Queries
16 posts / 0 new
Please Lock this thread.
I thought the indigenous protocol was smoke signals.
What do you want to achieve? Why not use just one wire?
Hazed wrote:
Is this the right way to go about implementing my protocol? Any ideas on how to improve this?
That is hard to say, because you invented the protocol and we don't know your requirements, you are the best person to judge whether it is right or not.
For example, locking a task for 160 ms per byte while data is sent I would consider the "wrong way", because I expect to handle multiple tasks with my code. If the only task is to handle the comms protocol, then there is no problem. I would use a timer and a state machine to handle the protocol.
Bob.
Have you looked at I2c which has similar signals, probably addresses a number of issues that you may have overlooked in your proprietary protocol & most importantly is supported in hardware on the Mega328p you are using?
unless an academic exercise to gain deeper understanding of the principles involved wheel re-inventing is rarely a good idea.
Hazed wrote:
I wanted to create my own communication protocol, similar to I2C, to see how things work
So the first thing to do is to ensure that you have a thorough understanding of how I2C works.
Start here, with the Official Specification:
UM10204: I2C-bus specification and user manual
Rev. 6 — 4 April 2014
http://www.nxp.com/documents/use...
Designing a Prototcol has nothing specifically to do with AVR - this should be in 'General'
This is not the right way to go about anything!
You are making the classic mistake of jumping straight into implementation without have first done a proper - or, even, any - design.
You need to start by defining the requirements for your protocol.
Then you can move on to a design for your protocol.
Then - and only then - start thinking about implementation.
What are the issues with I2C?
That's a really important question!
After identifying your requirements, one of the first things to do in any design should be to review the current state of the art (aka "prior art") - to see how other people are addressing the same or similar requirements...
You may want to take a step back and ask yourself why, out of all the potential ways to make a serial link between two devices almost all micros in the world have settled on a subset of pretty much just one-wire, I2C, SPI, UART with a few "odd balls" like LIN tacked on (oh, yeah, and this new fangled "USB" thing). If there was a "better way" then it's a pretty fair bet that would be what we'd all be using!
What happens if both devices decide to drive the bus? I2C manages this by using open collector drive so that such a collision is not a problem.
If we were to dissect the I2C protocol, we note the following:
1. it starts off as a simple synchronous protocol
2. they add protocol violations to implement the start and stop states
3. wire 'or' so that collisions can be managed and features like clock stretching can be implemented
4. specific states for device selection and data transfer
I think the OP indicates that it is a learning exercise for him, so I wouldn't worry too much about re-inventing wheel. In practice, there may be occasions when we need to bit bang a protocol, although I would only try to do that as a last resort.
As a generic exercise in "sending and receiving data", I think there are some useful aspects to learn which could apply to other programming problems, particularly in the typical applications for MCUs. I'm disappointed design methods like SDL rarely get a mention, they would help a lot.
Bob.
Wonder why this is done in such an inefficient way then:
  int bits[8];
  /*Generally, to find the k-th bit of n, we use (n >> k) & 1
   * By right-shifting the desired bit into the least significant bit position, masking can be done with 1, to find the value.
  for(k = 0; k < 8; k++)
  bits[k] = (data >> k) & 1;
  //I use this loop to send the data bits as per our requirement through the clock line. The clock line will be set high if the bit is high and vice versa.
  for (i=0; i<8; i++)
    if (bits[i] == 1)
        PORTB |= 0x02;  //Setting the clock line high
        _delay_ms(20);
        PORTB &= ~(0x02); //Setting the clock line low
        _delay_ms(20);
Why not simply:
  for (i=0; i<8; i++, data >>= 1)
    if (data & 1)
        _delay_ms(20);
        _delay_ms(20);
No need for bits[] at all. If you want the bits in the other order then:
  for (i=0; i<8; i++, data <<= 1)
    if (data & 0x80)
EDIT: actually this:
    if (data & 1)
        _delay_ms(20);
        _delay_ms(20);
has _delay_ms() in both conditional statements so surely:
    if (data & 1)
    _delay_ms(20);
At 20ms/bit it is about as slow as sending smoke signals.
You're right, about how the code for that part could avoid using bits[], I've incorporated that as well. Thanks!
Thank you all for all your comments and suggestions. There isn't any specific application to which I wish to try this protocol. It is purely an academic exercise. For testing, I'm trying to use it to send one character from one MCU to another. It will be a system of one master and multiple slaves. The slaves won't drive the system unless they are sending an ACK, so I don't think there is a situation wherein both the master and slave will both be trying to drive the system. I know that there are better, more efficient methods out there. But, I felt that designing a system by myself would help me learn a bit more since when I tried doing I2C or SPI, it merely required setting certain registers, and I didn't exactly get to see how the data moves -- bit by bit (not theoretically, but practically).
However, I am facing issues when it came to designing a function to receive the signals of the master. I'll upload the code (what I've done till now) for the same as soon as possible.
