USB-CAN Analyzer from SEEED
4 posts / 0 new
USB-CAN Analyzer from Seeed Studio.  $24.90.
Features
  • Optimized the conversion protocol, improved conversion efficiency.
  • Saving customized setting automatically.
  • Hex number converts to Decimal number visualized in the software. Decimal number show both value with symbol and without symbol, don’t need to use calculator.
  • Customized receiving ID, easy to debug.
  • Visualized CAN bus status. Convenient for analyze CAN Bus problem.
  • Can be saved as Excel or TXT file.
  • Receiving data can be refreshed and checked in order.
Hardware
  • Integrated TVS Surge Protection
  • Including 120 ohm matched resistance.
Software
Basic Function
  • Support CAN2.0A(Standard) and CAN2.0B(Expansion)
  • CAN baud rate(5K~1M), customized CAN baud rate.
  • CAN send and receive data with time tag,can show the receiving data in order,can refresh data easily.
  • Data can be sent by single frame, multiple frames, manually, regularly, you can even set a certain time to send.
Enhanced Function
  • Response to data that received from a certain ID.
  • Can check CAN Bus status manually.
  • Can set to receive from the wanting ID directly, without setting filtering ID or shield ID.
  • 4 working mode
  1. Standard Mode: CAN communication
  2. Loop Mode: Self testing, in this mode, the analyzer will send and receive data itself, and also send data to CAN Bus.
  3. Quiet Mode: Only use to monitor CAN Bus without influence.
  4. Loop Quiet Mode: Warm testing
  • Data can be saved as TXT or Excel.
  • Baud rate of virtual COM port can also be modified, default baud rate over 1M, so don’t need to worry about conversion efficiency.
Advanced function
  • All customized setting saved automatically.
  • Easy secondary development,only need to handle 1 command.
  • Transparent Transition function
  • Software supports English
I'll move this to market place.
and I'm surprised that the :"Software supports English" very advanced feature! cheeky
has anybody attempted to use this with Linux?
