watch two registers
7 posts / 0 new
Sir / Madam,
Could anyone tell me how to watch the following two registers ?
#define PRODSIGNATURES_TEMPSENSE0  _SFR_MEM8(0x002E)
#define PRODSIGNATURES_TEMPSENSE1  _SFR_MEM8(0x002F)
Sincerely,
Liu Wang
I have edited the title of your post that contained the whole message!!
Sir / Madam,
Found them in the following window.
Is their value 0x0A80 corresponding to the 85C as specified in Xmega128A1 data sheet ?
Is there a temperature sensor register somewhere in Xmega128A1 ?
What's the resolution of the temperature register value ? 0.5 degree C as of normal temp sensor ?
Sincerely,
Liu Wang
The datasheet says:
• Four internal inputs
Internal temperature sensor
– DAC output
– VCC voltage divided by 10
– 1.1V bandgap voltage
No idea on how to use it unless I read up a lot.
Js,
Thanks the time in commenting and sharing.
Reading more...
Sincerely,
Liu Wang
Solved here http://www.avrfreaks.net/forum/h...
By the way I'm not sure that you have really solved the problem but I may be wrong, you may have fixed the error message but maybe you are not getting the values you want.
Looking at the assembler .inc file I see
.equ NVM_PROD_SIGNATURES_TEMPSENSE0_offset = 0x2E        // Temperature Sensor Calibration Byte 0
.equ NVM_PROD_SIGNATURES_TEMPSENSE1_offset = 0x2F        // Temperature Sensor Calibration Byte 1
usually NVM associated stuff need some special procedure before they can be accessed, so you simple = statement may not work as you expect.
As I said I may be completely wrong on this, not much experience with Xmegas. Someone else may chime in with a more sensible answer.
EDIT Sorry I see that although similar it's not the same, back to normal.
