XMega timer prescaler reset
3 posts / 0 new
I've recently started using the XMega devices instead of the Mega chips.  On the Mega chips (328P/328PB for example), there is a General Timer/Counter Control Register (GTCCR), which can be used to reset the prescaler counter when clearing the timer (PSRSYNC bit), so that there won't be a random fraction of the time period "missing" from the first cycle count.  This makes timing interrupts much more precise after timer resets.  I can't seem to find the equivalent of this on the XMega chips (I'm using the A series, ATxmega64A4U as an example).  Any ideas?
Andras
I think most of the peripherals tap off a common prescaler so a reset signal would have side effects beyond the timer/counters. Seems to me that cascading timers on the XMEGA can achieve the same precision and range you could get on the 328 (with timers to spare).
All TCs share a common prescaler that is separate from the system clock prescalers, so, if you could reset the TC prescaler, it would only effect ALL TCs.
Greg Muth
Portland, OR, US
