ATxmega32E5 USART
8 posts / 0 new
Hi Everybody
I used to work with USART and interrupts on ATxmega-AxU. Today I have ATxmega-E5 and never interrupts are triggered. Do i need to initialize XCL ? What is the simpliest way ?
Thanks for help
Regards
    Hervé
XCL has nothing to do with, and many people are using interrupt handling in xmegaE 's USART without any problems.
What kind of program code is it?
Are you sure you configured the interrupt controller correctly? Try this for a start:
PMIC.CTRL |= PMIC_HILVLEN_bm |PMIC_MEDLVLEN_bm|PMIC_LOLVLEN_bm;
sei();
If you post your code, we can help you much better. But be sure to post only the relevant lines, nobody want's to read a thousand lines with only 10 relevant ones.
"Some people die at 25 and aren't buried until 75." -Benjamin Franklin
What is life's greatest illusion?"  "Innocence, my brother." -Skyrim
Thank you Kabasan and Pawi
Here are some files : joined *.c and copied *.s (server don't accept it).
#include "ATxmega32E5def.incs"
#include "asm.h"
#include <avr/interrupt.h>
    .global USARTD0_RXC_vect        /* Reception Complete Interrupt */
    .global USARTD0_DRE_vect        /* Data Register Empty Interrupt */
    .global USARTD0_TXC_vect        /* Transmission Complete Interrupt */
    .global repondre
    .global test_int
test_int:
    cli
    ldi a,USART_SFDEN_bm|USART_RXEN_bm|USART_TXEN_bm
    sts    USARTD0_CTRLB,a
    ldi a,STX
    sts USARTD0_DATA,a            //premier caractère à transmettre
    ldi a,(USART_DRIE_bm|(med_lvl<<USART_RXCINTLVL_gp)|(med_lvl<<USART_TXCINTLVL_gp)|(med_lvl<<USART_DREINTLVL_gp));
    sts USARTD0_CTRLA,a
    sei
    ret
/************************************ programmes sous interruptions **********************************************/
USARTD0_RXC_vect:
    push a
    in a,SREG
    push a
    push yh
    push yl
    lds yl,PointeurRxD
    lds yh,PointeurRxD+1
    lds a,USARTD0_DATA
//    sts USARTD0_DATA,a            //echo
    st Y+,a
    sts PointeurRxD+1,yh
    sts PointeurRxD,yl
    cpi a,ETX
    brne pas_fin_message
    sbi flags_rs,mes_recu
    lds a,USARTD0_CTRLA
    cbr a,(med_lvl<<USART_RXCINTLVL_gp)
    sts USARTD0_CTRLA,a            //interdiction interruptions RxD ultérieures
pas_fin_message:
    pop yl
    pop yh
    pop a
    out SREG,a
    pop a
    reti
USARTD0_DRE_vect:
    push a
    in a,SREG
    push a
    lds a,lg_bufT
    dec a
    sts lg_bufT,a
    brne tst_sup_0
    ldi a,ETX
    sts USARTD0_DATA,a
    rjmp fin_int_tx
tst_sup_0:
    cpi a, 0xFF
    brne emettre
//    sbr flags_com,(1<<emission_terminee)
    ldi a,(1<<USART_TXCIF_bp)
    sts USARTD0_STATUS,a            //RAZ éventuel TXCIF
    ldi a,(USART_DRIE_bm|(med_lvl<<USART_RXCINTLVL_gp)|(med_lvl<<USART_TXCINTLVL_gp)|(disabled<<USART_DREINTLVL_gp));
    sts USARTD0_CTRLA,a
    rjmp fin_int_tx
emettre:
    push zl
    push zh
    lds zl,PointeurTxD
    lds zh,PointeurTxD+1
    ld a,Z+
    sts PointeurTxD,zl
    sts PointeurTxD+1,zh
    sts    USARTD0_DATA,a
    pop zh
    pop zl
    rjmp fin_int_tx
USARTD0_TXC_vect:
    push a
    in a,SREG
    push a
    ldi a,(USART_DRIE_bm|(med_lvl<<USART_RXCINTLVL_gp)|(disabled<<USART_TXCINTLVL_gp)|(disabled<<USART_DREINTLVL_gp));
    sts USARTD0_CTRLA,a
fin_int_tx:
    pop a
    out SREG,a
    pop a
    reti
and GCC correctly initialize vectors : part of *.lss
 98:    0c 94 6e 00     jmp    0xdc    ; 0xdc <__bad_interrupt>
  9c:    0c 94 6e 00     jmp    0xdc    ; 0xdc <__bad_interrupt>
  a0:    0c 94 7c 00     jmp    0xf8    ; 0xf8 <__vector_40>
  a4:    0c 94 9a 00     jmp    0x134    ; 0x134 <__vector_41>
  a8:    0c 94 c0 00     jmp    0x180    ; 0x180 <__vector_42>
I don't know what is wrong or what i forgot...
    Hervé
Even if it shows such a long source code, I am in trouble.
You should buy a debugger.
Interruption is running after removing extra code.
/* main.c *//////////////////////////////////////////////////////////////////////
#define F_CPU 24000000UL
#include <avr/wdt.h>
#include <avr/sfr_defs.h>
#include <avr/sleep.h>
#include <avr/pgmspace.h>
void test_int(void);
#define BSEL    80        //Baud rate 921600 pour clk 24MHz
#define BSCALE    -7
#define BRR        (BSEL+(BSCALE<<12))
void init_uart()
    USARTD0.BAUDCTRLA=(char)BRR;
    USARTD0.BAUDCTRLB=(char)(BRR>>8);
    USARTD0.CTRLC=frame;
    USARTD0.CTRLA= USART_DRIE_bm | USART_RXCINTLVL_MED_gc | USART_TXCINTLVL_OFF_gc | USART_DREINTLVL_OFF_gc;
    USARTD0.CTRLB=((1<<USART_RXEN_bp)|(1<<USART_TXEN_bp));
    PMIC.CTRL |= (PMIC_HILVLEN_bm|PMIC_MEDLVLEN_bm|PMIC_LOLVLEN_bm);
    sei();
    init_uart();
    set_sleep_mode(SLEEP_MODE_IDLE);
    test_int();
    while (1)
        sleep_enable();
        sleep_cpu();
        sleep_disable();
        wdt_reset();
/* asm.s */////////////////////////////////////////////////////////////////////////////////////
#define    a    r16
    .global test_int
test_int:
    cli
    sts    USARTD0_CTRLB,a
    ldi a,0x02    // STX
    sts USARTD0_DATA,a
    ldi a,0b01101010
    sts USARTD0_CTRLA,a
    sei
    ret
USARTD0_RXC_vect:
    nop
    reti
USARTD0_DRE_vect:
    nop
    push a
    in a,SREG
    push a
    ldi a,0b01101000
    sts USARTD0_CTRLA,a
    pop a
    out SREG,a
    pop a
    reti
USARTD0_TXC_vect:
    nop
    reti
Hi Kabasan,
and thank you for help.
made a new project with "your" code : it works ! smiley
Now, i need to see where the differences are... i will not have time today, nor tomorrow. Perhaps in the evening.
Thanks a lot
   Hervé
How to correctly post source code: http://www.avrfreaks.net/comment...
The program is working now. I added 2 other interrupt sources (TCC4 and ADCA) but I had to assign them different priority levels (High and low, USART is using medium level) or the program doesn't work. Does PMIC works as on other XMEGA ? I used XMEGA-AU microcontrollers before, with many interrupts on the same level. Or perhaps i forgot something with this program ?
regards
  Hervé
