copy data from an array into a data structure
10 posts / 0 new
hi
i wrote this code to copy data from an array of bytes into an data structure
typedef struct {
	unsigned char data[512];
	unsigned short offset;
}TDataBlock;
unsigned char db_read(void* __ptr, size_t __size, size_t __nmember, TDataBlock* db)
	unsigned int __buffSize = __size * __nmember;
	if(__buffSize > sizeof(db->data)) return 0xFF; // check buffer size
	// cast both source and destination in to an array of bytes
	char* __surc = (char*) db->data;
	char* __dest = (char*) __ptr;
	unsigned int ii = 0;
	for(unsigned int i=db->offset; i<(db->offset+__buffSize); i++)
		__dest[ii] = __surc[i]; // move data
		ii++;
	return 0;
the results seems fine and the function works!
i just wanted to know your opinion about it and if there is a problem with this code, please let me know
thanks.
Don't use double underscore prefix in user code (apart from the fact that it is reserved for the compiler namespace it simply obfuscates the code!)
BTW why did you feel the need to reinvent memcpy()?
Besides the things already mentioned by Cliff:
Why is db->offset not taken into account here?
Stefan Ernst
OK.
thank you all for good advises.
i rewrote the code and now its like this:
unsigned char db_read(void* ptr, unsigned int memb_size, unsigned int nmemb,TDataBlock* db)
	unsigned int buffsize = memb_size * nmemb;
	if(buffsize > sizeof(db->data)) return 0xFF;
	if((db->offset+buffsize) > sizeof(db->data)) return 0xFF;
	memmove(ptr, db->data, buffsize);
	return 0;
and i added a new function to change the offset member of TDatablock
unsigned char db_seek(TDataBlock* db, unsigned int _offset, unsigned char _origin)
	if(_offset > 511) return 0xFF;
	if(_offset < 0) return 0xFF;
	switch(_origin)
		case SEEK_SET : db->offset = _offset; break; // move form start
		case SEEK_CUR : if((db->offset + _offset) > 511) return 0xFF; db->offset += _offset; break; // move from current location
	return 0;
Why twice?
That is not equivalent to your former code. There the source pointer was data+offset.
And why memmove instead of memcpy?
I would not use a magic number here (and later in the function).
Can't happen, _offset is unsigned.
Stefan Ernst
you right replacing my own code with memmove() completely ruined it.
so i am going to stick with my own code.
and about the first question : maybe you did not understand the role of offset member in TDatablock.
it holds current position in our data block.
its like a caret in a text file.
the first if statement checks the size of our destination buffer, it must not bigger that our source.
the second if statement prevents overflow in reading data form data block.
exp:
if offset member in TDatablock is 400
and size of data member in TDatablock is 512 bytes and you want to read data in to a buffer with a size of 250 bytes the code will overflow.
K-AVR wrote:
you right replacing my own code with memmove() completely ruined it. so i am going to stick with my own code.
I already wrote what is wrong.
But the first if doesn't cover any case that is not also covered by the second. If A>B, then is A+C>B also true (for C being unsigned). (*)
Edit:
(*) except A is that much off that A+C overflows. Since your function setting C ensures C<B, it is better to use A>B-C. That truly covers both if statements.
Stefan Ernst
that was a really good explanation thank you.
now i understand what you mean and why first if statement was completely useless.
Here is the code :
	if((buffsize+db->offset) > sizeof(db->data)) return 0xFF;
	char* _surc = (char*) db->data;
	char* _dest = (char*) db->ptr;
	int ii = 0;
	for(unsigned int i=db->offset; i<(db->offset+buffsize); i++)
		_dest[ii] = _surc[i];
		ii++;
	return 0;
Why do you need the variable ii? You can take care of that when you assign your pointers. I'm not sure what the compiler would generate for your code, but i expect your code can be simplified so it would be easier to read and execute.
well.
that actually a very good point. thank you Kartman
i just solved that problem too
here is the code:
	char* _dest = (char*) ptr;
		*_dest = _surc[i];
		 _dest++;
	return 0;
