ?
How are you testing this "display" ?
Again, what does stepping through the code show?
It displays nothing on Hyper Terminal, I'm getting there, It is displaying some of the sting.  I'll get back to yous if I need anymore help. Thanks
How is "some of sting", nothing? Got a scope?
It all starts with a mental vision.
"some of" is very different from "nothing" - isn't it?!
Baud Rate and/or Parity would be prime suspects, then.
As already noted, a 'scope would be invaluable here ...
got it.  I'm using a SIM900 Module and it echo's back the character it received, but it is vey slow.  Slowing down the transmission of characters worked.
Thanks Guys
Fianawarrior wrote:
it echo's (sic) back the character it received
Only if you ask it to!
Look at the ATE command to control this ...
Please do yourself (and us)  a favour and buy yourself a USD5 logic analyser salaea clone from ebay/ali.
They work like a charm with sigrok / pulseview and you would have diagnosed this problem yourself in less time than it took to write these posts.
Paul van der Hoeven.
http://www.hoevendesign.com
